Question about Dell Dimension 8300 PC Desktop
Hallo? when i start the computer i'll hear the fan sound turning only without any displaying on the screen plz help
  • Anonymous Jul 15, 2008
    The fan starts up loud, but nothing comes up on the screen.
    Problem Solver:
  • 42 Answers
It sounds like there is a dirty in you RAM Cards. I suggest you do this.......................
  • Remove RAM Card(s) from their slots and clean them
  • Then plug the Cards back to the slots
  • Make sure they fit well into their slots
Try that and let me know thw proceedings.
Cheers....................
Posted on Jan 19, 2008
HP TouchSmart 310-1125f display is black
Hearing fans and hard drive spin up doesn't necessarily mean system is working - just without video. If you heard a POST beep or the Windows Startup sound that would be different - and good. Is there any video on the screen at all, even just a blinking cursor in upper left of display? If not, your problem is probably hardware such as ram or motherboard. If this system has a VGA or HDMI output to connect to another monitor or TV would be a good check, but AIO system usually don't have that option. Other than that, and this is a shot in the dark: Ensure the system is off, disconnect the power plug, and hold the power button in for 30 sec for a power reset. Then plug in system and try powering it up again. If no go, you may have a hardware problem and will need a PC Tech. Hopefully it is just loose ram.
Apr 08, 2015 | HP Touchsmart 310-1125f Windows 7 4gb Ram...
Blank screen
sounds like you have a bad lcd screen, try and hook it up to an external monitor and if you get display you need a new screen.
Aug 16, 2013 | Fujitsu Siemens Computers & Internet
Dell Latitude D830 running Windows 7. Also running laptop screen plus additional monitor. I was watching a visor from cnbc.com when the addt'l monitor went blank and the laptop screen went a broken...
Hallo there
I hope you have got your screen beack, if not try to restart your computer in safe mode.
The restarting can be done in the following way:
1. Click START, click TURN OFF COMPUTER, and then click RESTART
2. While the computer is starting, press and hold down the F8 key until the Startup Menu appears
3 Use the UP ARROW and DOWN ARROW to select Safe Mode, press ENTER.
Now to the display settings
1 Open Display Properties in Control Panel
2 Click the Settings tab
3 If for some reason you are not in safe mode go through following:
In Colour quality, clock to alower settiing
Move Screen Resolution slider to the left if you want to reducethe size of the desktop
To Refresh frequency click Advanced and check the Adapter and Monitor.
4 After you have made your changes click OK
restart the computer if you are told to do so. But do not do it in safe mode..
Good luck
Kobrun
Feb 29, 2012 | Dell Computers & Internet
Sir i have a problem with my CPU it can power up but there is no display fan run good i mean all fan run fine and hard drive i can hear it is spining.. i try a other procesor and video card also a 512RAM...
You'll first want to make sure that BIOS would load. Turn the MB on with only the memory chips, video card, and CPU (with fans). You'll need to add/remove individual components to isolate the issue. Make sure that the cases's wires are connected to the correct pins on the MB.
Jul 18, 2011 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
A sound appears to be coming from my computer but i hear nothing.how can i fix it?
Since you reference "appears", you might be referencing seeing your volume display showing sound emitting. That would probably be either your microphone is turned on and it's picking up noises, sounds, ambiance.
Or you might have a device plugged in or connected via Bluetooth that is emitting audio.
Or you might be hearing the hard drive spin occasionally while other times it is idle. In addition, your power supply fan will turn on when you start up your computer. Some fans will automatically turn off if the power supply is cool enough.
Nov 24, 2010 | Computers & Internet
Need help for Acer Aspire ONE MODEL # ZG5 screen does not work?My Acer Aspire ONE MODEL # ZG5 notebook is show that the power is on, but the screen is black. I can hear the computer running, but there is...
If you are sure the computer is running then connect an external monitor to the laptop. You will have to select the external using your Function keys FN + F7 or F8. If you can now see your machine on the external monitor then you know it's the screen portion of your laptop that is faulty. If this does not work then the sounds you are hereing are probably just the fan and the hard drive spinning. These are not an indication that the computer is working. All in all, I would say that the laptop needs to see a pro.
Mar 26, 2009 | Acer Aspire One PC Notebook
Black screen on compaq presario v5000
the very first thing that u can try is that try it with the different ac adaptor and the battery and try it with the differnt ac aaaadaptor and still it doesnt then wahat u said is that u can hear the sound of the fan and the disk is trying to read but u cannnot see anything on the screen adn all u need to clearify is that if the computer is actually running or not and if it is working then what u can do is that connect the external monitor and then try and turn on the laptop and if u get a good display in te external monitor then definately replace the lcd screen and also what u can try is that try and reboot the computer in the safe mode and if turns on and u can see the display in the screen then do the system restore and it will be fine.......and as u said that u get a choppy sound from the fan then what u can do is that try and clean the fan from the back or by opening it......anbd it will not get any sound from the fan......good luck....
Jan 25, 2009 | Compaq Evo N610C Notebook
Can u help plz?
Check the screen connections.If you have a graphics card in your PCI Exspress slot then your screen will be pluged into it ,remove the graphics card and plug it into the defult motherboard socket.Turn on . If you have a spare screen around plug it in and test. Test all of these ,depending on the results of any one of the solutions will i know the problem.
Jan 19, 2008 | Dell Dimension 8300 PC Desktop
Hi?
your RAM is not working.. open the cabinet clean the RAM and insert it again...
Dell Dimension 8300 PC Desktop Logo
35 people viewed this question
Alun Cox
