Question about Samsung DLP HL-P5663W 56" TV
TV keeps turning off...
I have the 50in version of the Samsung DLP HL-P5663W 56...the TV stay on for awhile and turns off by it self. i can turn it back on right away and some times it stays on for a awhile before turning off and some times it keeps turning off right away.
I have not checked the indicator lights yet but i plan to the next time it happens.
Please advise.
  • 8 more comments
  • Anonymous Mar 03, 2008
    I have the Samsung 50 inch DLP, two years old. It won't stay on and started turning off by itself and will only stay on for about at minute? Picture seems fine when it is on and the lamp looks bright so I don't think the lamp needs to be changed?????
    DlP by Samsung turning off.
    Tv turning off
  • gina1972 Jun 18, 2008
    the tv turns off after 15- 1 min then turns itself back on straight away whats the problem
  • chchri Jul 17, 2008
    turning off by its self
  • lddsdd Jul 20, 2008
    I have the 50 inch DLP as well and it stays on for about 10 minutes before it turns off. Then it will go another 10 minutes and turn off and then it may stay on for an hour before it turns off. I am quite frustrated at this point.
  • Anonymous Jul 25, 2008
    My tv is 42 in Samsung DLP and I have exactly the same problem. It turns on for 2-5 min, then switches off automatically.
  • Anonymous Oct 30, 2008
    Own a DLP-5663W Kept turning off Read manual and no troubleshooting reference to this problem A friend owns a Plasma Samsung with the same problem I think this is due maily for temperature problems. After some simple steps I was able to solve problem 1) Make sure TV is away from backwall at least 9 inches . 2) Vacuum vents and keep cabinet and surround areas free of dust 3) Keep bulb vent area from overheating I bought a small electric fan which I placed on side of tv close to bulb vent I also turned ceiling fan 4 ) Reset by unplugging TV for a few minutes Haven`t had the problem in over a month
  • Kayaddy Jan 27, 2009
    My tv keeps turning off, the lamp and temp button stay green.
    If i turn it back on it only stays on for a few minutes.
  • john83821
    john83821 Nov 24, 2012
    http://forums.cnet.com/5208-13973_102-0....
We have a Samsung HL-S6187W that's only a year and a half old that was having the same problem.... it would shut off for no reason... sometimes after being on for awhile but then sometimes it would shut off w/in a minute of it being on. Called Samsung support and they said to unplug and "reset" the T.V. and if that didn't happen they'd send a tech out (at a fairly steep service charge) and they would troubleshoot it. Talked to my audio/video guy that installed it all and he said it was probably the lamp that needed to be replaced (obviously for labor and parts charge). We really don't use the T.V. that much (have another flat screen 20' away in the kitchen we watch more often) so I seriously doubted it was the lamp.... plus it couldn't be turning off from over heating because sometimes it would turn off RIGHT after turning the set on.
After reading several suggestions here on Fixya I incorporated a few options to try and fix it myself and I am ecstatic to report that it's been over a month and a half, and we've watched it alot, and it's completely FIXED and doesn't turn off anymore --- and it didn't cost me a cent to fix!!! WOW!! Thanks to all the suggestions... this is a great website!!
Here's what I did:
1. Took off back lamp cover and vacuumed out the entire area (there wasn't ANY dust... but thought it couldn't hurt to clean it out anyway).
2. I disconnected the temperature sensor and cleaned off the contacts and plugged back in firmly.. (I think this is what the real solution was),
3. I then moved the "Auto Shut Off Switch" back and forth a little then made sure it was in the correct position when I replaced the lamp door cover (it's not hard to make sure it's positioned correctly).
Voila!! It's all fixed! This site has great pictures of the correct way to position the Auto Shut Off Switch and of the temp. sensor if you need it.
Posted on Jul 30, 2008
  • 2 more comments
  • sexydeke Apr 25, 2011
    Hi, where are the pictures to show how to disconnect the temperature sensor
    Hi, can you tell me where are the pics on how to disconnect the sensor
  • roxanavana
    roxanavana Oct 22, 2012
    what site did you go on to see the pictures???
  • john83821
    here is link i searched and helped..http://forums.cnet.com/5208-13973_102-0....
Samsung HLR4266wx: My tv was cutting off every couple of minutes. Heard it might be heating up and an automatic turn off function caused it to shut off. Purchased a can of the compressed air that you use to blow dust off computers and blew off all of the vents on the rear of the tv. Also put a small 6 inch at the rear of the tv to blow some air in the vents. The tv has not shut off in 2 days now. Might try not using the fan to see if the only problem was the clogged vents. Try this before you take the set in and they charge you $75 just to look at it.
Posted on Oct 13, 2008
    New Friend:
My DLP tv keeps turning itself off.
Posted on Oct 23, 2008
    Scholar:
  • 173 Answers
Samsung is noted for allot of shutdown circuits and sounds like one has engaged, also the switch mode power supply acts up.
I would try PS board first , then HV board.
needs shop
Posted on Jan 19, 2008
We have a Samsung HL-R6167W, less than 2 years old. It also started shutting off by itself. The TV repairman said these TV's are known to have problems with the light engine and parts connected to it. He said they used to replace the bulb, then a week or two later it would do the same thing so now they replace the light engine at the first problem. He has replaced over 50 of them. Luckily we have an extended warranty as the cost is around $750-$800. He said all these TV's should be sold with extended warranties.
Posted on Mar 04, 2008
6ya staff
SOURCE:
Samsung 50"dlp turns on&off by it self as soon as i plug it in
Sounds like a thermal problem. Check this link for more details.
Mar 04, 2013 | Samsung DLP HL-P5663W 56" TV
I have a 42 inch samsung and it turns on and stays on for a couple of seconds and turns off by its self is there anything i can do.????
iT SOUNDS LIKE THE POWER SUPPLY BOARD HAS FAILED. YOU CAN CALL 1-800-SANSUNG FOR THE NEAREST SERVICE CENTER.
Feb 05, 2010 | Samsung DLP HL-P5663W 56" TV
Why is my 42" dlp tv turns itself off after awhile?
the power supply is not working fine. your tv needs preventive service so that semiconductor, diodes and capacitors are changed on the power supply before it switches off completely on its own.
do it fast
okay
Jan 05, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP turns on and off - cycle repeats
make sure put the lamp door back before trying to turn it on because they have switches on them that allow the tv to turn on. If that is ok you probably have a bad ballast.
Call a local tv repair shop to further diagnose the problem.
Dec 10, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung dlp HL56A65 turns off and on by itself
It looks power board problem.
You need to get service from Samsung.
Mar 04, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HL-P5663W
your tv need to be re solder ,it's the first step your going to do.if nothings happened check the supply vertical IC or the IC itself.
Oct 31, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5663W 56" TV Logo
8,015 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
