Question about Asko 24 in. D3350 Dishwasher
Asko D3350 code F7
Dishwasher showing code F7.
The pump is running properly, the drains are OK.
Is the pump stopped by a sensor or by timer?
  • kjeldg Jan 25, 2008
    Thanks a lot!
    I have checked drain pump, hoses, installation of drain
    hose.
    How can I check the control unit ?
  • 126 Answers
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
Posted on Jan 24, 2008
2 Suggested Answers
cschichtl
  • 43 Answers
SOURCE: Asko D3350 code F7
you seem rushed
ok
the problem might not be in your senser or timer but in the pump its self
Posted on Sep 14, 2008
My asko D5155 stops washing and flashes F7
LED L1+ L2/Fault code F7, Pumping out fault (machines with
pressure sensor)
Water not evacuated after 120 seconds pumping out. Program
interrupted.
Check: Drain pump, hoses, installation of drain hose, control unit and wiring.
Dado
Oct 06, 2015 | Asko Dishwashers
Asko D3350 code F7
you seem rushed
ok
Sep 14, 2008 | Asko 24 in. D3350 Dishwasher
I have an Asco D3350 dishwasher. When the cycle starts the machine fills with water and when there appears to be the right amount of water in the machine an error code F4 shows on the panel. 3 clicks can...
There could be a variety of problems most common clean filter sensor water level faulty replace or pump not working how old and how often do you use it?
Aug 29, 2017 | Asko 24 in. D3350 Dishwasher
Hi I have an Asko D3350, and have an 'F7' problem, can anyone help. Starts all wash programs then stops half way through with f7 showing. but the pump and discharge hose is clear. If it means anything it...
At the bottom of the dish washer where the water drains from there is a rectangular hole at the back (you will need to remove all the baskets and the screen). Grease can accumulate here and block the tube that feeds a pressure switch, causing this malfunction. This grease will not be visible as it sits under a lip on the other side of the rectangular hole and above it. This would need to be removed carefully as one doesn't want to push the grease into this tube
Feb 02, 2011 | Asko 24 in. D3350 Dishwasher
F7 code
yes remove filter and water from under filter theres a small chamber at the back of the sump,it may be full of fat clean it with your finger then try running some heavy wash cycles to clean it.
May 02, 2010 | Asko 24 in. D3350 Dishwasher
ASKO D1986: Water pump running constantly
Solved by draining water from bottom pan.
Jan 18, 2009 | Asko 24 in. D3350 Dishwasher
Asko 3350 Dishwasher
The "F7" code means that the drain is blocked. To remove items from the drain: 1.Turn power to unit off. 2. Remove the "Coarse Filter" by squeezing the tabs together and lifting out. 3. Remove the "Fine Filter" and "Main Filter" by removing the screws around the filters and lifting them out. 4.Remove the small black adapter piece and check the sump area for debris. 5.Wash the filters out gently with hot, soapy water. DO NOT RUN THE UNIT WITHOUT THE FILTERS IN PLACE! 6.Replace the black adapter piece to its original position FIRST (Important!). 7.Replace the filters in reverse order of removal and turn the unit back on. The error code should reset and work normally. *In areas with hard-water, the filters should be removed every 8-12 months and submerged in a chemical solution (CLR or LimeAway) to remove mineral deposits. Hope this helps...
Sep 04, 2008 | Asko 24 in. D3350 Dishwasher
D3350 - Code F9
Jan 19, 2008 | Asko 24 in. D3350 Dishwasher
Asko D3350
Steve, according to the codes listed on http://www.repairclinic.com/0078.asp apparently F7 is a bad door latch. It could be just not shutting fully or maybe one of the springs/rods needs looking at.
Is there anything recently that may have happened to the door? Slamming, jarring, etc.
Dec 21, 2007 | Asko 24 in. D3350 Dishwasher
F4 Fault indication
F4 is a water inlet fault. It doesn't make sense if you have this fault indication with water flowing into the unit. Does the dishwasher drain properly? Usual suspects for an F4 indication would be a clogged inlet line, water supply turned off, bad fill valve, or a control board failure. Let me know if this helps, or give me a little more information on what you have done to correct so far.
Jul 09, 2007 | Asko 24 in. D3350 Dishwasher
Asko 24 in. D3350 Dishwasher Logo
3,536 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
