Question about Compaq Armada 1700 Notebook
Smart failare predicted on hard disk - Compaq Armada 1700 Notebook
    Problem Solver:
  • 17 Answers
Pull off all of your critical data and replace the hard drive as soon as possible. SMART exists solely to give you an early warning of impending drive failure so you have enough time to backup your data before losing it permanently.
Posted on Jan 19, 2008
Smart failure predicted on hard disk repair
This means either your hard disk is about to fail or it already has in which case you will need to purchase a new HDD (hard disk drive) and then contact acer to purchase recovery disks or if it is still under warranty then contact for service.
Jul 19, 2014 | Acer Computers & Internet
How to resolve problems (smart failure predicted on hard disk 0 : toshiba MQ01ABD050 - (S1))
Copy all the data from the drive to another drive because this one is predicted to fail very soon. Format the drive. That might work, but unlikely since SMART is a hardware problem and format is more of a software driven solution. It has some elements of a hardware issue, but not enough to fix most SMART problems. A low level format might help, but that is not a DIY.
Jul 12, 2014 | Computers & Internet
SMART Failure Predicted on Hard Disk 0: WDC WD3200BEVT-75ZCT2-(S1) WARNING: Immediately back-up your data and replace your hard disk drive. A failure may be imminent. Press F1 to Continue
just means its time to backup all your information, as if the hard drive does fail theres a good chance you may lose some or all of your information.
hard drives aint that expensive around 30 pounds +
and you can replace it with any sata hard drive.
Jun 17, 2012 | Western Digital Computers & Internet
Hard Disk Problem
That failure is predicted by the SMART reporting system. Its a status chip on the drive that reports to apps that can read the smart data from the hard drive. Its not always accurate but it usually is.
Time backup your data on that drive ASAP and then buy a new drive.
Sep 07, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Smart failure predicted on hard disk toshiba mk4025gas ( pm )
This means your hard drive is bad or about to go bad and needs to be replaced. If you can still access the drive, immediately back up anything important to you. You will then need to replace the hard drive. Thanks and please take a moment to rate this solution with a fixya rating, even if the news isn't what you wanted to hear. Thanks! :c)
Feb 14, 2009 | HP Business Notebook NX9110 Notebook
Seagate 100GB Hard Drive for notebook SMART failure
Solution #1 is grossly incorrect. The S.M.A.R.T. mechanism is software/application/drive content agnostic. It is a firmware-based predictive failure feature. If the S.M.A.R.T. test returns a certain bit, then the drive is degrading and in need of replacement. If the disk is under warranty, then it generally qualifies for free replacement. If it is not under warranty, then you can run diagnostics such as which can sometimes identify the specifics. Sometimes the problem is transient, like the disk was powered on/off too many times in a short amount of time, or the temperature is too high.
May 25, 2008 | Computers & Internet
When you turn the computer on it says SMART Failer predicted on hard disk 0: HTS54108G9SA00-(S1)
S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) is a diagnostic method originally developed by IBM that at that time referred to as "Predictive Failure Analysis". This technology was developed for IBM mainframe drives to give advanced warning of drive failures. Based on this diagnostic, Compaq announced IntelliSafeTM, which was submitted to the ATA/IDE standards committees and the resulting standard was named S.M.A.R.T.
S.M.A.R.T. analyzes many of the mechanical attributes; over time, some failures can be predicted by detecting if the hard disk drive is moving out of tolerance. While the S.M.A.R.T. technology can detect upcoming issues, not all hard drive failures are predictable.
All this means on most modern drives is the hard drive is coming close to the maximum tolerances
I usually switch off in the bios smart monitoring.
This system is trying to predict a possible failure, which may or may not occur..
Mar 30, 2008 | Computers & Internet
Compaq laptop C310 T1300
here's what you should do.. first, as mentioned, you should backup all your important files in another drive or an optical drive... once you have done it, format your hard drive and perform scans to check the error.. during scan, you will see errors on it and you may not be able to fix it since the drive is internally damaged.. purchase a new one ok? just make sure to backup all your files..
Jan 23, 2008 | Compaq Armada E500 Notebook
Error message at startup !!
SMART stands for Self-Monitoring, Analysis, and Reporting Technology.
If you want lots of details on what it is, and does, take a look at this link:,_Analysis,_and_Reporting_Technology
It is highly unlikely that you will be able to fix this since it's a hardware problem on the hard drive. The drive may last for years or it may die tomorrow. At a minimum I would back up everything you care about on a regular basis.
If you found this information helpful I would appreciate it if you would rate this solution. I hate to beg, but over half of the solutions I've posted have no feedback. I'm not paid for this I'm just trying to help.
Dec 31, 2007 | Computers & Internet
Compaq Armada 1700 Notebook Logo
95 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
