Question about HP Color LaserJet 3500 Printer
59.0A error in hp color laserjet 3700
Can u find exactly what spares gone
  • jaimon Jan 19, 2008
    error code is 59.A0 , if i switch off the printer for one day again it will print 2 or 3 pages the its give the error. i channged all the accessories like tuner transfer unit and fuser still the problem persist. can u tell me in 3700 which is the main moton and locatted. pls help.
    error code in 3700 59.A0 i changed all the toners , fuser and tranfer unit. still the problem is same.but i am printing after 1 or 2 days again it will print for 2 or 3 pages. then its starts problem the same error.pls suggest me to solve the problem.
    can u tell me reg main motor pls.
  • 417 Answers
Hi there the following is the normal description hope it helps.
59.X PRINTER ERROR A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error 1. Turn the printer off, and then turn the printer on. 2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train. 3. Check the main motor’s cable to ensure that it is seated properly. 4. If the error persists, replace the main motor.
Thanks J
Posted on Jan 19, 2008
  • Jason Collin
    Jason Collin Jan 19, 2008
    Hi there you will need to replace the main follow the site below then you will be able to get the part number and replace.
    Thanks J
    http://partsurfer.hp.com/
    Problem Solver:
  • 17 Answers
All 59.XX error codes have to do with a motor failure of some type. I don't know anything specific about 59.0A but 59.A0 means that either the drum motor failed to start or something bad happened while it was rotating. If you feel like tackling it yourself you can try reseating all the connections to the drum motor and the DC controller board. Other possibilities could be a bad drum motor or a bad DC controller. HP says you can also get this message when the tranfer unit is missing or improperly installed.
If you don't feel like tackling it yourself then it's off to a repair shop unless it's under warranty, in that case call HP.
  • Richard Lightfoot Jan 19, 2008
    After seeing your second comment I would definitely inspect and try reseating the transfer unit and check any gear train associated with it.
By Jiwan Sharma
When switch on my HP laser jet 3700, Its motor just move and stop. The shows error 13.20.00. (Front door paper Jam) I followed the procedures to remove the media jam and media sensor jam. I did not find any paper in the paper path, but still the problem persist. Kindly give me some solution.
Posted on Apr 03, 2008
55.00.00 error message display on the control panel
Error 55 is a major Engine or DC controller issue.
HP LaserJet Enterprise Printers 55 00 0x and 55 0x 06 Errors
Try spares from salvaged printers. Look for "working pull from damaged unit". Of course reconfirm model and spare compatibility.
Printer Works RM1 9371 000 DC Controller As M775 mfp
HP LaserJet DC Controller For M775 Printer RM1 8898 - USD70+shipping
Mar 18, 2016 | HP LaserJet M775DN Laser Multifunction...
I Have A 2006 Chevy Trailblazer And Neither The Key Or Keyless Entry button Will Unlock The doors. What could be the problem?
If it uses central locking then ma bee your car battery has gone flat you will need to access the battery somehow and charge it up or replace it If your car is fitted with a trailer plug you can use a spare battery ---conect the negative of the spare battery to your chasis and connect the positive of the spare battery to the auxiliarry pin on the trailer plug to power up then unlock the doors
Nov 23, 2014 | Cars & Trucks
59.9k error on hp laserjet 5500
59.9 error is caused by a problem with the ETB (transfer belt) motor. Check the connector that the belt plugs into to make sure it is not damaged. If you have a spare Transfer Belt I would try that first. Most likely the motor has failed and will require replacement.
Jul 03, 2014 | HP Color LaserJet 5500 Printer
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
B4000 problems
since you have a truck, what I would do is just saw it off, let the spare fall to ground, and just throw my spare tire in the back. Of course you can try to use wd40 to loosen the stuck mechanism. Little known fact: Brake fluid works best at loosening rust, just don\'t get it on any paint, as you can bet your bottom dollar the paint will be gone by morning.
Dec 17, 2013 | Cars & Trucks
Error code 55.4k
This error 55.4k appeared in printer hp color laserjet 5550. The following trouble shooting did. Orignally my printer fault is display blank.Then i replace dc board with formatter board. blank is gone dueto new ram.Machine display showed the memory process. but immediatly the error 55.4k appeared on display.The reason for this error is, communication failure between formatter and dc board.The dc board which i was replaced by old type one.Then i found exact same dc board, replaced. Error was gone.Machine came to normal status , working fine.
Oct 01, 2013 | HP LaserJet 5550dtn Printer
HP Color LaserJet CP1515n Printer is showing error 51.23. please help
error 51.23 on the hp color laserjet cp1515n printer. please help
Apr 28, 2011 | HP Office Equipment & Supplies
Hp color laserjet code 59.fo error
All the book says is that one of the motors had a problem.
Power it off for at least 30 seconds. Power back on.
Make sure you are not using a surge protector.
Put the power cord directly into the wall outlet.
I just checked the manual for another printer and the 59.f0
could be the ITB. Make sure that it is seated correctly. If you have
a spare install it and see if problem goes away.
Apr 04, 2011 | HP Laserjet Cp2025n Printer
Regularly getting error code 50.9 on a HP color laserjet 3550 printer
Hey Joe,
This is what the HP Website has to say about it:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
BUT! you can try performing a cold reset, and maybe this would help:
500, 3550, 3700, 4600, 4650, 5500, 5550, 8500, 8550, 9500) use the instructions below. 1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
Feb 07, 2011 | HP Color LaserJet 3500 Printer
I have a 2003 ford thunderbird. i have a key but the chip is gone and my spare key is gone. can my one key be rechipped?
Possibly but only the dealer would be able to do it. They can get the replacement keys with the proper chip if nothing else.
Jan 22, 2011 | Ford Thunderbird Cars & Trucks
HP Color LaserJet 3500 Printer Logo
2,791 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
