Question about Aiwa NSX-A115 Shelf System
Volume The volume is very difficult, whenevern I try to turn it down it goes up, the only way i can adjust the volume is to turn the knob back and forth and i almost never can get it to turn down. When it does, if i keep turning it just goes right back up.
  • 3 Answers
Change the Volume Knob completely cos it's damaged, worn!!! ;)
Posted on Mar 10, 2009
    Problem Solver:
  • 9 Answers
Removed and replace potentiometer volume control.
Posted on Feb 19, 2008
Disssrm the control volume and clean it with alchol, but be extremely careful with the thin contact, are very delicated, after of this, re-assembly y test it. and now is working. I suggest do not desoldering from the front panel, because is not necessary.
Posted on Jan 20, 2008
    Sergeant:
  • 395 Answers
The volume control needs to be cleaned. this control is a step switch basicly. and the switch contacts are not making proper contact. cleaning this requires dis-assembly and desoldering so if you are inclined to do this work happy fixing if not it shouldn't cost much to fix.
Why could my volume knob be stuck on max volume and not adjusting?
There is probably grease or dirt on the contacts inside the unit. Here's a video that shows you how to fix it:
http://www.youtube.com/watch?v=y4XF9PoidJQ
Hope this helps!
Aug 08, 2014 | Marantz SR-4320 Receiver
The volume is too loud......#1 is too loud to hold a conversation in the car. How can I adjust the level???
Typically the left or right knob should adjust the volume by turning it counter-clockwise. However, some companies need to make this a bit more advanced or difficult. If this is the case, you can try pressing the audio button on the device. If it provides you with any options on the screen, search for anything which indicates changing the volume control. (It may also be under Menu)
Once you do that you should be able to turn the sound down with either the knob on the left or the arrows on the right.
Feb 21, 2011 | Blaupunkt Bahamas MP46 CD Player
The volume control does not go up or down when I turn the knob. I have to play around with it and sometimes it works and other times it dosen't.
On volume control potentiometer carbon layer wears out with time. The easiest way would be to clean it with spirit. Turn off the unit, remove the knob, spray spirit on volume control then turn the knob back and forth around a minute, should work after. Also you can disassemble CD player and resolder pot contacts on the board, when pressure constantly applied from outside, contacts get loosen. And the best way will be to replace the pot.
Oct 30, 2009 | Alpine CDM-7874 CD Player
Volume control knob on radio turns volume up at all times
first of all if you live in a cold climate I never turn the radio on until the car warms up if you can remove the knob on the radio spray a light amount of WD 40 and then put the knob back on and turn it back and forth and if you have pop on your hand or water also dry your hands off before touching the radio the lights and the radio will last a lot longer also and also before leaving the car always remember to turn the radio off it will be alot easier on your battery as well
Jan 05, 2009 | 1998 Pontiac Bonneville
Volume problem with VSX-D409
Had the same problem. I had to replace the volume contol. It was inside the receiver behind the knob. It has a part# on it. Mine was part# AWX7386 (control assembly) from Pioneer.com. If you can figure out how to open the case than you can change this piece. Good luck
Dec 23, 2008 | Pioneer VSX-D409
Volume control for model TXD1972
This may sound stupid but try this turn the volume knob to high and low continously for a few seconds sometimes the contacts become dirty and just a little movement back and forth quickly repairs it. I said SOMETIMES.
Sep 04, 2008 | Samsung TXD1972 19" TV
Volume knob quirks
if you know how to repair, then replace the volume control switch. it is a digital type/mechanical type of switch with silicone oil on it to prevent sudden turn of volume. if i were the repairman i can simply clean the contacts of the volume control and pour silicon oil again. but i really dont know in your area if they try to clean those.
May 03, 2008 | Yamaha RX-V1200 Receiver
Speaker noise
The contacts on the volume control (potentiometer) get oxidized over time on any analog rotary volume control. With the power off, crank the volume control back and forth real fast for a minute or two, this will do the most cleaning of the contacts that you can do without access to the insides. Ultimately you'll probably need to sprary some tuner wash/tuner cleaner or other electronic parts cleaner in the know (with the electricity disconnected) and then work the knob back and forth. Tuner wash bottles are available at electronic specialty stores or radio shack and usually have a long extension tube (like what comes with WD40). You might be surprised where you can reach with the extension tube.
Sep 01, 2007 | Boston Acoustics BA745 Computer Speakers
Volume knob
Normal Aiwa compact shelf units use what is called a jog switch for the volume. Usually you can tell the difference if when you you turn the volume up or down. It goes a short distance and seems to spring back. In this case there are two momentary contact switches. One for up one for down. With a plastic lever on the back of the knob that bumps the approriate switch whether turning down or up. If the lever is broken it will bump up against one but not the other. If it is broken plastic you know how good gluing plastic goes it never seems to hold.
Aug 02, 2006 | Aiwa NSX-A777 Shelf System
Aiwa NSX-A115 Shelf System Logo
527 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
