I am using a Dell Inspiron 510m and the CD/DVD tray keeps popping out on it own without even trying to open it.. once i leave it or set it on a table or desk the tray opens on its own..What is wrong with my computer?
Almost all cd and dvd or bluray drives have a manual way of opening. Usually it is a small opening to the right of the button to open the drive. Make sure the system is OFF to try this. Just straighten a paper clip and insert it in the opening and give it a small push. The door should manually slide open.
CD/DVD Drive Tray problems There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work. Go to My Computer and right click on the drive and click on Eject. If this does not work then you can manually open the CD/DVD drive tray by - Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc. If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc. Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens. If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Two things to check: First, look on the tray edge - does it say DVD and CD, or just CD? If it does not say DVD,it will not play them. The second thing is you may not have software to play a DVD. Usually Windows will use media player, assuming you have a dvd player. You can also open "my computer" and the drive will show up as a DVD or just CD.
It is most likely jammed. If you look on the front of the drive, there should be a little hole. Use a paper clip that you have straightened out and insert it into the hole. When you feel resistance, push it hard carefully. The hole is an emergency/manual tray release. It should pop the tray out. If you can't get the tray to release and you have a CD or DVD in the drive, you will have to take the drive out of the system and take it apart to get the platter out. Of course this means you will have to buy a new drive as the old one will probably be unusable, even if you try to put it back together.
If there is any life left in your notebook drive connecting it to another IDE drive could allow you to transfer the data to the PC.
This next link is for connecting your laptop drive to a PC drive. http://www.paddlersite.com/2lato3deideh.html
This is a CD drive mechanical problem. All CD/DVD drives have built in error checking for mechanical failures. When you insert the CD/DVD, it tries to grab and seat the disc, then attempts to spin it up and then read it. If the grab and seat function fails for any reason, the drive will eject the tray so you can try again. You should contact Dell support and get the drive replaced. Has the drive ever worked? or did it just stop working one day?
You can see a hole located on the tray of the cd rom drive. Commonly seen beside the button to eject the cd out. Grab a small pin and push the hole and this should eject the tray. Close the tray again by pressing the button. Eject it using the button. If everything still failed, call up Dell to have the CD Rom Drive replaced.
