Question about Dell Dimension 8300 PC Desktop
Hi? when i start the computer i'll hear the fan sound turning only without any displaying on the screen plz help
    Guru:
  • 1,894 Answers
Your RAM is not working.. open the cabinet clean the RAM and insert it again...
Posted on Jan 19, 2008
HP TouchSmart 310-1125f display is black
Hearing fans and hard drive spin up doesn't necessarily mean system is working - just without video. If you heard a POST beep or the Windows Startup sound that would be different - and good. Is there any video on the screen at all, even just a blinking cursor in upper left of display? If not, your problem is probably hardware such as ram or motherboard. If this system has a VGA or HDMI output to connect to another monitor or TV would be a good check, but AIO system usually don't have that option. Other than that, and this is a shot in the dark: Ensure the system is off, disconnect the power plug, and hold the power button in for 30 sec for a power reset. Then plug in system and try powering it up again. If no go, you may have a hardware problem and will need a PC Tech. Hopefully it is just loose ram.
Apr 08, 2015 | HP Touchsmart 310-1125f Windows 7 4gb Ram...
Nx7400 black screen
back light problem
check led and inverter
Feb 22, 2014 | HP Compaq nx7400 Notebook
Sir i have a problem with my CPU it can power up but there is no display fan run good i mean all fan run fine and hard drive i can hear it is spining.. i try a other procesor and video card also a 512RAM...
You'll first want to make sure that BIOS would load. Turn the MB on with only the memory chips, video card, and CPU (with fans). You'll need to add/remove individual components to isolate the issue. Make sure that the cases's wires are connected to the correct pins on the MB.
Jul 18, 2011 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
HI, i have sony vaio laptop. few months ago i face the problem that my computer LCD light. after starting 2 or 3 times it show the screen. it is running every time. i can see dim screen but after 3 or 4...
In your situation, you have the possibility of several different problems.
1. Your "Screen Inverter" is failing.
2. Your screen "LCD Panel" is failing
3. The "Video Controller Chip" soldered permanently to your motherboard is failing.
The first step in troubleshooting these problems would be to take your laptop to a friend's house who is using a desktop computer with a separate external monitor. Hook your laptop up to the external monitor and see if it displays normally on that monitor. If it does, you merely need to replace both the Screen Inverter and LCD Panel of your laptop and you'll be fine.
If, however, your laptop will not display on an exterior monitor, it means that your video controller on your motherboard has failed and you'll have to either get a new motherboard installed or consider replacing your laptop.
I'll be rooting for # 1 or 2.
Kind Regards,
Selk
Apr 29, 2011 | Sony VAIO Notebook
Need help for Acer Aspire ONE MODEL # ZG5 screen does not work?My Acer Aspire ONE MODEL # ZG5 notebook is show that the power is on, but the screen is black. I can hear the computer running, but there is...
If you are sure the computer is running then connect an external monitor to the laptop. You will have to select the external using your Function keys FN + F7 or F8. If you can now see your machine on the external monitor then you know it's the screen portion of your laptop that is faulty. If this does not work then the sounds you are hereing are probably just the fan and the hard drive spinning. These are not an indication that the computer is working. All in all, I would say that the laptop needs to see a pro.
Mar 26, 2009 | Acer Aspire One PC Notebook
Black screen on compaq presario v5000
the very first thing that u can try is that try it with the different ac adaptor and the battery and try it with the differnt ac aaaadaptor and still it doesnt then wahat u said is that u can hear the sound of the fan and the disk is trying to read but u cannnot see anything on the screen adn all u need to clearify is that if the computer is actually running or not and if it is working then what u can do is that connect the external monitor and then try and turn on the laptop and if u get a good display in te external monitor then definately replace the lcd screen and also what u can try is that try and reboot the computer in the safe mode and if turns on and u can see the display in the screen then do the system restore and it will be fine.......and as u said that u get a choppy sound from the fan then what u can do is that try and clean the fan from the back or by opening it......anbd it will not get any sound from the fan......good luck....
Jan 25, 2009 | Compaq Evo N610C Notebook
Can u help plz?
Check the screen connections.If you have a graphics card in your PCI Exspress slot then your screen will be pluged into it ,remove the graphics card and plug it into the defult motherboard socket.Turn on . If you have a spare screen around plug it in and test. Test all of these ,depending on the results of any one of the solutions will i know the problem.
Jan 19, 2008 | Dell Dimension 8300 PC Desktop
Hallo?
It sounds like there is a dirty in you RAM Cards. I suggest you do this.......................
  • Remove RAM Card(s) from their slots and clean them
  • Then plug the Cards back to the slots
  • Make sure they fit well into their slots
Try that and let me know thw proceedings.
Cheers....................
P4vmm2 doesnt boot,Y?
Hi yansky, When you turn the computer on do you see or hear any of the following: -Does the power LED turn on and if so for how long? -When you turn you power on listen closely for any sounds like hard drives or fans starting up. -Does anything show on your monitor, if yes what exactly? -When turned on do you hear any beeping sounds from the computer? If you do listen for the pattern of long and short beeps and let us know what they are. If you see absolutely nothing you should try testing the socket the computer is plugged into. Fuses blow, power strips die cords develop shorts so unplug the computer and plug in a lamp to verify you?re getting power. If that doesn?t turn up anything let us know the answers to the questions above plus any other observations and we?ll try to help.
Jan 13, 2007 | EliteGroup P4VMM2 Motherboard
Dell Dimension 8300 PC Desktop Logo
49 people viewed this question
Alun Cox
