Question about Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television
Samsung 42' Rear projection - High freq squeal
The TV is 5 years old, it has just started to emit a high freq squeal, which is really painful after 30mins or so. Any ideas?
  • Samsung Master
  • 5,138 Answers
Solder around pins on flyback transformer,see if this will solve your problem.some flybacks will make this sound, like a ringing noise.
Posted on Jan 19, 2008
5 year old goodmans tv suddenly went off, then intermittent high pitched squealing noises
Check the horizontal output section circuit. It sounds that the LOT {Line Output Transformer} has damaged.
May 11, 2012 | Televison & Video
I have an RCA DLP tv model HP50LPW52. the sound was there with no picture. since it is 5 years old I replaced the lamp for the first time. got it all hooked up, turned it on and the tv slowly came on....
That is your Color Wheel that is bad. I wish you would have posted the problem before buying a lamp. I would have told you to treat yourself to a new set instead of putting good money into a DLP set that is 5 years old.
Feb 10, 2011 | RCA Televison & Video
My Hitachi plasma HDTV emits a high pitch squealing sound in all volume positions. Have you seen this before. The only way I can use the tv now is to set the volume all the way off and use external...
That, I would guess, is a decoupling problem in the decoding section of the audio stage, or a poor connection in the audio section. Unfortunately a service manual and engineer will be required to find the problem
Hope that helps.
Feb 02, 2011 | Hitachi P50H401 50 in. Plasma HDTV
We have a five year old 40 inch samsung dlp tv and the only problem we have is that it has a really annoying squeal when you turn it on. It must be something to do with the fan but we have tried to use a...
Ur colors wheel is warn out,just not broken yet, it spinning off it axis.That where the noise is comming from.Replaced the colors will solved this problems.Spend some money hire a tv repair man to replaced this,because this reqiure take out alot machanical parts and boards to get to the colors wheel.
Mar 14, 2010 | Samsung LN-S4051D 40 in. LCD Television
High pitched squeal
Hi...
Does the squeal come from the TV cabinet or the speaker?
If from the cabinet , it's most likely the Horizontal high-voltage section of the set.
Find someone that's good with hand tools,unplug the set from the wall outlet, let it sit for a good 30 minutes.
have someone open up the back of the set and dust out and vacuum out any dust from inside the set.
Put back together and try it out.
Jan 01, 2009 | Samsung TXN2034F 20" TV
New High Pitch sound
If the sound is from the compressor, the unit is likely under warranty...generally 5 years.  If the unit is frozen up and the sound is from a fan that is hitting ice, defrost the unit completely.  Other fans in the unit could also be squealing.  You'll have to be a detective.
Nov 20, 2008 | GE GSS20IEP Side by Side Refrigerator
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Jan 01, 2008 | Samsung TX-P2670WH 26" TV
High pitched squeal from TV
Get a small wood/plastic stick and touch the different coils/transformers to see which one is the cause. Replace part or if the part doesn't run hot, use a small amount of hot melt to quiet. Don't completely encapsulate in glue, don't want to create any hazards.
Oct 29, 2007 | Samsung TX-R2779H 27" TV
Open Questions:
Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television Logo
110 people viewed this question
Jerry Greenberg
Jerry Greenberg
