Question about Sony STR-DE545 Receiver
Reduced audio output from right channel
My Sony STR-DE545 receiver's right channel, both front and back, A and B, started outputting audio @ less then half of what the left channel does. Does anyone have any idea on what could be causing this?
  • plplayer Jan 20, 2008
    Thanks. I tried turning it off over night but it still has the same problem. Even took it apart and didn't notice anything unusual, with the exception I hear it click when it is running. I guess after 8 years its time for a replacement.
    Scholar:
  • 67 Answers
Try lightly tapping on chassis to see if you can get audio to cut on or off with vibration if you can most likely cause is bad solder connections. This unit is well known for poor solder connections especially around poweramp driver IC's IC701, IC501. Also Electrolytic Capacitors in unit have fluid in them and heat Evaporates the fluid causing them to not operate properly over time . Caps that usually go bad are around parts that run hot like Power amp drivers
Just a couple likely suspects.
Try unplugging overnight to give unit a Good Reset also double check all setup settings.
If you need service manual I may be able to get you one
kstahl65@att.net
Posted on Jan 20, 2008
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
The receiver works ok until the vol is reduced and the right front channel drops out. Increasing the vol usually picks up the dead speaker but it drops out again when the vol is reduced. I've tried...
Make sure the audio level on the left and right channels are balanced. Check the menu for audio levels to adjust and make sure they are not maladjusted. If all levels are adjusted properly then the volume control or volume control circuity may be at fault.
Jun 27, 2010 | Sony STR-DE685 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Question about Sony STR-DE595
NO! It uses the same amps for a and b channels. and you could short it out if its wirer improperly.
Dec 17, 2009 | Sony STR-DE595 Receiver
Optical digital cable connection ?
It only works through DVD setting
Jun 20, 2009 | Sony STR-DE545 Receiver
Right audio channel not working
Most likely it's due to bad solder for the Blue Relays.It can be fixed by re-soldering.
Apr 04, 2008 | Sony STR-DE545 Receiver
The Output Volume Is Extremely Low!
Sometimes the rear channels can be used as a 2nd zone. Does the unit have A&B speaker selection on front panel? Usually if it has a 2nd zone it will say in owerns manual or on back of unit or on front panel as well. That is when you have the option to adjust the volume in the menu on the 2nd zone. GURU JAY
Feb 07, 2008 | Sony STR-DE545 Receiver
Problem with 'central' speaker output
took apart my reciever and found that the blue relays in back in the middle are starting to malfunction. I tapped on them and they clicked. When I tapped the right one, i got the sound back in my center speaker.
Oct 30, 2007 | Sony STR-DE545 Receiver
Sony STR DE485 (Audio Video Reciever)
Your problem must be caused by the right channel (rear, front whatever..)side feeding resistor on the power supply.
May 05, 2007 | Sony STR-DE485 Receiver
Sony STR-DE545 Receiver Logo
116 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
