Question about Liebert (PS2200RT2230) UPS System
Liebert UPS fan work fast even when off
Liebert UPS fan work fast even when it off, the ups indicate load even with no load
my email:
    Problem Solver:
  • 7 Answers
This system is opperated by fieldeffect transistors it may be obviouse that 1 or 2 component especially the FET may be sort circuting
Posted on Jan 25, 2008
  • benito jumarito Jul 07, 2013
    it does affect the performance of the UPS?.
How to correct fault on liebert gxt3?
Disconnect batteries. Shut off the UPS wait 5 min. If alarms returns then something is wrong with your unit
Aug 18, 2014 | Liebert UPStation GXT2700RT-208...
After battery is discharge because power failure, ups is not automatically working even there is power supply
Check on the back of the UPS to see if the input circuit breaker has tripped. Are you getting any lights on the front LED's? Also disconnect all loads and ensure nothing is plugged into the output receptacles. Also open UPS up and ensure the input fuse is not blown. You will need a meter to check this out.
Oct 11, 2011 | Liebert UPStation GXT2000RT-120...
How to cennect the input line, L1 and L2
If you open the back of the UPS and unscrew the 3 large screws you should see where the input and the output hook up. I have a user manual if you need one. Just email me at and ask for the manual. If you have one then can you be a little bit clearer on what is needed.
Sep 20, 2011 | Emerson Fans Liebert GXT2 6000RT UPS AC...
How many systems support for 1 KV UPS
1 KVA UPS will provide you good back up with 2 pcs simultaneously without any power fluctuations.
May 24, 2010 | Liebert 1 KVA UPS MODEL RT1000-60...
U p s by pass l e d flashing light
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. Including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. If one battery is faulty in a set of batteries it will causes the whole battery system to fail and indicate a battery fault.
A faulty charging circuit will not charge the batteries and will also cause a fault condition.
Nov 29, 2009 | Liebert (PS2200RT2230) UPS System
My Liebert PSA itON 600 UPS keeps beeping when i turned it on
To figure out what's wrong with the UPS, first you have to do a few things.
When calculating the rating a UPS can handle, it's voltage x amperage. If it's Watts multiply the number by 1.67 to give the rating of the device.
Add up all the devices (use the power supply rating in the computer) as well as any other device, and add them up.
If this rating was exceeded, then you have overloaded the UPS. If it was too long that you did this, then you wore out the battery.
When a UPS beeps even when not connected, that means the battery is very weak.
If the battery is more than 3 years old, it will need to be changed. If the online tests of the unit were done and the battery doesn't need replacing, then other parts of the UPS need fixing.
Check the battery.
Jul 27, 2009 | Liebert PowerSure ProActive PSA700 UPS...
Need repair manual for Liebert UPStation GXT1500RT
Hello gypsy6767, I spent 10 years as a Liebert Rep here in the Phoenix, Az. market! Here is a link to the Liebert GXT User's Manual -
I hope this helps,
Mar 12, 2009 | Liebert UPStation GXT1500RT...
Liebert (PS2200RT2230) UPS System Logo
168 people viewed this question
Top Liebert Computers & Internet Experts
Computer Links
Are you a Liebert Computer and Internet Expert? Answer questions, earn points and help others
