Question about Yamaha YST-M7 Computer Speakers
I do not have any volumn control
I moved a week ago everything was fine set it up and no volumn control i can not raise the volumn from the speakers
  • 22 Answers
Open the speaker where the volume control is located then check it if there are lose connections. You can also clean the variable resistor or the volume control with a contact cleaner solution or oil... ^_^
Posted on Jan 19, 2008
Where is volumn control located on Mac Book
F12 increases volume. You may need to raise the volume on the browser before you go full-screen.
Feb 15, 2014 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
No volumn controll on taskbar
Try and rigth click on the bar >propertys>customise enable hear or reset default setings
Dec 18, 2009 | Computers & Internet
No sound output except for during test.
Did you check in control panel on the status of your audio settings?
Open audio devices in control panel. click on advance , then click on the drop down bar and select 5.1 . click apply,then OK then and close it .
post if that does not do it.
First unplug the speakers, and then go to the page of the manufacturer's,.
if you cannot find the disc with the drivers.,and download s new copy of the drivers..
Then install it and then shut down the computer and plug in the speakers.. that should do IT.
Nov 05, 2009 | Logitech X-540 Computer Speakers
Tuner does not work
If you're trying to listen to FM, and are indoors, and your walls are fairly thick, or brick and mortar, chances are you're not getting a strong enough signal.
Modern minisystems like yours come without an external antenna, and use their power cords in lieu of one. Try extending the cord, not coiling it, for better reception.
Other than that, your system may have had a spontaneous problem to its FM tuning module, though not likely.
Aug 29, 2009 | RCA RS2664 Shelf System
There no sound is coming from my laptop speakers
First go to http://www.versiontracker.com/dyn/moreinfo/win/142192 and download the newest version of the software. Sometimes a new program you load such as a game, media player, etc. may require a newer version of the software then what you currently have running.
This should fix the problem. If not, go into the control panel and click on Hardware and Sound in the right view panel. Click on Sound. Be sure that the playback and record tabs list Conexant as the default sound then click OK at the bottom of the window.
If this does not fix the problem check your volumn levels through the Control Panel and be sure the volumn is at adequate levels.
The next step will be to click on additional options in the left view panel. You will see several icons there. Click on Smart Audio. Click on reset to be sure the computer is using it's default settings.
You can also go to the Audio Director tab and be sure the speakers on the computer are turned on. You can set the speakers to play through the headphones or through the speakers only. Setting everything to default is usually best when trying to locate further problems.
Hope this helps everyone! Thanks!
Jun 01, 2009 | Compaq Computers & Internet
Reconnected after moving pc to another room no volumn
  • just check the volume settings on the system tray, by clicking the speaker icon on the lower right side of the screen
  • set the settings to high volume
  • if the problem persist try to delte and reinstall the sound blaster if have one.
May 28, 2009 | Dell Computers & Internet
Sound issues
the larger box is the subwoofer. the speaker is in the box with no obvious grill because it is used for bass and the box contains a "maze" through which the sound travels before exiting the bottom (usually) of the box. to resolve the issue, go into the control panel, then hardware, then device manager. locate the heading SOUND DEVICES. click the heading to drop down the devices that are under this heading. right click on the first item in the list and select...UNINSTALL DRIVER. confirm the removal and move on to the next, doing the same until no devices remain under the SOUND DEVICES heading. Reboot the computer and let Windows reinstall the devices. On the speakers, set the volumn controls at halfway. On the subwoofer set all controls to halfway. Now, play a CD.......
Jan 18, 2009 | Computers & Internet
Computer stopped recognizing the speakers
Check the sound card system Can your hear through headphones for example?
Nov 15, 2006 | Logitech X-230 Computer Speakers
Yamaha YST-M7 Computer Speakers Logo
213 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
