Trouble shooting for dv3250lcd display
No picture nosound no raster only on screen display working
  • Anonymous Feb 22, 2008
    no sound
  • Anonymous Jan 10, 2009
    same thing
  • 30 Answers
Yes, i agree with the Shuttle83. If you need the free schematic diagram or service manual, please feel free to go to the to get it.
Posted on Jan 20, 2008
  • 1,139 Answers
Hello raj ro,
The problem you have described is a possible problem in the RF/IF section before the video and audio are separated. I would check the tuner, and the signal into the IF/Video/Audio Processor. I say this because in most televisions now the IF, Video, and Audio are preprocessed through the same microprocessor with input from the tuner or some sort of amplifier after the tuner. Check the output of the processor to the various stages Video, Audio, Sync, etc. In addition to this check the DC bias voltages, and the signal waveforms on the processor also. This should lead you down the right path of solving this problem.
You will need:
  • a schematic diagram of the TV (To locate test points and signal)
  • a Digital Multimeter (To measure DC volts and test passive components)
  • an Oscilloscope (To measure waveforms)
  • a signal generator (To provide proper reference signals)
  • an Isolation AC power supply (To prevent shorting out the test equipment while testing the TV set)
These are the basic pieces of test equipment needed to do this type of troubleshooting.
If you do not feel you can do this please contact a qualified TV repair person to troubleshoot this problem.
I hope this helps
Thank you,
Can not even in the picture
Have you tried to press the display button? On the bottom from the left, the third button. When pressing this one you can cycle between normal screen, raster and off.
Nov 17, 2013 | Canon PowerShot SD100 / IXUS II Digital...
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from or from or from --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
Video problem
There is a power supply problem. Your sweep is working but I bet you that one of the supplies off of the sweep power supply went out. Probably due to a defective capacitor, or perhaps the convergence amps shorted and took out one of the supplies. You will need a service manual as well as a multimeter to trouble shoot this TV set Good Luck
Sep 18, 2007 | Toshiba 42H81 42" Rear Projection...
do you see anything on picture doesnt mean no raster ,raster mean anything that comes out in raster with sound only mean failure in either,connection in heater which means, loose connection or some new sets declare failure in vertical be more specific ok?
May 08, 2007 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony trinitron 32 in. pip no video, (raster, with audio)
What you have described there is a classic example of the jungle IC failure. Ic301 Sony p/n 8-752-101-04. A pic with no color, and lines or grainy texture in the picture. Not a project you want to tackle if you don't have the proper soldering equipment or skills. And not a costly one at a good repair shop.. Only real hurdle is getting that heavy monster into the shop. To answer your question, yes what you described there is raster. Even the salt & pepper looking screen with no real decernable image is described as raster. In fact any image generated on the CRT is raster. And yes, these sets are prone to solder joint problems, usually ring cracking in circuits that generate the most heat.
May 20, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Fuji f700
I recently had trouble with the LCD Display coming up with a black screen. So I mailed it to Fuji with a letter explaining the problem. About 3 weeks later I got it back in the mail and it seem to be working fine until a month later. I turned it on and the LCD display show a black screen only now it has white lines. I'm so incredible mad and extremely dissapointed in Fuji. Reading online I have notice many people having trouble with Fuji Products. I WILL NEVER BUY a Fuji again!!!
Jan 15, 2007 | Fuji FinePix F700 Digital Camera
Televison & Video Logo
300 people viewed this question
Top Televison & Video Experts
