Question about HP PSC 1510 All-In-One InkJet Printer
Keep printing test sheets
Every time i turn the printer on, it print a test sheet. I tried the earlier suggestion regarding "open HP Director and click on the factory settings button". The factory setting button was not avaliable only the apply button. The printer is a HP PSC 1510v all-in one
  • 13 more comments
  • space222 Jan 22, 2008
    It is a HP test page
  • scanqueen333 Jan 30, 2008
    I have the exact same problem. When I turn the printer on, it runs a test page. I take the test page and scan it. It happens every time the printer is turned on. Scanning does not stop it. Now I just leave my printer on 24/7 because it is a waste of ink.
  • Anonymous Mar 18, 2008
    Printer is an HP PSC 1510 All In One It prints a test sheet when it is first turned on and also first thing in the morning even though it has not been turned off - also during the day after it has not been used for some hours
  • Anonymous Apr 09, 2008
    i already scaned the page.
    same problem
    i guess it s because the color ink is below 50%
    also, pressing the cancel button after power on does not help
  • Keeza Apr 16, 2008
    Every time I turn the printer on it prints a test page
  • Bhawnani Apr 28, 2008
    everytime the printer is turned on the print test page is printed first
  • Anonymous Jul 31, 2008
    hp printer keeps printintg test page
  • jesseth Aug 07, 2008
    once i open my printer, the test print always comes first everytime i open. how will i know the soultion of this matter?
  • cshields175 Aug 08, 2008
    Keeps printing the test page so I leave it on all the time. It will also not align the cartridges when I replace them.
  • Anonymous Oct 12, 2008
    Same thing here. HP REALLY SUCKS.
  • squizy Feb 03, 2009
    I have the hp C3180, on the face of it an excellant design BUT the ink catridges are tiny 5 x 4 x 3 cm they contain less than 50ml of ink. The Hp programme is designed to waste ink with excessive wiping of the heads on start up, excessive high quality printing and alignment at new cartridge installation. The programme should ask us IF we wish to perform these functions BEFORE stealing our ink. This IS theft. Are there any lawyers out there ? OR would HP like to to put there house in order by revising their programme. Who will join me in a class action to get compensation? Ted
  • randleland Mar 29, 2009
  • Anonymous May 17, 2009
    None of the solutions presented here are working on my psc 1510, and I cannot complete the alignment because the scanner is not working... I think this will be the last HP printer I will buy, really ****!
  • Soulvisitor
    Soulvisitor May 11, 2010
    is that the same as the "calibration page?"
  • Soulvisitor
    Is it a windows test page or a HP one?
  • HP Master
  • 1,113 Answers
A lot of HP printers print a page to enable the print head alignment and calabration. This normally orcurs when a cartridge has been changed. If the alignment page fails then it will reprint alignment page until it can align.
So, you need to get that page it prints and place it on the glass and press scan, then it will complete alignment and be ready to rock.
See Here
Posted on Jan 24, 2008
I had the same problem. Here's the solution:
1) Disconnect the power plug of the printer
2) Reconnect the power plug and at the seem time hold the first button (cancel) until you see the light flashing. As soon as you see it start flashing, release the cancel button. It will flash even faster for a moment.
After I reset my printer this way, it stopped trying to re-align on power-up.
Posted on Apr 04, 2009
If your printer is automatically print a test page every time you turn it on, try this: You literally have to turn it off, disconnect printer (with the USB port) from the computer, turn it back on (with the USB port still disconnected from the computer) and run a test alignment page, turn the printer off, reconnect the USB and then turn it on again. If you don't it will print a color alignment page every single time you turn it on. I hope this helps!
Posted on Jul 11, 2008
    New Friend:
The problem is, you need both black and color cartridges to complete the alignment process. If you don't use color printing (like me and many other users), it won't accept the test page as a correct one and will print it again and again.The way I deal with this problem is that I keep the test page I printed when I bought the printer and had the alignment test for the first time, and I scan it every time I replace the ink. The alignment is far from perfect, though, and there is no way to do it yourself manually.
Posted on Nov 20, 2012
Posted on Dec 23, 2008
After I have reset my printer everying Works fine.
To reset the printer.
Posted on Aug 10, 2008
Here's my solution to the test page print problem --
Immediately after you turn the printer on press the CANCEL button. This stops the printer from running the test page routine.
If you find that you sometimes forget to press the CANCEL button or delay pressing it, you may want to get in the habit or removing all the paper from the paper tray when you have finished all your print jobs and intend to turn off the printer. Obviously the test page cannot print if the paper tray is empty.
Posted on Mar 15, 2008
You can bypass the cartidge alignment process. Steps for the various models are given at:
Posted on Jul 04, 2009
I had the same problem and after working with a HP technician discovered that the HP alignment page will continue to print until a successful alignment is completed. The HP technician stated that in order for a successful alignment to occur both cartridges need to be at least 50% full. In my case I replaced the black cartridge but, the color cartridge had less than 50% ink. I replaced the color cartridge, performed the alignment and the alignment page stopped printing. What a waste of ink.
Posted on Mar 12, 2008
  • leonmadrid54 Oct 27, 2012
    yours is the best advice,thanks.
LEAVE THE PRINTER ON 24/7. What an excellant idea from cshields175 to leave the printer on 24/7, at say an average power use of 5Kw this will cost less than $10 ( £8 ) for the YEAR. So HP have now caused us to seek economies by wasting power, evidence for future proof of their global irresponsibility. Class action groups please note. HP please get your house in order this month, by going green you may actually increase sales ! Ted
Posted on Apr 05, 2009
Why does my hp laserjet 1020 keep printing 4 blanks after each printed sheet? HELP!
My solution already posted in FIXYA.. for the same complaint go through..
You need to clean the paper pick up solenoid located at down right side ...gently remove & clean it as of luck..
Aug 20, 2014 | HP LaserJet 1020 Printer
My HP PSC 1350v prints a test page every time I turn on the printer?
Bet you recently replaced a print cartridge!
That model of printer recalibrates after any cartridge replacement.
Let one of those sheets print out in full. Read what is on the sheet. Place the sheet on the scanner
and press the button that the sheet indicated to be pressed. The printer will go through a alignment
cycle then quit. Once that is finished you should not have to do anything till the next time your change
a print cartridge.
Mar 22, 2011 | HP PSC 1315 All-In-One InkJet Printer
How can I stop my printer automatically printing out a test page when I switch it on?
every time u switch on the printer it will print the alignment sheet until you scan it.once the alignment sheet is printed ,keep it in the scanner glass and press the scan button.this will scan the alignment sheet.
Sep 24, 2009 | HP Photosmart C5180 All-In-One InkJet...
I am getting the print cartridge allignment sheet repeatedly.
Please visit then search or click the printer tab to the product side and search the HP Director and download it.
Aug 13, 2009 | HP PSC 2410 All-In-One InkJet Printer
Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Aug 20, 2008 | Office Equipment & Supplies
network cable,Thanks
Feb 23, 2008 | HP LaserJet 2430dtn Printer
Keeps printing test sheet
I just had the same problem after putting in a new black cart. Try this:
  • Open HP Director
  • On the main window select Settings>Print Settings>Printer Toolbox
  • Open the Configuration Tab
  • At bottom right click "Factory Settings" button then "Apply"
A configuration warning popped up explaining that 'd be changing settings used by the driver. I clicked ok. AOK. (I did do an alignment just before this, but it's probably not required to fix the prob.
Jan 09, 2008 | HP PSC 1350 All-In-One Thermal Printer
Paper Jam message when NOT jammed
Close all the running programs/applications on your computer.
1. Click Start --All programs - HP - HP Director/Solution center.
2. In Hp Director/Solution center Click Start - Settings - Print Settings - Printer Settings
3. Click on the Features tab. Set the Paper Type to Plain paper and Paper Size appropriately.
4. Click Ok. Close HP Director/Solution center.
Open the application and try printing.
Thank you.
Dec 23, 2007 | HP PSC 2410 All-In-One InkJet Printer
My printer keeps printing the test page every time it's switched on
I had the same problem and it was driving me crazy until I did this. Please follow exactly and IN ORDER.
1. Turn off the printer and wait 10 seconds. Turn it on again
2. Let the printer print the test page.
3. After the test page is printed, disconnect the USB cable connecting the printer to your computer. DO NOT turn off the printer while disconnecting the USB cable.
4. Place the test page on the scanner glass and press the SCAN button on the printer. The ON light will flash as the page is being scanned.
5. Remove the test page when the ON light is steady.
6. Finally, turn off the printer and wait another 10 seconds. Then turn it on again. No more printing test pages! Yay!
(You may now reconnect the printer to your computer via the USB cable.)
Dec 23, 2006 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
10,791 people viewed this question
Ben Johnson
