Question about Dryers
Hotpoint Condenser Dryer Model CDT00
My dryer has stopped heating up and is not drying any clothes, I have cleaned the condenser and fluff filter and the water tank is empty. The dryer is only 13 mths old. Can you help please?
  • 4 more comments
  • Anonymous Feb 11, 2008
    My hotpoint dryer is not heating up and i regularly empty the water container and keep the filters clean. The company can offer no advice until a service agent sees it at a cost of 116 euros.
  • andy smithson Aug 10, 2008
    i have a cdtoo i have replaced the 2 sensors at the back and a new element and it still does not get hot what else can it be
    i have bought 2 new sensors and the element and the ctd00 still does not get hot
  • ramone123 Oct 15, 2008
  • Anonymous Mar 29, 2014
    My husband removed the control panel on my hotpoint condenser dryer model number TCEM80C6P(UK) and cant remember which wire goes where
  • Anonymous Mar 30, 2014
    the water reservoir is empty the power is on but will not start fluff cleaned and condenser cleaned
  • 139 Answers
Either your heater is blow or your thermal cut outs are blown easy to check and replace ...
The are located at the back of the dryer behind the protuding funny shaped panel...
Check the continuity on the t-stats if no present then replace both of them small round things
then its the heater....
Posted on Jan 21, 2008
Doesn't dry
Drying consists of removing moisture through heat and airflow. Check to make sure that your venting tube is not kinked somewhere and therefore not allowing the air to flow freely from the dryer.
Apr 11, 2014 | AEG T57800 Electric Dryer
Hotpoint ultima tumble dryer
sounds like its blocked with fluff somewhere and your element could be wet take off the back and check your element and if water around it you need to compleatly clean out your filters and down where the condenser is then leave it for a day or two to compleatly dry the element
Apr 07, 2014 | Hotpoint 1701746 Ultima Tc71n Condenser...
Hi i have a hotpoint tcm condenser dryer and dosnt seem to dry my clothes anymore?
You need to clean all the fluff out of the dryer, the heat exchanger gets fluffed up, the fan gets fluffed up.I am assuming that the dryer is getting hot?
Mar 05, 2011 | Dryers
Wd440 not drying. how does the fluff get emptied?
Because it is a washer dryer, there is no fluff filter to clean.
It is self cleaning, because the fluff is washed away by cold water entering the condenser and flushing the fluff away.
Trust this answers your query.
Please rate my solution.
Jan 25, 2010 | Hotpoint Washing Machines
Hotpoint WD440 creases clothes badly & takes ages to dry
This sounds like excess steam in the drum. Check that the drain filter is clean as washer driers rely on cold water being taken in to cool the condenser tank during the drying cycle. If the filter is clear, the tank may be blocked with fluff. You have to open the machine a look for a big plastic tank, usually down the right hand side.
Dec 11, 2009 | Hotpoint Ariston WD440G Front Load...
If the clothes are coming out hot and steaming, then the water from the clothes is not condensing, it could be a blocked condenser, which will have to be removed and unblocked and cleaned.
The other possibility is that there is no cold water coming in on the drying cycle, this can also have the same effect.
Hope this helps.
Dec 03, 2009 | Hotpoint Washing Machines
Hotpoint tdc 30 not getting hot enough to dry
Remove and clean all filters, and make sure you have the correct heat setting selected
P[lease rate my solution.
Nov 15, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint condenser dryer CDT00
how to connect the dryer belt to the motor is there is two pullys.
Mar 30, 2008 | Dryers
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Dryer does not dry clothes
On the top of the heater box there is a thermal fuse that blows if the dryer overheats, on this model it could occur if the air circulation fan is faulty, or the condenser valve is faulty, alternatively the sump hose filter may be blocked, only a closer inspection of these items will determin which the problem is.
Nov 13, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Dryers Logo
719 people viewed this question
Top Dryers Experts
