Question about Dell Latitude D600 Notebook
Battery is not charging and also the charging LED is getting ON
Mate i have baught the laptop about three days ago and now when iam charging the laptop the battery LED is not getting ON and the battery didnot charge please help me on this
  • Edtoth Jan 30, 2008
    I have a D600 and I cannot get the laptop to run on battery power and the power meter does not recognize that a battery is installed!
  • Anonymous Feb 04, 2008
    L E D is also blinking red and the battery is not charging
  • 56 Answers
Hi
First of all go into the bios and see if the battery is being detected or not.just go down to battery option and it would you the details.incase its not try taking it out and putting it back in.Incase still not working you can get the battery replaced
Posted on Jan 19, 2008
Why won't my PC power-up?
Firstly you should not unplug your computer for long times. Inside is a battery to keep the BIOS alive. When you unplug it, it flattens the battery and if left unplugged for a long time, it kills it. This means that the BIOS now starts in default mode, which can lead to many problems because all the custom BIOS settings are now lost forever or until you or someone else change them.
Change the battery on the motherboard and try again.
The reason why the LED was flashing then stops, is that the battery has a small charge enough to be stable. Now that your BIOS battery is dead, you will never be able to charge that battery again, so replace it.
Sep 01, 2014 | Watches
My Brand new Ryobi 18v lithium-ion battery P104, I bought this three years ago and just now needed it. I opened it from the blister pack it was in and I tried to charge it. When in the charger the red...
get the new charger; and consider returning to store or manufacturer.
if you have the black charger, throw it out
you need the green/two-tone charger for ryobi one 18v
Mar 18, 2017 | Drills
N500 will not charge
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 12, 2012 | Lenovo 3000 N500 Notebook
My LG laptop is not powering on. what will i do? I didn't used it for three days then when I started to turn it on. there is no power. When I put the power cord, there is no light on the battery. What...
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Jul 06, 2011 | LG Computers & Internet
Inspiron 6000 flashing orange light for three batteries. I took apart two, made one using three groups of three cells that were fully charged and rebuilt another with brand new cells, and both get the...
The flashing orange LED is a Battery Critically Low indication.
If the Windows Battery Meter and the BIOS do not show the batteries charging then there may circuit problem in your battery.
If you can, try battery in another system, if you can't, I'd try a new battery before doing any hardware changes to the system
Dec 24, 2009 | Dell Inspiron 6000 Notebook
We Dont Kno!!!
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop power it up then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 02, 2009 | Dell Inspiron 6400 Notebook
Phone doens't turn on : (
hi. i would seriously return this phone asap. this phone has a defective circuit board and battery bay. the core has failed prematurely. return for a free replacement asap.
May 23, 2009 | i-mate Jama 101 Smartphone
DELL XPS 1210 i purchased a replacement battery not recognised
If the battery is not detected in the BIOS (F2 at boot) and doesn't show as charging, then return the battery and get a replacement.
If neither the original battery or the new replacement battery are not detected in the bios a problem with the motherboard may exist. If still under warranty, contact Dell Support for a repair, if not, then you may be investing in a new motherboard
Jan 29, 2009 | Dell Inspiron 1501 Notebook
I.Mate -JAQ charging problem
my i mate jaq charging jak iss broken i need charging jak jumoers
Aug 27, 2008 | i-mate JAQ Pocket PC
it is not your battery that is the problem but the charger so you will need to go somewere like officemax and buy a universal charger and if you still have problems then call HP tech support there friendly people
Jun 23, 2008 | HP Pavilion dv6000z Notebook
Dell Latitude D600 Notebook Logo
140 people viewed this question
Alun Cox
