Question about Compaq Presario M2000 Notebook
Sound my sound is very low.before it was high until i off it directly.from then my sound is low
    Genius:
  • 1,067 Answers
Turn it up in master menu sound in control panel try nice set extrnals turn meadia player master vol up
Posted on Jan 19, 2008
Hi, I have a Mac-3200 and need to know where to set the 3 carb. screws at. T, low and high I don't have a manual Thank you. Z-man
Most guys adjust them 'by ear'. Warm up the saw (hopefully you can get it to start), and set the high speed by opening the screw until it sounds like it is 'burbling' at wide open throttle. DO NOT adjust until it is screaming at its highes attainable rpm !!!! If you do, the mixture will be so lean it will damage the saw under repeated heavy load. Leaving it 'burble' at WOT (wide open throttle) will ensure that proper lubrication will be available in the cut. Under load, the burble will disappear and the saw should pull strong and not overheat, damage the piston or score the cylinder wall.
Next set the low speed screw until there is no hesitation in rpm increase when the trigger is pulled. Some suggest setting the low speed first then the high speed so you may have to readjust the high speed once the low speed is done.
The idle screw should be adjusted to where the chain is NOT rotating the guide bar at idle. If it continues to move, the idle is too high.
Nov 22, 2015 | McCulloch Garden
What is the setting for the hi speed and low speed on the carb
Hi Darrell:
Here's what I was taught.
- Wear hearing protection.
- Start saw.
- Adjust low speed screw... turn in slowly until engine falters, then back out a bit until engine sounds happy.
- Place screw driver in high speed screw, apply full throttle, adjust high speed..... turn in ... rpm shoud increase, ten drop off... back screw out until maximum rpm, then a tiny bit more to make sure the mixture is not too lean.
- Chain saw should now be happy.
Apr 28, 2015 | Garden
My tahoe has a high pitched sound when I accelerate
I had that sound in my Acura. The transmission was low on oil.
Hope this helps.
Sep 12, 2014 | 2006 Chevrolet Tahoe
Wiper motor will not stop
Sounds like the motor won't park try replacing the board on wiper motor
Jan 14, 2018 | Oldsmobile Silhouette Cars & Trucks
1994 pontiac grand am high beams work but no low beams, possible relay issue?
Sounds like it's in the actuator itself - the part that you move on the steering wheel or dash to put the high beams on or the headlight switch itself.. Find the ground wire on the headlights and run a new wire from that directly to the body somewhere so it gets a good ground, or directly to the neg side of the battery.
Oct 09, 2017 | Pontiac Cars & Trucks
How do I adjust the carburator on a craftsman blower
All carburetors have 3 screws high and low and idle, then screw high and low all the way in, then turn them back 1 and half that should be factory settings go from there. start with the high idle back it out slow until it sounds good. My blower ran good on two turns out on high idle then three turns on low idle. Good luck...
Sep 15, 2012 | Craftsman Garden
CEILING FAN w/remote. It worked until removed to paint. When it was reinstalled the speed is backwards (high for low, no med, low for high) & lights do not work. The re installer is not an electrician,...
There should be a small switch or a cord (tied to a switch) that changed the direction of flow. The reason for that is because you want the fan to move air downward CCW in the summer and upward CW in the winter.
Aug 11, 2011 | Heating & Cooling
Need to know low and high air screw adjustments
Turn both of them in all the way then back them out one turn. This should let you start it. Then turn the high air screw clockwise until it begins to stall, then turn it counter-clockwise until it begins to stall. Then turn it somewhere in between the two where it sounds smooth. Same with the low.
Apr 28, 2010 | Homelite Mighty Lite Lawn Trimmer
I relpaced the fuel lines on my Mccullough Eager ****** leaf blow
ok then these are the low and high speed adjusting screws. first make sure the spark plug is clean of buildup or new . what you need to do is first try to get it to idle with the low adj screw. now im not sure which ones which so try one and if it makes no difference during idle then try the other. start it if it dies turn the screw , repeat this until you get the right sound and steady idle.once you figure out the low screw trun it all the way clockwise then turn it counter about 2 turns. then tune the idle from here. you want it to have a steady sounding idle. now the idle sounds good use the high screw to adjust the throttle. give it about half throttle and turn the high screw until it sounds steady here. then go to full throttle and turn high screw until it sounds steady here. now it should sound steady at idle and throttle. and try not to trun the screws more than 1/8 to 1/4 turn at a time,especially the high, you dont want to blow it up. lemme know how it goes
Nov 16, 2008 | McCulloch 26cc Gas Blower Mcb3208
Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Aug 18, 2007 | Bose 3 2 1 GSX System
Compaq Presario M2000 Notebook Logo
57 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
