Question about ViewSonic (CO21)
Display monitor screen is blank with message says our of range.
I want to hook up a 19 inch Westinghouse monitor to a Directv receiver using the DMI input. But all I get is a message that says OUt of Range.
Posted on May 28, 2008
    Brigadier General:
  • 6,966 Answers
Assuming that there is no hardware fault, this is indicative that your PC's Screen Resolution and/or Screen Refresh Rate are higher than what the monitor can display.
To correct, start your PC in Safe Mode, go to Display Properties (right click on any clear area of your desktop, click on Properties, click on Settings tab, move Screen resolution towards left or 800 X 600 and lower Color quality to 16 bit) and lower down all settings (including Advanced/Monitor/Screen refresh Rate). Reboot.
Once in Normal Mode, do the same again and increase settings one step at a time and click OK/Apply. In the event that the display disappears again, hit escape and/or revert back to last known good setting(s).
Hope this be of help.idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 19, 2008
Where can I find a driver/adapter for Advent X19W LCD Monitor?
Goto device manager , uninstall the card. go into control panel and check that the driver is uninstalled from the programs list. Swich of the pc for a minute or two then reboot Windows updares does not download drivers for graphics cards so will not install or reinstall the driver that is causing the issue, 307? Users forget to uninstall from program manger in control panel which is why the card keeps reinstalling with the undesired driver.
Please let me know what happens
Dec 14, 2014 | Nvidia Computers & Internet
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
I TRIED TO RESET THE RESOLUTION. THE SCREEN WENT BLANK AND THE MESSAGE ON THE SCREEN SAYS IMPUT SIGNAL OUT OF RANGE
I believe the max resolution this LCD can support is 1440 x 900 / 75 Hz. If you set your display resolution higher then that, you will receive the input signal out of range error. Your LDC turns off to protect it self from the invalid settings. If you can not change it back once your PC boots to windows, you may have to do it in save mode by pressing F8 once you power on your PC and before the windows loading screen starts.
Regards, Chris
Jun 29, 2011 | Hannspree 19" Widescreen LCD Flat Panel...
My samsung 750s monitor has a message saying sync. out of range
When you turn off the pc the monitor loses the sync signal and should go into a suspend mode where the screen is blanked. The power management settings should be checked. In display properties check that the monitor is installed correctly.
Jun 06, 2010 | Samsung SyncMaster 750S Monitor
DELL E153FPf doesn't show the image
OSD Warning Messages A warning message may appear on the screen indicating that the monitor is out of sync range.
Cannot Display This Video Mode
This means that the monitor cannot synchronize with the signal that it is receiving from the computer. Either the signal is too high or too low for the monitor to use. See Specifications for the Horizontal and Vertical frequency ranges addressable by this monitor. Recommended mode is 1024x768 @ 60Hz.
Occasionally, no warning message appears, but the screen is blank. This could also indicate that the monitor is not synchronizing with the computer or the monitor is in a power save mode.
Jan 18, 2010 | Dell E153FPf 15" TFT LCD Flat Panel...
WHY DID MY MONITOR GO BLACK AND HAVE A MESSAGE THAT IT WAS OUT OF RANGE ALSO WILL GO BLANK TURN IT OFF THEN BACK ON AND IT WORS AGAIN
Out of range message indicates that you are running at a resolution or refresh rate that is not compatible.Go to your display settings and change to different settings.
Sep 25, 2009 | Princeton Digital VL1916 19" LCD Monitor
Connecting PC to television
Hi and welcome to FixYa,
Initially, try the lowest possible Screen Resolution in the PC's Display Properties. You could also try lowering the Screen refresh Rates. This is especially so if the PC connects to the TV using composite (yellow) video out or S-Video. In some video cards/settings, it may be necessary to enable twin/dual view in the display properties.
Good luck and Thank you for using FixYa. Happy New Year.
Jan 01, 2009 | Hitachi SuperScan Elite 802 21" CRT...
Over range auto detectable flashes across screen
Restart the computer in safe mode by tapping the "F8" key as it comes on. Then open display properties and set the display settings to a lower setting and restart the computer.
You
Jan 04, 2008 | Albatron L17AS 17" Flat Panel LCD Monitor
Likom Futura LDF770
There may wrong setting of refresh rate. Most monitors work at 60 to 70 Hz refresh rate. Above that they tunned blank screen or out 0f range message displayed. Also check the output video signal. Please confirm technical specifications from the documentatation of the monitor.
Aug 15, 2007 | Likom Futura LD7 17" CRT Monitor
Open Questions:
24X7 availability and assistance for your call toshiba laptops. Are you witnessing issues in your Toshiba laptop like your laptop isn't working since you installed an app, driver or update? Many Toshiba laptop and pc users report issues they face in their day to day life. Toshiba technical support is always available to help customers confront such situations and resolve issues for better working laptops and their longer productive lives. In case your Toshiba laptop is not letting you peacefully open the start menu or you are facing troubles installing any update or your newly installed update is not working the way it was supposed to then this article will help you in getting all the right answers for your issues. Toshiba support email is always available to help its customers at any time of the day and they even provide on-site support facilities. Toshiba support is provided by experienced and professional technicians who use industry authorized advanced technical tools and techniques to cater fully effective measures used to counter all possible issues that interrupt the productive working of Toshiba devices. In case you are facing issues in your Toshiba laptop you simply call our Toshiba laptop support , you can find out the cause of those issues by restarting your pc in the safe mode. Taking this option will remove all those apps, drivers and updates you have installed after the restore point was created but nothing will happen to your personal files. For using the restore point, you have to go to the control panel and type recovery in the search bar of control panel window. After that you have to choose the option of open system restore and click on next. You have to then select the most recent apps, drivers and update and click on the option of scan for affected programs. You can always contact Toshiba customer support using their toll-free helpline number +1888784-9316. They will provide on-site and on-line support assistance over the phone, email or chat. If restoring from the restore point doesn't help then you can reset your pc and wait for issues to get resolved. Resetting results in reinstalling of Windows after choosing which files you want to keep or remove. Resetting option is available in the settings menu. Under the sub section of update and security, there will be the option of recovery which will further have an option of reset this pc. For assistance in technical issues you can contact Toshiba customer care anytime.
Sep 26, 2018 | Toshiba Computers & Internet
See all ViewSonic (CO21) Questions
Computers & Internet Logo
187 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
