Question about Cooktops
Wiring a new energy regulator
Dear sirs,
One of the electric hobs has packed up. Upon investigation, I establish the energy regulator had burnt out rather than an element fault. Through the internet, I stumbled across a company called espares who suppled me with the part (no. 082590800). Upon receipt and when endeavouring to replace the old, I was horrified to find the new part has 4 electrical terminals (1 x brass & 3 x silver), there are only 3 wires to plug in however. It is obvious the design has moved on but I do not know which 3 of the 4 teminals to wire up. I contacted espares whostated that they do not have a wiring diagram and I should contact the manufacturer. I subsequently phoned New World who said they could not provide a wiring diagram as they did not supply the part directly to me. When I quoted the part number, the response was there was no guarantee the part supplied was the same as the part number.
I am therefore caught between a rock and a hard place. I would be most grateful if you could offer some assistance, many thanks in advance
Terry Pook
terry.pook@ntlworld.com
  • No brains Jan 21, 2008
    Thanks vm for you assistance, unfortunately I have just suffered a back strain but will persue your fix as soon as I have recovered.
Here's the fix: First, get out your old unit and examine it. You will see that there are essentially two elements in one assembly. Note that each element ends in a terminal on the old one but that two of the terminals are tied together. That is the common. On the new unit, simply tie one of the ends of an element to one of the ends of the other element with suitable wire. I suggest that you use the size wire that is used in the stove wiring to make the connection. If the wire is stranded, use the same type of wiring. Make up that pair of connections to the common wire. Now, note the type of element (some are concentric and there is a smaller inside one and larger outside. Match up the wires appropriately. If the configuration is not identical, don't worry. Just do one and one. Tighten all connections fully with the wires going clockwise around screws. If the connection will be wire-to-wire, use a bare section at least one and a half inches long and twist the wires along their length rather than make a pigtail. Tape from the middle to the end of the splice and then back over the whole of it and then back to the middle. You've done it!
Posted on Jan 20, 2008
Back L element no go
Feel free to download a copy of your wiring diagram from http://sparepartspro.zendesk.com/entries/118713-zanussi-electric-hob
Qualified Electricains only.
Feb 24, 2010 | Zanussi 23 in. ZKT641H Electric Cooktop
Burnt induction hob
hi my name is mark, you can try softscrub or a glass cook top cleaner made by jenn- air or a genaric brand from the supermarket.
Mar 01, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Wiring for Neff Hob-not supplied/no wiring instructions
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
Nov 28, 2008 | Neff T1323 Electric Cooktop
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Burner/Flame
Hiya .. this could be due to a number of problems...... has the burner ever worked correctly?
Is the behaviour with only one ring?
1. If not... then it could be that the pipework to the hob itself has not been recuced sufficiently enough in pipe diameter to the regulator far enough back ...
2.The regulator is faulty... in which case it can be replaced... however consider the cost of a new regulator and labour to fix it .. against the cost of a whole new hob... which should include a regulator. Is the hob still under warranty... if so use that .. but you will normally have to provide some proof it has been fitted by someone suitably qualified.
3.the regulator may never have been fitted, which is dangerous and bad practice.
Either of these scenarios... please ensure that you use a suitably qualified gas engineeer... I dont wish to be alarmist... but gas leaks and faulty gas appliances do cause unnecessary deaths...and is a silent killer.
Regards Faggly
Mar 26, 2008 | Maytag MGC5430 Gas Cooktop
Only 2 hobs work
this is almost certainly a wiring issue at the mains connection block, there are links which have not been tightened down. there is usually a diagram adjacent to mains block telling you what to do. connection block is covered by a plate. take plate off and tighten all terminals making sure links have been inserted. switch of at mains of course
Jun 06, 2007 | Zanussi 23 in. ZKT641H Electric Cooktop
Cooktops Logo
1,276 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
