Question about Samsung YP-K3 MP3 Player
I could not open my unit
The only thing I see in the lcd is the unlock sign that is flashing
  • 70 Answers
Please rephrase the question. From your post I cannot work out what the problem is.
Posted on Jan 21, 2008
Pattern lock
my samsung galaxy Ace Gt-S5830i swipe scree to unlock (draw pattern) google account is not opened failed pls help
Jun 19, 2013 | Samsung Galaxy Y Pro B5510 White Unlocked...
I like to upgrade my pnone 1110i,what will i do?by using a codes?
hi,
you cannot upgrade it by just using a code...but i will teach you how to upgrade it to higher unit ,2310...
you need this tool and gadget..
1).1110i fbus cable
2)jaf box
3.)2310 flash file
4.)pm files of 2310
5.)2310 lcd
procedure..
a)open jaf interface
b)connect the phone to jaf box
c.)select dct4
d.)thick check
e) if the phone is connected put MCU ,PPM,CNT of 2310
f.)flash the phone
g.)write 2310 pm
h.)after flashing ,the phone is in contact service status ,dont worry
i)just unlock the phone..
j.)replace the LCD (glass display) and now you have 2310 colored phone..
if you have no gadget that i have mentioned above ,dont try this..i hope it will help you..thanks
Jun 19, 2010 | Nokia 1110i Cellular Phone
Power led flashing on dell E172FPB monitor
The fact this is a LCd or at least listed as a LCD there are a few porbable causes to a faulure,
1. Bent pins
2. Bad signal cable
3. Bad back light (take a flash light point it at the screen if you see the screen change the backlight)
4. Bad signal board (rare)
please do be considerate and check these things in the list please to leace postive feedback and ratings for any expert that tried to help you.
May 26, 2010 | BenQ FP731 17" LCD Monitor
Sign comes up "osd Main controls locked" then a few seconds later "osd Main controls unlocked". I can carry on working behind the signs as they flash on and off but it's really irritating! i can't find...
guest, Problem may exist internally on the units "switch-mode-power-supply/ccfl inverter supply printed circuit board. When very, very STRANGE things start to show-up on the lcd screen that shouldn't be there, the first place I as a technician would look would be the SMPS/CCFL inverter board. If your unit acts same way when connected to different pc, or if a "known good" monitor works well with your pc, then you will need to have unit serviced by a cold-cathode-fluorescent lamp back-lit lcd monitor technician! It's that or you will need to visit YOUTUBE and see if DIY repair is in your future. Do some reading in my or "buddymc" , "budmrtn" and other techs fixya profiles here on fixya for more info. Above all else, remember this!!! Your CCFL back-lit lcd monitor isn't any different than any other brand in it's basic design and operation!!! Just do some reading to understand why so many lcd monitors fail in the field. If this response has been of some use then do a return comment so all other users can read it. Bye for now. 12fixlouie
May 19, 2010 | Philips 150S4FB 15" LCD Monitor
Locked door
Just inside the door but on the oven is a button. My husband pressed it and held it down while sliding the (center) lock to the left. That unlocked it.
Dec 31, 2008 | Ovens
Flash will not atomatically flash/can't change flash setting
Do you see any flash error code on lcd screen? if no then...
Flash will work when camera will set on auto mode ( green mark on jog dial) and you will see flash icon on lcd screen.
Dec 12, 2008 | Cameras
Need code to unlock kenwood kdc-x679
Leave unplugged for a few days or open unit and look for button battery and pull it out for a few seconds. If board has permanent type battery (soldered) you can try and unsolder it and resolder it again. The unit requires some sort of power to remember these things unless it uses a flash memory, but that is doubtful.
Mar 03, 2008 | Audio Players & Recorders
Child lock?
press and hold the power button on the unit for 5 to 10 seconds
Jan 22, 2008 | Audio Players & Recorders
Lcd backlight blown, poss. capacitor?
the flash capacitor witch stays charged for days even when your camera off has very high voltage on it and probably arched over into more that just blowing your lcd screen.
only thing I would do is junk it or buy one on ebay with minor problems and start repalcing boards, get some fine jewlers philips screwdrives and small flat, and be very careful. I wouldnt try to replace any surface mounted componets.
Jan 16, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
My new Hitachi LCD L32H01U
If you know just a little about electronics I can suggest several things. If not you'll need a tech...
Forst check F901 in the power supply, if it's open replace it and D902. If not open, check R964 for broken solder connections. The power supply in this unit is very commonly the culprit of a dead unit as you're describing... It's not usually an expensive repair for a qualified shop if any of this sounds a bit beyond you...
Take care Juliet and let me know how it turns out.
Bill
Nov 15, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Samsung YP-K3 MP3 Player Logo
26 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
