Question about Panasonic TH-42PD60U Television
Tv will not turn on
We have a Panasonic Digital Progressive Wide Plasma Television
Model # TH-42PD60U. that one night we turn it of went to bed and the next morning it will not turn on not even with the remote. please need to know what can i do get it to turn on again. I am very good with electronics. so please help
with something it will be mostly appreciated. thank you very much for your help.
sincerely yours
Fidel V Junior
  • goff307 Feb 11, 2009
    Hello, My tv has the same problem. I took the back cover off and replaced one of the fuses (T8AH) and followed the trouble shooting chart from panasonic web site. Check the voltages on different boards and the chart will tell you whats wrong. I now get 10 blinks so the PA or Tuner board gave me the s.o.s.I folled the chart and it said DG board. Yours could be different.
    Hope this helps
Had same problem, no turn on.
No blinks, by the way.
Checked fuses, everything is ok.
Had Panasonic tech check it, and he found that by disconnecting the DT (digital tuner) board, the system would "click".
He said $700 total to repair ($500 parts). I said no.
I got the TV to work, by unpluging and then pluging back the DT board WHILE POWER ON.
Now TV works, but if I turn the TV off I have to do the unplug plug sequence.
This is VERY DANGEROUS as there are high voltages in the TV, so I don't recommend it to anyone not trained.
My long term solution? Find a cheap DT board on ebay or WWW
Posted on May 11, 2009
I turn on my Panasonic TH-42PD60U Television - red LED blinks and there is a clicking noise but TV doesn't turn on.
Panasonic plasmas are notorious for their power board problems.
I can't know which one of the few possibilities yours might have, but at the very least it is worth checking against the most common ones(s):
http://www.coppelltvrepair.com/p/54/repair-kit-for-panasonic-th-42px60u-panasonic-th-42px600u-and-panasonic-th-42pd60u
Read the listing, get a multimeter and check the described components for short or open (in case of a fuse) and if it matches then that's the problem and that's the solution.
For in-depth troubleshooting help consider using www.coppelltvrepair.com/diagnose - it's free to ask, but we may not always be able or willing to help and when we do we'll typically put a price on a consultation.
Sep 30, 2012 | Panasonic TH-42PD60U Television
PANASONIC TH-42PD60U will not power on/no power light/have already replace power supply
If your power supply is new try to check the power cord..If you have a volt meter or multimeter range in AC..check the voltage input of your power supply it should have 110v to 240 volts depends on your electrical supply in your outlet..
If no voltage replace the power cord..Hope it helps..
Mar 06, 2012 | Panasonic TH-42PD60U Television
How i do tv chanel tunig
Hello Ansarielectr, The Panasonic TH-42PWD7 is a professional grade progressive wide screen plasma display. It's not your normal HDTV. You probably already know this. This display requires a component /composite video terminal Board that mounts to slots 1 & 2, or slots 2 & 3. The item number for this component is TY-42TM6Y and can be purchased through the Panasonic support website here for about $270. Once you have this component, you can connect the TH-42PWD7 to a digital HDTV cable box to receive signals. Just make sure you're on the right input signal. Hope this helps.
Dec 28, 2010 | Panasonic TH-42PWD7 42 in. EDTV-Ready...
Vertical line
replace the vertical ic chip
Feb 14, 2010 | Panasonic TH-42PX60U Television
Need Help.
Can you get the On-screen menu to come up using your remote?
Jan 07, 2010 | Panasonic TH-42PD60U Television
Panasonic plasma TV model TH-42PD60U won't turn on
I had this problem in 2007 / 2008 here is what happened to me. Jan 09, 2008 - I also have brought the unit to the authorized Panasonic repair facility and the problem is a failure in the P-board which is the power supply board. The P-board needs to be replaced. The repair will cost $475 plus tax. $250 is for labor. The unit was nop more than two months out of warranty. This does not speak well for Panasonic. I have been researching the problem and it looks like this has happened to many of the Panasonic plasma TVs.
Jun 14, 2008 - As an update to my problem with the failed P board. Contacted Panasonic Service and talked to a customer service representative. I told them how I have purchased many Panasonic products and how unhappy I was with the failure of the product. They proposed paying the labor cost of $250 and I would pay for the part. I just hope it does not happen again.
Oct 03, 2009 | Panasonic TH-42PX60U Television
Panasonic Plasma no sound, can't change channel
Yes the control board would definitely be the offender here. But a word of caution. Oftenj when this board goes 2 other boards are also compromised and not always obvious at the time people think they can just swap the board out.
It went for a reason, not just old age. So it is better and cheaper in the long run to get a professional to check it out.
Also from a safety aspect, this is the High Tension area of the TV. Also be aware that radiation of the X type is in abundance at the rear of the tube. The TV must be grounded when opening ( but my advice is dont!) Let the professional do it
Sep 18, 2009 | Panasonic TH-42PD60U Television
Panasonic TH-42PD60U Wont come on..
hello, I went to the Panasonic web site and it said driver sos3 (SS energy recovery circuit) on the SS board. call 1-800-211-7262
Sep 15, 2008 | Panasonic TH-42PD60U Television
No sound: Panasonic 50" plasma
This just happened to me - I called Panasonic. Turns out it was my digital cable box - I unplugged it, turned in back on, and the sound was back.
Apr 04, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Televison & Video Logo
921 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
