Question about Dryers
Cleaning What is the best method of cleaning the condenser unit and seals? I have no instruction manual.
  • 126 Answers
Put the condenser in the shower, and flush it to it is clear off lint. Wipe off the seals with a wet rag.
Posted on Jan 28, 2008
Where is the condenser in my Kenmore French door bottom freezer, and how to clean
Condensers are usually on the bottom of the unit and you can clean them by blowing out the dust with the exhaust side of a vacuum cleaner. Or an air compressor if you have one.
Some newer refrigerators have the condenser coils on one of the walls so they are inaccessible for cleaning. But since they are sort of sealed off there is really no need to clean since nada gets in there.
Aug 20, 2015 | Kenmore Refrigerators
Maytag dryer mdc1305aaw
try follow the instruction on original manual or at web site indicated below
http://www.manualslib.com/manual/100392/Maytag-Mdc1305aaw.html?page=14#manual
Important: Always switch off and remove the plug from the electricity supply before cleaning the condenser. To maintain the efficiency of the dryer regularly check that the condenser is clean. To remove the condenser 1. Remove the kickplate (see page 13). 2. Turn the two locking levers anti-clockwise and pull out the condenser. 3. Pull out the condenser unit. 4. Gently remove any dust or lint with a cloth, then wash the unit by holding it under a running tap turning it so that water flows between the plates, to remove any dust or lint. 5. Refit the condenser ensuring it is in the correct way (as indicated by the arrow) and pushed firmly into place. Lock the two levers by turning them clockwise. 6. Refit the kickplate.
plug back the machine
Apr 22, 2014 | Washing Machines
RefRegeREtor not cold
Hello Tanya - When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Contact a professional to move forward accurately from this point.
Dec 01, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Display not working
Hello Lan Sutton - Since the unit is now not cooling, when was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator or control board may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Contact a professional to move forward accurately from this point.
Nov 25, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The ice cube indicator is blinking
From the manual:
The Control Center monitors refrigerator and
freezer temperatures as well as the ice maker
system. If there is a temperature or ice maker
problem, you'll be alerted by a flashing
SERVICE indicator light. This same SERVICE
light will also flash if the condenser needs
cleaning. Before calling for service, please
check and see if your condenser area needs
cleaning. Refer to Condenser Cleaning,
page 22.
CONDENSER CLEANING
In all Built-In models, the condenser is located
behind the grille. First, remove the grille. Then
using a soft bristle brush, vacuum to remove
dust and lint from the condenser. NOTE: To
avoid bending the condenser fins, be sure to
vacuum in the direction of the fins (up and
down). Clean the condenser area every three
to six months.
CAUTION
Before cleaning the unit, shut the electricity
off at the control panel. When you
clean the condenser, wear gloves to avoid
injury from the sharp condenser fins.
Failure to clean the condenser could
result in temperature loss or mechanical
failure or damage.
Mar 14, 2011 | Sub-Zero 650 / O Bottom Freezer...
Water sensor light keeps coming on even tho tank empty have checked hoses and cleaned large filter at front
try cleaning out the condenser unit, instuctions are on pages 2 and 3 of your manual, if you dont have it download it from the indesit website.
fluff and old stuff gathers in it, if you leave it too long it will burn out the thermostat
instructions below.
Step 1
Open the condenser cover
- grip the handle and pull
towards you.
Step 2
Remove the condenser by
turning the 3 catches, then pull
the condenser towards you. (It is
normal for some residual water
to be left in the tubes).
Step 3
Clean the condenser with running
water over the rear side to
remove any fluff deposits.
Step 4
Replace the condenser unit;
make sure that the unit is
securely in place, that all 3
catches are fixed and that the
position arrows on the front end
of the condenser are pointing
upwards.
Nov 15, 2010 | Indesit IS70C Electric Dryer
How do I open the goodman condensing unit for cleaning
I suggest taking the top screen and possibly the condenser motor out. If you try to take off the cage that surrounds the unit, you may not get it back on right. Best to push the dirt out with a hose from the inside out.
Jul 15, 2010 | Amana Heating & Cooling
Subzero 532 refridge cooling but freezer won't freeze
Unit has separate compressors and thermostat's. Clean the condenser, if it doesn't improve call for service, as there is a decent chance you will need sealed system work or defrost issue. If you need instructions on cleaning the condenser check subzero.com.also try advanceing the defrost timer as they mostly die in the defrost cycle. Behind the grille there will be a panel with a small hole in it with a screw above and below. Use a flat blde screw driver to turn the gray piece in th small hole clockwise a few clicks. If the freezer comes back on you will need to replace the defrost timer.
Jul 26, 2009 | Sub-Zero 690 Side by Side Refrigerator
Re-located condenser, trying to charge unit in cold weather. How do I do this?
It's probably too late to recommend capturing (bottling) the charge in the condensing unit...... With that said the absolute 100% way to charge any unit is to use the weight method. If you look on the nameplate of the unit it will provide you the amount of refrigerant needed in lbs and ounces, the manufacture instruction manual will give you the additional weight needed for the lenght of the line set. In the event you don't have the ability to weigh the refrigerant accurately you can always wrap the condensing unit with a blanket reduce the condensing capacity of the condenser this will simulate a warmer ambient and allow you to charge the unit. If the unit has a fixed orfice metering device you can use the superheat method, if the unit has a TXV (thermal expansioin valve) you should use the subcooling method. Either of these methods with detailed proceedures can be found on any of the popular search engines. Hope this helps and good luck!
Oct 05, 2008 | Goodman CLQ36AR49 Air Conditioner
Dryers Logo
77 people viewed this question
Top Dryers Experts
