Question about HP zv5160US Notebook
Memory Sockets Where are the two memory sockets for the HP Pavilion zv5160us located?
  • 1 more comment
  • DavidO08 Jan 21, 2008
    The manual you indicated was not for the HP Pavilion 5160us. My laptop is not a Compaq, thanks for trying. I know of the underside compartment, but it only contains a single socket. I don't know where the other socket is located. I had already replaced the 512 factory installed RAM with a 1GB, but now I want to max the RAM with 2GB. Thanks again.
    I knew of the underside compartment. I also knew of the possibility of a socket being underneath the keyboard. Unfortunatley, the manual in the HP website does not resemble zv5160us but of a compaq. I finally found the manual that resembles my laptop and was able to access the socket underneath the keyboard. I was able to upgrade the memory to the max of 2GB. Thanks for trying.
  • mac7ac Feb 09, 2008
    looking for manual on removing keyboard for zv5160us model. The link to the manual is for a compaq.
The following link provides the manual for dissembly of the zv5160us.
On the bottom back of the computer I removed the three screws that holds the strip cover on just like it says on page 5-30. I flipped the computer over and with the help of a small flat blade screwdriver I popped the Strip Cover off. NOTE: Tilt the screen to be horizontally flat (wide open, screen facing upward) with the main body of the computer to allow the three cowl-like hindge cover to free up as you are popping off the Strip Cover. Once the Strip Cover is off you can see the four screws that hold on the keyboard. Remove the four screws ten the keyboard lifts up very easily and then you can see the main memory socket.
Don Alford
Posted on Mar 04, 2009
    Problem Solver:
  • 14 Answers
On this laptop there should be a small door on the bottom of the laptop that has one very small screw in it. It is usually in the center of the laptop. If it is not there then you will need to check out the manual listed above because they will be under the keyboard.
Posted on Jan 21, 2008
  • 196 Answers
The manual is here:
See page 4-14.
Posted on Jan 20, 2008
  • Hugh Vandervoort
    Hugh Vandervoort Jan 21, 2008
    That is the manual listed by HP (HP bought Compaq a few years ago).
    Try this page, where they may provide more info on model numbers.
New memory stick 4 gb doesn't work
you cant do that. memory is always in PAIRS. The sockets are Colour Coded for each PAIR. two blue two black. the largest may need to be 1st Pair. suggestion: take all 4 out. put 2 largest back in as 1st pair see if pc is ok. then add 2nd pair. see if ok.
Dec 20, 2017 | MSI Hp Iona-gl8e Oem Motherboard Ms-7613...
I want to increase the memory ram of my lap top: HP pavilion ze4910us What kind and how much memory can I install ?
You can upgrade, have a look at the specs;
Pavilion ze4910us Memory Specifications Standard Memory 512 MB (removable) Maximum Memory 1.0 GB Memory Expansion 2 sockets Memory Comments PC2100/2700 DDR SDRAM SODIMMs CPU Type 1.4GHz Intel Celeron M 330 Model Comments 400MHz FSB Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop, the HewlettPackard Pavilion ze4910us Laptop takes the PC2100/2700 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your HewlettPackard Pavilion ze4910us Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop.
Hope that helps.
Dec 15, 2010 | Computers & Internet
I have an HP Pavilion 7850. I only use it for old programs and printers and scanners. I would like to add some memory, ie 256 to 512. How can I tell what the max memory is for my computer. I use MS...
Pavilion 7850 Memory Specifications Standard Memory 128 MB (removable) Maximum Memory 512 MB Memory Expansion 2 sockets Memory Comments PC100 SDRAM DIMMs CPU Type 933MHz Intel Pentium III Model Comments 133MHz FSB
Aug 26, 2010 | HP Pavilion 7850C PC Desktop
Where is the 2nd memory slot for the HP zv5160us laptop located and can the laptop handle 2GB of RAM
There is one external memory slot that is on the bottom of the laptop and then the second one is internal located under the keyboard.
Here is a link to the HP maintenance manual:
HP does this for a lot of models, kinda stupid if you ask me.
Apr 14, 2010 | HP zv5160US Notebook
Whether DDR is compatible for hp pavilion dv1000 or only sdram is compatible. With which ram can i upgrade.
According to the maintenance manual only 266Mhz Ram can be added to the notebook.
This would be SDRAM.
Hope this helps!!
Kind regards!!!
Jan 06, 2010 | HP Pavilion dv1000 Notebook
What is the maximum memory for this computer?
This computer (HP Pavilion a620n) has 2 x 184-pin DDR DIMM sockets and supports up to a maximum 2 GB of memory. It supports unbuffered PC2700/2100 non-ECC DDR SDRAM memory. (Also known as DDR333 and DDR2100 respectively)
Oct 27, 2009 | HP Pavilion a620n (PC028A) PC Desktop
Does not recognize all of installed memory ??
check that the installed memory cards are properly and securely located in their sockets. Also check that you have installed the correct specification of memory cards
Jul 16, 2009 | HP Pavilion ze2000 Notebook
What is the ram limit of HP Pavilion 061 DW234A-ABA A530N I have two sticks of kingston 512 in it right now but want to put in two sticks of 1 GB each. Can I? Nvidia 7800 GS OC with 500 watt power supply,...
From the HP specifications page for Pavillion A530N:
Memory type DDR Memory speed PC 3200/2700/2100/1600 Memory sockets Two DDR DIMMs (184-pin) Maximum HP/Compaq approved memory Two x 512 MB DDR-DIMMS, 1024 MB total (1 GB)
Mar 10, 2009 | ASUS Computers & Internet
You will need to purchase SDRAM (which is the RAM / Interface Type)
and installation is quite simple
Use the following steps to insert a memory module into an empty socket:
The memory configuration of channel A (the first two sockets) and channel B (the second two sockets) must be identical.
Align the memory module so the small notches on the lower edge line up with the raised marks in the socket.
  2. Push straight down on top ends of the memory module until the memory module is fully seated in the socket. The retaining clips on the ends of the socket lock into place when properly seated.
Aug 25, 2008 | HP Computers & Internet
Computer memory upgrade
Standard Memory 256 MB (removable) Maximum Memory 2.0 GB Memory Expansion 2 sockets Memory Comments PC3200 DDR SDRAM DIMMs CPU Type 1.6GHz Intel Pentium 4 Model Comments 400MHz FSB
- Always believe HP - its there product - Staples is not the manufacture.
Jul 22, 2008 | Computers & Internet
HP zv5160US Notebook Logo
132 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
