Question about Samsung HT-DS1000 System
Samsung ht ds1000 plays fine, but there is no sound.
I have a samsung ht ds1000 and there is no sound that comes out. All cables are correct. It was playing fine, but while I was watching a movie by son touched the 13 pin din connector a little and then it stopped playing audio. Could the din audio connector be faulty. I noticed if I wiggled the end of it the subwoofer makes a loud thump.
  • eddiy Feb 06, 2008
    i was listening to music and out of no where the speakers made a loud static sound and stoped playing ever since. i though that i might have blown the fuses but i cant find them... can someone please sujest something or tell where i can find them?
  • sdroy_boy Feb 25, 2009
    I have the same problem....I wiggled the din cable and got the loud thump. Now when I turn the system on I get a "protection" error message and the system shuts down. Does anyone know If I replace the cable would it solve the problem.
  • 32 Answers
You have not blown thye fuses the static sound suggests that that is not the problem
Posted on Jun 12, 2008
I have an HT-DS1000 I bought used. The FM tuner works, the CD player works ok, but it will not read DVD's at all. It just continually says "loading." I hooked up an alternate DVD player...
Optical pick up out of tolerance. If you take disc out it should stop clicking. The clicking is the optical pick up lens hitting max extension due to focus not being achieved
Apr 25, 2017 | Samsung HT-DS1000 System
Hello, pls my system if is playing the sound would cut off and pickup after some minutes while the counter on the cd player is counting which indicates that is playing but no sound,when is like this i...
When the sound cuts off just hit the side of your main system with your fist. Do it with the radio playing or the CD will skip and get damaged ( Remove all the CDs from the system ). If the sound comes back when you hit the system, there is a dry soldering in your system for which you will have to take professional help. Please check if the Fan at the back is working. Dry soldering occurs because the system is running very hot. Poor ventilation or Fan failure.
Mar 10, 2011 | Samsung HT-DS1000 System
Hello! Pls, send diagram connector to sub-woofer Samsung HT-DS1000. I want to connect low signal(Sub woofer) direct to amplifier. If connect to AUX - sub woofer sound with delay, no good sound. Thank...
The speaker connections are documented in the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-DS1000-Home-Theater-Systems-manual/id/287ci764/t/2/
Are we talking about an external add-on sub not supplied with the HT-DS1000? If so, please identify it.
The interconnecting cable itself is a 13-pin DIN.
Mar 07, 2011 | Samsung HT-DS1000 System
Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Jun 02, 2009 | Samsung HTP-1200 System
SURROUND SOUND
Do you have HDTV with Digital Coax out or Optical Out? If you do you can connect your surround system rear port mark Optical In from your HDTV Optical out. Tosh link fiber cable..
Now if you don't have HDTV with Digital out nor a HDTV but CRT set with Analog Stereo output you can connect using RCA left/right cables to bottom of the unit where you have HDMI, Component and Audio out. This is where you would connect your TV too. For audio playback using the AUX mode.
Jul 23, 2008 | Samsung HT-DS1000 System
Samsung ht ds1000 audio problem
I had the same issue 6 months after I purchased the unit. Worked with tech support several times. Finally they sent new woofer and that fixed it.
Jun 12, 2008 | Samsung HT-DS1000 System
Connect Issue?
You need to make sure your using cable rated for use as Sub woofer don't use Audio or Digital Cables they're not the same.
Oct 20, 2007 | Samsung HT-DS1000 System
Samsung home cinama
Most likley your scart cable is the culprit, check whether the scart cable is the AV I/O type. And also better check the audio settings of the DVD player. Hope u hook up the speakers correctly. Cheers, Rifaa
Sep 04, 2007 | Samsung HT-Q100 System
Dvd does not load
clean the lens of your dvd if that does not work there is a strip connected to the lens have that replace or adjusted by a tech.good luck.
Apr 03, 2007 | Samsung HT-DS1000 System
Samsung HT-DS1000 System Logo
346 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
