Question about Sony Handycam DCR-TRV310 Digital Camcorder
Transfering my hi8 to digital media
I have lost my manual. how do I use the firewire to put my videos on my computer?
  • drikku Jun 15, 2008
    i have a sony camcorder which uses hi8 tape.what software and cable do i need to transfer video to a pc.please help.
  • 98 Answers
Connect ur cam to ur pc used windows movie maker from XP..from start menu----------program file-------window movie maker-----------then capture video from device---start recording then drag your video to from timeline----
Posted on Feb 09, 2008
6ya staff
SOURCE:
I have a working TRV81 Hi8 HandyCam and 15 Hi8 tapes I'd like to convert to digital and make ready for edit on IMovie (Mac). Would appreciate any advice....
The only way to do that is to play it in a device that plays Hi8 tapes and somehow converts it to a digital signal (likely through firewire as DV), then capture it to your computer just like a digital camcorder.
There are several ways:
1. Buy a device (like a camera) that plays it, output through RCA cables to your other camera or tape deck that is digital through the line in, and then just record that. (Alternatively, you could put that signal into a DVD-R machine and record onto a DVD, then just copy the files off the DVD, if you don't have a way to capture DV through firewire.)
2. Buy a device that plays Digital8 (same tapes, but miniDV FORMAT) and output directly from the tape through firewire. This means you must buy a SONY (only brand that made [now discontinued] Digital8) camcorder or deck [if decks were made, though those are usually expensive].
So, the simple answer: get a Digital8 camera and capture, or get another digital camcorder and a Hi8 camcorder and play through the digital one into the computer.
Buying a Sony Handycam (OLDER model) will be your easiest option, and probably possible on ebay, etc., for $100-$200.
Short of this, you could look to a friend or a professional solution for just getting the tape copied (like VHS->DVD services exist, there is probably some place you can mail your tape to).
EDIT: I should add: You included "8mm" in your title-- that is a bit confusing. 8mm refers to a few formats. One is film (obviously not what you're referring to), but then there is the older "8mm" tape format; it's like Hi8, but I believe it's actually not the same tape-- unlike Digital8 and Hi8which share a physical medium. I don't think you can get an 8mm -> Digital device, so you'd need to go through the RCA cables, as described above. [And though Hi8 is actually 8mm in width, it's not quite the same as the other "8mm" format... for whatever odd reason someone decided.... frown.gif]
However, I suspect you ARE actually working with Hi8, so this shouldn't be a problem.
Nov 24, 2010 | Sony Handycam CCD-TRV81 Camcorder
I have a hitachi Hi8 VM-D865 camcorder and wish to transfer the tapes to my computer to produce DVD's. Can I purchace the i-link (DV) cable through Hitachi? Is this cable all that is required to produce...
That is a standard IEEE cable that available anywhere. As far as you being able to produce the videos it depends on your computer and its capabilities. You have to have a firewire input on your pc and also the software that makes the dvd's. I hope this helps.
Sep 05, 2010 | Hitachi VMD865LA Digital-8 Digital...
We are trying to get some Hi8 footage onto our macintosh computer. We have both the VHS camera and the Elura 90. We have a firewire and have successfully transfered lots of digital video onto the computer,...
the procedure is the same ..for vhs...but you will need a firewire cable ..also ..and a program that will import from device...The issue is that Im not sure what program you need for MAC ..but if you have a windows computer available to do that ..things are getting simple..just follow this video..
http://www.5min.com/Video/Windows-Movie-Maker---import-from-a-DV-tape-6876
So...if you have a movie maker in your Mac ..the procedure will be the same ,just playback in the camera ...be sure it is detected by the firewire cable...and record (import ) with the movie maker...
Please dont forget to rate if this helps...
May 09, 2010 | Canon Elura 90 Mini DV Digital Camcorder
Six years ago, I purchased my Sony Handycam CCD_TRV308 Hi-8. Now I want to download some old videos. Will this cam corder allow me to transfer videos to my computer?
You likely need a video capture card that will accept analog video (several makers like Pinnacle--not a recommend);
...alternatively, if you have a digital video camera, better ones have an analog video input jack by which you can use the digital camcorder as an interface (with analog to digital conversion), and thence to the computer via the firewire cable.
...This technique can also be used to transfer VHS from your old VHS player from its analog output, via the digital camcorder to the PC.
..This way you can transfer into a NLE (non-linear editor) like Adobe Premier, Final Cut, Sony Vegas, AVID, etc ; and edit your video now that it has been digitized. And the Hi8 as you know will have much better resolution potential than the VHS.
Aug 08, 2009 | Sony Handycam CCD-TRV308 Camcorder
Transfer 8mm,hi8,digital 8 to pc
Since my request..Found i could answer my own questions. Brought firewire card with 6 pin socket.Also brought a cable with a 6 pin to fit the firewire card @ a 4 pin on the other end for the camera .Found my install cd. Loaded the USB installation. Got my connection completed between the camera @ the computer.With regard to the tape formats no problems at all.With nero 6 not sure yet.My home movies go back as far as 1989 and the quality is as good as new.Hope SONY don't stop making the dv tapes. With the external hard drives for editing @ storage need an answer for capacity James from Auckland New Zealand.
May 16, 2009 | Sony Handycam DCR-TRV330 Digital Camcorder
Downloading Canon ES8600 Hi8 movie to Macintosh
Just connect the camera to you Mac by using Firewire.
Apr 07, 2009 | Canon ES8600 Camcorder
Putting on computer
Hi8 camera has analog video signal / format and needs to be converted in digital format for PC storage /use.
Best option available is to hook up Hi8 camcorder with DVD recorder and burn movies on DVD. Now you have digital files of movies and can put in PC.
Dec 03, 2008 | Sony Handycam CCD-TRV68 Camcorder
Get video off Sony Handycam DCR-TRV118 Hi8 to PC or Mac
Hi There,
MisterSony is quite correct about the Capture card.
While most computers have the built-in ability to capture sound via the 'Line In' port, digitally recording the Video signal is a totally different aspect.
Certain TV Tuner cards also have Video Capture abilities (in addition to the tuner they have a VCR input). They often work in tandem with your Video Display card via the 'Feature' connector.
Both types allow the incoming signal to be displayed and recorded digitally at your choice of speeds, resolutions and formats.
My preferences in the past have been the VideoBlaster line by Creative Labs. There are many others.
I'll do a little research as to what's currently out there and post my findings directly.
Mike
Nov 01, 2008 | Sony Handycam DCR-TRV118 Camcorder
Problem with Sony Hi8 ntsc playback
Do you have firewire ( IEEE 1394 } input on your computer if you do. You can transfer direct from your CAM to computer or burn into DVD without using Dazzle 150 see how to do it in user manual if you have not user maual, download from Sony Web
Let me know if you need further assistant
Cheers
Aug 27, 2008 | Sony DCR-TRV285E Digital-8 Digital...
Transferring Hi8 to my PC
Download Driver
http://esupport.sony.com/US/perl/swu-matrix.pl?upd_id=1452
Install then download and install a video program like movavi videosuite or ulead videostudio (i personally recommend movavi).
Plug in the camcorder and switch it on, put it on play/edit and play the video, press record or capture in the software and let it record!
once the video scene in the camera is done, stop the recording and do what you wish!
GOOD LUCK!
Jul 03, 2008 | Sony Handycam DCR-TRV310 Digital Camcorder
Sony Handycam DCR-TRV310 Digital Camcorder Logo
203 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
