Question about HP Pavilion dv1000 Notebook
HP Pavilion DV1000 not charging the battery
The laptop works OK, the WinXP icon says it is on mains power, and is charging the battery.
But the battery charge is not going up.
Could there be a fault in the charging circuitry?
  • 2 more comments
  • jigme Feb 16, 2008
    I have a HP Pavilion dv6000 Notebook.
    The same problem is with me, in windows XP, it says the battery is charging, but the charge is not going up.
    I even have the "HP Battery check" utility, and it says that the battery status is OK.
    What do you mean by replacing IC with blower.
    If its a problem with the motherboard circuitry, do I have to change the whole motherboard?
    And what are causes of such failure.?
    Thank You
  • jigme Apr 06, 2008
    My HP pavilion dv6244us notebook stopped charging last time. When it is plugged in, windows XP would say battery this much % (Charging), but the charge would never go up.
    Even if i shut down the pc and let it charge, the charge will stay the same. If it is plugged in, the charge will not drop but using the battery, the charge decreases.
    I tried my batter on my different notebook, and it works. The chargin works and it gets charged.
    So I think there is a problem with my notebook. What could be the problem? I have finished my warranty. How can I fix this problem.
  • XionXxen Dec 13, 2008
    I have the same problem. Which IC needs replacing?
  • bardschombur Feb 06, 2009
    Unreal. My brand new HP pavilion has the same issue. I even got a replacement battery and it still doesn't work. Thanks for checking this before it shipped out HP. Never again will I buy an HP.
    Problem Solver:
  • 19 Answers
Yes its u r mother board battery connector problem...in the mother board there is IC for sensoring DC supply..near the battery connector..plase check the IC is working properly with A logic probe.if it not working plaese replace the IC with a blower..
Posted on Jan 19, 2008
Get the latest BIOS driver from HP website.
Make sure to get the right driver for ur laptop model.
Posted on Jul 24, 2009
Hi, looks like I got same problem with my dv1000. Anybody know how to fix it by your self, I mean if I know what part might be bad, that just find new one and replace right. So anybody have any info about this "IC for sensoring DC supply" how much would be or were to find, and what's the deal with "blower" ? What this blower has to do with ? "what are causes of such failure.?" bad blower ? OK. thx.
Posted on Apr 12, 2008
    Problem Solver:
  • 10 Answers
Friends,
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
I USED THE LAPTOP HP PAVILLON DV 11OO .
ON MONDAY UP TO 22H00 THEN I SHUT IT DOWN AS USUAL.ON TUESDAY IT COULDN'T START I DON'T KNOW WHAT HAPPEN EXACTLY DOES SOMEONE CAME ACROSS SUCH A PROBLEM
Posted on Dec 10, 2008
My hp pavillion was no power without ac adapter
if the pc is not getting power without the ac adapter then most likely the battery is dead if it does not take a charge via the ac adapter then then the battery is no good or the ac adapter is busted
Apr 28, 2010 | HP Pavilion dv1000 Notebook
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I have a hp pavilion dv1000 laptop and it randomly hibernates
Go to the control panel > Power Options, click on the hibernation tab and uncheck it. Click on apply and ok. Hibernation can damage older HP systems such as the DV1000 that is running XP, make sure it is turned off and also go through the power settings and change the setting for closing the lid on the laptop. Change the setting to "Do Nothing". This will keep your system from getting corrupt.
Nov 26, 2009 | HP Pavilion dv1000 Notebook
Hp dv1000 won't power up running on power cord or battery
PLease check both of them. First check the power cord by replacing the power cord and see if its charging or the battery and see if it is charging.
Thanks
Aug 13, 2009 | HP Pavilion dv1000 Notebook
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
HP pavillion dv1000 won't charge
Try using your laptop without the battery and just using your power supply (new universal or your old one).
If your laptop works on just mains power it means your battery is causing the problem, which is not unusual.
Aug 07, 2008 | HP Pavilion dv1000 Notebook
This is going to be a problem with the power management system on the motherboard, it's a common problem. You will have to replace the motherboard in order to fix this. This is a good machine and can be fixed, but if you think it's time for a new one (and can stand the pain) go for it, besides this one will be totally obsolete soon, and you'll probably be ready for a new one within the next two years anyway.
Aug 06, 2008 | HP Pavilion dv1000 Notebook
Charging cable gets hot, charge port too, not battery though
No it is not a problem. The power dissapiation in the adaptor causes it to become hot.
Jul 16, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 PC Notebook
Have you followed the recommendations on HP SITE
If the screen is blank they suggest disconnect the power, battery, and reset the memory modules.
May 25, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
2,501 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
