Bosch washing machine
Bosch WFF 1401, Only fills with tiny ammount of water when temperature set above 30deg... Water supply Hot and cold OK to machine and all electric water inlet valves operate (for a short time) to let it fill. My guess is the programmer uses level or temperature sensor to control the fill with Hot/cold... but is the fault with the programmer or sensors ? how can I diagnose.
  • steve hollis Jan 23, 2008
    It seems like this is the problem... with no clothes the the water stopped before it was visible at all in the drum... tried this several times.
    I removed the hose from the water level pressure switch and give it a hard blow few times and re-attached. Now the water level rises until you can see a few centimetres in the drum. I'll check the level on rinse.. but it looks like it's fixed... lets hope it's perminent!
  • 130 Answers
With no clothes in the washer start a program. The washe level is below the door glass. the rinse level comes up 3 cm on the glass. The washer is designed to be water efficent. If you are not getting water this high, look at the pressure switch hose, maybe it is restricted and causing the pressure to be held in the washer.
Posted on Jan 23, 2008
My Bosch vision 300/500 DLX series washing machine continually dispenses hot water no matter what cycle I have dialed in. What can I do?
if it's hot and cold fill machine , have you got the hoses connected correctly hot to hot supply , cold hose to cold mains supply
if its cold supply only to machine , make sure it's not connected to hot water supply, this could be worth checking.
Oct 28, 2016 | Bosch Washing Machines
Which is hot & cold inlet connection
If you want to connect up a washing machine that uses hot and cold water but you only have a cold water supply (such as in a basement or garage) you can use a Y Piece connector to connect the hot and cold fill hoses to a single cold water supply (external link to 4Washerhelp spares).
The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may also be able to buy this part from a DIY store like B&Q)
If you don't connect a water supply to the hot valve (and simply connect the cold water hose to the cold valve leaving the hot valve with nothing connected to it) then some wash programs may not work as some programmes only fill with hot water. However, some washing machines will work OK with only the cold fill hose connected. You can always try it and see. The worse that will happen is the washer could either stick on the odd wash programme or may abort on some. If you do this though it's possible for water to drip out of the hot valve on some machines during fill. It's best to use a y-piece if possible.
The fact that you have connected cold water to the hot valve is irrelevant, the washing machine will not know any different and will just heat the water up to the correct temperature. The washing machine may use slightly more electricity but if it's less than 10 years old it shouldn't be significant unless you use a lot of 60 or 90 degree washes. On 40 degree washes, manufacturers argue it's more efficient to fill with cold water only and slowly heat up the water to 40 degrees.
Apr 30, 2011 | Washing Machines
Can i use just cold water fill for my bosch precision wfg 2020
Yes! You will need to purchase a 'Y' piece which is used upside down - the single end is screwed onto the water supply tap and each of the hot and cold water feeds to the machine screw onto each of the double lower 'arms'. The machine opens its 'hot' water valve, receives just the single supply cold water and then has to heat it to the correct temperature. When it wants cold water- for rinses- it opens its cold water valve ..........and gets the same water supply as the hot valve!
'Y' pieces are normally obtained from local hardware stores - certainly in the UK and France!
Good luck,
John C
Mar 22, 2011 | Bosch Washing Machines
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
I have a bosch clasixx 1400 washing machine and it is not spinning but is going through all the programmes and i have also changeed the carbon brushers, what is wrong?
Make sure the filter is clean, this is located at the bottom front right of washer, unscrew anti-clockwise to remove and clean.
Mar 09, 2010 | Washing Machines
Bosch wff 1401 not emptying water therfor not able to spin the pump goes round but water does not empty if i drain the water the machine will spin
If you have not already done so, then check and clean filter located at bottom front right of washer behind drop down cover.
If it still does not empty, then it is either blocked between the pump and tge waste outlet, or the pump itself could be faulty.
Jan 25, 2010 | Bosch Washing Machines
Cant connect the water hoses the machine
Cold fill only , designed to run efficiently on lower temperatures and with cold water powders
Blank off the hot supply line at the back of your washer before you fit it back to the wall.
Only two pipes on the machine Cold In, Waste out
Apr 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Error code
hi sir one of these problem will be there 1 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
2 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
3 - No mixed fill. It is likely that the water is not turned on at the taps.
4 - Check the water supply, inlet valve and hot and cold hose connections.
4 - A fault with the water heating has occurred.
5 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked.
6 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then book a service engineer.
7 - Door not closed properly. Close door firmly at the 3 o'clock position.
E20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing.
thank u............
Sep 11, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing machine - Bosch WFF 1401 - spinning problem
Bosch WFF 1401 This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2007 | Washing Machines
Washing Machines Logo
242 people viewed this question
Top Washing Machines Experts
