Question about Car Audio & Video
Hyundai lantra sedan car battery problem
Help - my parking lights will not turn off - and I just don't want a flat battery in the morning - have checked inside and everything seems right and off - what else should I check for please. Thank you in advance for your help.
  • dusta Jan 19, 2008
    would appreciate all the help I can get !! Thank you
  • 2,042 Answers
Maybe day light module broken look for day light module fuse or the module itself disconnect light should go off module on the side fender square box 3x2 imch with 5 or so wire connect to it good luck cheers
Posted on Jan 19, 2008
6ya staff
SOURCE:
Problems starting car
most likely a problem neutral or park switch or out of adjustment or loose
by moving the shift you are making it work so take it to an accredited service shop for a check/ repair
Sep 24, 2016 | Kia 2014 Forte EX sedan
Hyundai lantra motor diagram
Sounds like you have a issue with the starter .
Dec 24, 2014 | 1997 Hyundai Lantra
Hyundai lantra continues to stall as the clutch is depressed. and oil light turns on. i have no idea what is going on with it so any help would be muchly appreciated.
problem would seem to be in the running of engine ,when was it last serviced ,old plugs , air filter etc will affect engine idle speed which is why its stalling when dipping clutch
Mar 25, 2014 | Hyundai Elantra Cars & Trucks
How i can change spark plug seals in Hyundai lantra sports wagon
You must remove the valve cover as they are serviced on then.
Mar 19, 2014 | 2007 Hyundai Sonata Limited Sedan
1999 Hyundai Lantra runs and then wont start
Either a weak battery or a defective starter. Have you checked your battery voltage when it will not crank? Cleaned your battery terminals?
If you need further help, reach me via phone at https://www.6ya.com/expert/tom_1788908372a4836f
Jan 10, 2014 | Cars & Trucks
1997 Hyundai Lantra - Dash lights don't come on with headlights
Check the fuse. Also make sure your dimmer for the dash lights does is not turned all the way down. If all that checks out, your dimmer may be need replaced.
Oct 17, 2012 | Hyundai Lantra Cars & Trucks
I have a 2000 Honda Civic sedan. The radio quit first, then the wipers, then the lights, then everything. This happened before and it was loose battery cables. The cables are fine. Someone mentioned...
I would have the alternator checked. I would also have the battery checked because if the alternator is bad it could have caused the battery to go bad too. Most auto parts stores will do the testing for free, but you can check it yourself if you buy a voltmeter. I can help you with the testing if you need help.
Sep 21, 2011 | 2000 Honda Civic
Car Audio & Video Logo
127 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
