If the light flashes 6 times over and over it is the power board. butcheck the lamp
Ur main board have two power ICs is dead,One IC near the FBT,the flyback tranformer a big black block of plastic with a wire red with cap hook to ur CRT.The other IC 6 inches beside it.Know how to solders?Replaced both those ICs will get ur power back.
SOURCE: sony lcd wega KLV-30HR3 Tv turned off wont come
Your TV needs to be repaired. The blinks are a self-diagnostic function built in to Sony TVs. Three blinks may indicate a power supply issue.
If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
