Question about Tally T6218 Matrix Printer
Print stops after 2 pages !
Today we bought a new Tally T6218 printer, prints finr, but it stops after every 2 pages of printing. Then I need to bring it into offline and online, it prints 2 more pages and stops. Can somebody help...
Baiju, Dubai
Hi my tally printer 6218 giving Ribbon motion fault, what could be done to remedy this error message ?
Posted on Aug 21, 2008
My printer goes 2-3 pages and then stops and waits then starts up again. After 30-40 pages I get a shuttle fault error .
Posted on Oct 01, 2008
  • 118 Answers
Try installing USB latest drivers
if it is a USB printer
Posted on Jan 20, 2008
6ya staff
SOURCE:
Tally t6218 prints and stops with no errors
The power supplies are known for shutting the printer down without any error if that is the symptom, replace the power supply.
TALLYGEN 084435 POWER SUPPLY ASSY T6218 Refurbished
If not let me know exactly what it is doing.
Dec 28, 2015 | Tally T6218 Matrix Printer
Tally Printer the error is some times Hammer
In the T6215 Maintenance Manual the fault message: Hammer Voltage has been replaced, in the T6218, with:
Hammer Voltage 1
There is a new fault message for the T6218. It is:
Hammer Voltage 2
Explanation: A high resistance coil fault has likely occurred in one or more of the hammer coils
Note: This fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Corrective Action:
Check the hammer bank for defective hammer coils.
Confirm that hammer drive board is functioning properly.
Apr 05, 2010 | Tally T6218 Matrix Printer
Using ASCII commands form IBM INFOPRINT to Tally T6218
I used escape sequence: <esc>(w
this instructs the printer to use Canadian Englis font page
Nov 13, 2009 | Tally LJ Series T6218 LJ Matrix Printer
Printing not clear (its so Blur)
Perform these operations:
  • Test->Diag->Clear->NVRAM
  • Test->Diag->Clear->CalData
  • Then re-calibrate the printer.
Procedures:
  1. Turn ON the Tech Access feature (hold ENTER and LINE FEED keys depressed approx. 5 seconds - until printer "beeps")
  2. Turn ON the Fault Override feature (hold ENTER and FORM FEED keys depressed approx. 5 seconds - until printer "beeps")
  3. Press the MENU key then UP Arrow to Offline - Test Menu
  4. Press ENTER then UP Arrow to Test Menu - Diag
  5. Press ENTER then UP Arrow to Diag - Calibrations
  6. Press ENTER then UP Arrow to Calibrations - Print Engine Cal
  7. Press ENTER and follow the instructions on the display
  8. Turn OFF the Fault Override feature by holding the ENTER and FORM FEED keys depressed until the printer "beeps"
  9. Turn OFF the Tech Access feature by holding the ENTER and LINE FEED keys depressed until the printer "beeps"
Mar 18, 2009 | Tally T6218 Matrix Printer
How do I clear a "config 1" error on my tally t6218 printer
Click start>run>type services.msc. The services window will come up and you can right-click on the Print Spooler and then click Restart. This will clear the print queue and hopefully allow you to print. Good Luck. Let me know if you have any questions.
Feb 28, 2009 | Tally T6218 Matrix Printer
Platen open error message on tally t6218 line printer
there are two reason behind the problem . 1 .the problem may come from the logic board.
2.and the platen sensor. change the platen sensor. if not solved change the board.
Sep 16, 2008 | Tally T6218 Matrix Printer
Error in eject page
dont use LF use FF to forward a form. if you use LF then set the topper form again.
Feb 03, 2008 | Tally T6218 Matrix Printer
Hammer voltage 2
it prints for about two minutes then starts slowing down and then stops printing showing an error of : hammer voltage 2
Sep 05, 2007 | Tally T6218 Matrix Printer
Tally t2280 does not recognise the page breaks.
self test not printing & printer is offline mode
May 30, 2007 | Tally Matrix T2280 Printer
Printer problem
on photos, If you have a laser printer with half a meg of RAM and you try and print a full page graphic at 300dpi you only get half a page because the printer runs out of RAM. You can get a full page by printing at 150dpi. could also be that the encoder strip has become fogged with aerosol, and needs gentle cleaning. Good luck
Mar 25, 2006 | Dell Inkjet 720 Printer
Tally T6218 Matrix Printer Logo
556 people viewed this question
Top Tally Office Equipment & Supplies Experts
Thomas F. Schneider
CheckitRight
CheckitRight
Clive
Clive
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
