Question about Canon MultiPASS MP360 All-In-One InkJet Printer
Printing problem Printer ran out of ink whilst printing.Despite fitting new cartridges, checking there isnt a print queue, and reinstalling software, it just produces blank paper
  • ggirlc Jan 20, 2008
    Yes I have removed tabs, I may be blonde, but not that blonde! Thanks for the solution though
    That might be helpful, Theres one more possible solution before trying that. I asked Cartridge World if they had any ideas and they thought the print head might be blocked. They said they will have a go at sorting it without charging for labour, so fingers crossed. If that fails I'll try your suggestion. Many thanks.
    Genius:
  • 2,985 Answers
Have you removed the tabs on the Carts?
Posted on Jan 20, 2008
  • john ash
    john ash Jan 20, 2008
    Looks like you have done everything right then -my kinda blonde
    It OK I've got three like that[wife and 2 daughters] - I know my place.
    Now to the problem
    This may sound daft but try it.
    Take the carts out and replace them firmly.
    Remove the software[Yes I know you have done it before]
    Now just for the excerise do this
    Come off line
    Disable the Anitvirus software[did you do this when installing before - you should have]
    go to Start/Printers and Faxes click on Add a printer.
    Forget the software disk and simply follow the prompts to select from a list
    When you get there select the make Canon and then scroll down for the model MP360[or if not there any in the MP series]
    See whar happens.
    BY the way is this a new PC like Vista?
    There are know driver problems with Vista in which case refer to Canon support.
Epson Sx415 New Cartridge,empty already?!?!
1. New original ink tank will dried for several times of head cleaning procedure.
. ....ran a nozzle check and cleaned print heads because it wasn't printing any ink on the paper.... ???
Nothing at all? If yes, problem is in the printer main board. Lost electricity to the head.
Jan 13, 2013 | Epson Office Equipment & Supplies
Print job disappearing and not printing
1. Check for a paper jam. Paper jams occur when one or more sheets of paper become stuck in the feeding or printing mechanism. Gently remove any jammed paper and reset the printer.
2. Check ink levels. Those ink cartridges run out fast. If your printer looks like it is printing but nothing comes out on the page, you might be out of ink. Try replacing the cartridge and printing again.
3. Check for a clogged print head. If you know you have ink, the print head might be clogged. Navigate to "Control Panel > Printer > Right Click > Properties > Maintenance > Clean Cartridges" to attempt to clean the print head.
4. Reinstall printer drivers and software. If none of the above helps, try uninstalling and reinstalling the printer and software to correct possible software bugs, errors or conflicts.
Canon-Specific Issues
5. Check printer drivers. Navigate to "Control Panel > Printers > Right Click > Properties > Update Driver" to check for a new driver for your printer. You can also find drivers and software on the Canon Support site (see Resources).
6. Resolve the Waste Ink Error. Press menu on the printer and press scan/copy to enter service more. Press the right arrow to access "NVRAM." Set ABS-M level to 0. Set ABS-P level to 0. Press "Stop" to exit.
7. Resolve Wrong Cartridge Message. Turn off the printer and unplug the power cord. Remove the cartridges and the print head. Clean the print head in lukewarm water. Set it aside to dry. Clean the contacts gently with an eraser and wipe with a tissue. Reinstall the print head and reinsert the cartridges. Run a cartridge alignment.
8. Resolve E0D02 error. Clean the cartridges and the sender strip. The sender strip is behind the rubber drive belt behind the main hatch. It runs horizontally across the machine. Wipe it gently with a lint free cloth.
Aug 19, 2012 | Canon Pixma Mp250 Printer
Printer will not print in black. I do not use the Kodak EasyShare 5100 very often, and the black ink will not print, despite fitting a new cartridge.
Try reinstalling the software. If you are using the disc it came with make sure you check web installation. Do not plug in printer until told to do so.
Feb 26, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Not printing yellow or blue despite full cartridges & clean head?
alcohol burnout print nozzles, you have ruined your printer head. you need to replace-it.
Feb 13, 2010 | Canon PIXMA MP780 All-In-One InkJet...
My r220 epson will not prit anything
The ink indicator permanently on indicates an ink cartridge problem, (not that the protection counter needs resetting). The status monitor picture of the ink cartridges should show which cartridge is at fault, it will have a red X on it. The cartridge is empty, faulty, or in the wrong position. Alternatively, you may have an internal fault e.g. with the system board. But change the indicated faulty cartridge first.
Jan 09, 2009 | Epson Stylus Photo R220 InkJet Printer
My printer is not printing and sometimes blank paper comes out
that meaNS EITHER THE CARTRIDGE IS COMPLETELY EMPTY OR THE INK IN THE CARTRIDGE IS DRIED UP.
Dec 02, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Standard black printing has faded to grey.
Could just be a faulty cartridge?
My hp printer developed a similar fault, and despite all my attempts to clean, realign, whatever, the problem wasn't solved till I fitted a new ink cartridge. It's worth a try.
Nov 15, 2008 | HP Officejet Pro L7680 All-In-One Printer
How do I stop a printer from printing a test page every time its turned on, I have reinstalled and still won't and also how do I replentish my ink levels when I put a new Cartridge in?
The ink levels will replenish themselves. To clear the printer queue, check the queue first on the computer (there should usually be a printer icon in the system tray). If you cannot clear it via the computer, do so via the printer itself (unfortunately not all printers do this the same way so we'd need to know the printer make and model)
May 26, 2008 | HP Office Equipment & Supplies
After changing cartridge, printer will not print, z645?
First... check to make sure you removed the yellow tab from the new print cartridge
put the ink cartridge back into the printer
click Start
click Control Panel
open Printers and Faxes
click (or double click to open) your printer icon
click on Printer menu
click on cancel all documents
Then try printing again.
If this does not work, look in the manual that came with the printer and check out the troubleshooting section.
Dec 18, 2007 | Lexmark Z645 InkJet Photo Printer
Canon MultiPASS MP360 All-In-One InkJet Printer Logo
32 people viewed this question
old marine
old marine
