Dell Laptop Screen goes Dim After 5-10 minutes
I have a dell laptop. After a drop it's screen goes dim after 5-10 minutes, When I close the lap top and again open it it works fine and again after 5-10 minutes it goes dim. what is the problem and what is the solution.
  • Anonymous Jan 22, 2009
    okay, how do you switch RAMs?
    Problem Solver:
  • 19 Answers
Plase use another RAM in the same machine if the sam e problem will arise..its u r mother board prblem otherwise u r ram problem
Posted on Jan 19, 2008
I tried to clean the dell vostro 1014 fan, after i assembled the fan and turned on the laptop it appear black screen with dim image on my laptop screen, When I plug in external monitor it shows boot s
It sounsd like your GPU may be BGA chip and would require a re-flow/re-ball if your laptop shows graphical distortion on both monitors.
However I would first try taking the laptop apart again and double check you have connected everything properly.
Mar 20, 2014 | Dell Vostro 1014 Laptop Computer
Problem with magnetic switch. Sometimes when I
in the control panel power options chnage the setting to never for sleep options and dim display options
Sep 03, 2013 | Dell Inspiron Computers & Internet
WHEN I DISCONNECT THE POWER SUPPLY THE SCREEN GOES DIM
how do i get permission to download flashplayer on laptop
Feb 23, 2010 | Dell Latitude D810 Notebook
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
My Dell Inspiron 1521 keeps going dim every few minutes
This is usually an inverter or lamp issue both of which you could do yourself if you felt comfortable delving inside your laptop.
It is not usually an expensive repair and parts are available from a large variety of sources but EBAY is a good bet.
If you don't feel comfortable then a good local tech shop will be able to handle it.
Either way If one of those components is failing it is usually better to replace BOTH as they are connected.
If you found this useul pleae click
Aug 15, 2009 | Dell Computers & Internet
I have a dell latitude c400 my screen is dim. However I am able to use an external monitor.
If the screen is dim and and external monitor works, then the LCD backlight has failed. Replacement LCDs for that model are around $100 on Ebay and take 30 minutes to an hour to install depending on your skill level
Jun 06, 2009 | Dell Computers & Internet
Screen goes dim while in use
If you're using the battery, change the power saving settings.
May 03, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell inspiron 6400 display goes off < 1 min after switch on time
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
The buzzing sound is most likely the inverter problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 26, 2009 | Dell Inspiron 6400 Notebook
Screen is dim
Try looking for a function key (usually used by holding down the Fn key and then pressing one of the "F" key at the top) the key will be marked with a brightness indicator.
Is your screen only dim when running off the battery is it dim when running when the charger is plugged in as well. If it is only dim when the laptop is running on battery then this may be caused by a setting in Power Options which is located in Control Panel (that is if your running Windows). In Power Options look for settings about running on AC Power and running on Battery power.
Jan 07, 2008 | Dell Inspiron 8500 Notebook
Computers & Internet Logo
405 people viewed this question
David Payne
David Payne
