Question about NEC LT 17u 17" LCD Monitor
Display PIN settings
In an accident the display cabel was damaged and lost.
need the 15 pin display connecter setting/diagram to reconnect the same
please let me know on
romesh.sampat@gmail.com
or
+919892980900
  • romesh Jan 21, 2008
    take 15pin connecter 2 nos and cable wire to make cable
    make wireing 1 to 1
    yourr cable will be redy
    ashok
    Ans:-did not work as the other end is shouldered/directly connected in the LCD ....
    need the pin setting digram for NEC LT 17u
  • 23 Answers
Take 15pin connecter 2 nos and cable wire to make cable
make wireing 1 to 1
ashok
Posted on Jan 21, 2008
How to concert laptop to tv
what do you mean by concert, Do you mean connect?
If you do then you will need a 15 pin to 15 pin vga lead. Connect it to the 15 pin socket on the laptop, connect the other end to the tv's 15 pin socket if it has one. Then select PC on the tv's input source menu using the tv remote. Switch on the laptop and it should display on the tv.
May 06, 2012 | LG Computers & Internet
No display
hi friend...!!!!!!
there are some steps which you need to follow..
1) you need to clean your ram with blank white paper..
2)you need to disconnect all your power connections which is attach with harddisk, cd drive, 24 or 20 pin connector and 4 pin display connector on yourmotherboard every connection which is form S.M.P.S.. reconnect all connections.
3)reconnect your C.M.O.S battery which is on motherboard..
hope your problem solved
if you find this is helpful for you so please rate me this will encourage me todo more free work..
regards'
sandy
Sep 05, 2011 | Intel D945GCCR Motherboard
Hi guys. i hav an acer ac713 crt monitor. the cable that connects the monitor to the tower/hardrive has been cut by burglars. where can i find a wiring diagram to fix it? thanx.
in 15pin connector of the monitor,
red wire goes to pin No:1
green wire goes to pin no:2
blue wire goes to pin no:3
yellow wire goes to pin no:13
white wire goes to pin no:14
and black wire goes to 5&15. Now display will come!
Sep 08, 2010 | Acer AC713 17" CRT Monitor
Out of range message
This is caused by a resolution and/or refresh frequency setting in your computer's display properties that exceeds the values supported by the monitor.
Find out the optimum (native) resolution of your monitor (in case of AMV 17V5 it will be 1280x1024 pixels), and supported refresh frequency (usually 60Hz for LCD monitors), and set your display properties to these values.
Nov 23, 2009 | Amptron AMV 17V5 17" LCD Flat Panel...
DVD is playing but you don't see it on the tv . Do I have to put TV on a certain channel while playing DVD?
pls check dvd AV cabel .
if ok
then
playing dvd first and see dvd back side pin .
VIDEO OUT
after see on your dvd remot cantrol and check interface key if yes then use key to set display on screen S-VIDEO and see the picture is normal .
if not then.....
pls see the dvd back side
GY /BU /RV three pin
pls video out pin is plugge out and concting with step by step in all three pin
if sum picture on screen pls. canect and hold .
after that use dvd remot cantrol and selact SETUP key to on and see and open video interface menu pls set video system is select S_video.
after that reconact video pin is VIDEO_OUT and see picture is normal .
Oct 08, 2009 | Panasonic DMR-E75V DVD Player/VCR
Shrinking of the display
The DB15 VGA (Video Graphics Array) connector contains however 15 pins in three rows of 5 pins each. These five pins carry the color and synchronisation signals, also a digital I2C interface for two-way communication between the video controller and monitor. The common 15-pin VGA connector found on most video cards, computer monitors, high definition televisions which support VGA connections. The following schematic diagram and table shows respectively connector and pin assignment of DB15 VGA.
Pin
Name
Function
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
5 VDC supply (fused)
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Aug 10, 2009 | SAMTRON 55V 15" CRT Monitor
I need a circuit diagram for My Logitech Z-640 Computer Speakers
You may have to call Logitech support or email to find out what the pin out is. that would be my only solution if there is one.
Mar 26, 2009 | Logitech Z-640 Computer Speakers
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
NTL D4000 Lost connection
Press and hold "PAGE" button on main base for at least 10 seconds green power light will flash. Within 30 seconds press "store" display shows "arrow in lopsided square" press 5 press 1 you will hear confirmation beep. Enter your Base PIN, 0000 is factory set pin. Press "store" to confirm.
Jul 14, 2008 | Lands Phones
NEC LT 17u 17" LCD Monitor Logo
87 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
