Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Philips 55PW6393 When you turn on power all you get is a beeping noise come from the rear of the CRT's have went bad. There is no sound or picture
  • 1 more comment
  • smoothbill Jan 19, 2008
    The Chassis # is DPTV335
  • PETERKIPP May 11, 2010
    Hi , I have the same tv and the same problems , I had it checked out and the said the h/v generator was bad, which one is it more likely to be, the generator or the ic's, or should I just replace all three since im there, plus what kind of soldier do I use on it. thank you
  • ladywinn
    ladywinn May 11, 2010
    Need to know your chassis number,year of tv.
  • Philips Master
  • 5,138 Answers
Here is the correct answer which i call fixya! no high voltage and chirping sound is caused by bad ic (7044) stk-392-120 replace both ics with stk-392-180s.that will fix your set.
Posted on Jan 25, 2008
  • Philips Master
  • 8,617 Answers
A set beeping doesnt have to mean your CRTs are dead. Its more than likely something in your power supply. Do you have any diagnosis or soldering skills?
Posted on Jan 21, 2008
Picture went out then a beeping noise started
it sounds like a dew switch it shuts down the power when it sences moister
Jul 06, 2012 | RCA Televison & Video
Philips Projection 60PP90200D/37 NO PIC NO SND 6X/1QF
I had the same problem. It is error code 61 which is a power supply fault. Had a bad LSB board (pn: 313926719011 from MCM Electronics) which blew out on of my CRT. If you have any observed arcing in your CRT's, they are bad and will need to be replaced. I went to Ebay and found a used compatible Philips brand to replaced the CRT. Do not isolate the high voltage lines of the bad CRT to troubleshoot with a bad LSB. The LSB will short out another CRT (it did on mine). I bought the service manual an learned the set does not tolerant of power line surges. If you fix it, invest is a good surge protector.
Aug 27, 2009 | Philips 60PP9200D Television
I went turn on my tv the picture came on then off
Picture turned Yellow because the Blue CRT stopped working. Power turns off because the power supply is indicating a fault. you probably lost your HT (high tension [voltage]) power supply on the blue CRT (picture tube). Professional assistance is recommended. HT power supply CAN DELIVER A LETHAL SHOCK even when the set is unplugged.
Jan 15, 2009 | Philips 46PP9302 46" Rear Projection...
RCA 32 in TV no picture no sound just a beeping noise TV power is on
HELLO.! IT SOUND'S LIKE A POWER SUPPLY PROBLEM TO ME.!!! & FOR THE TIME YOU WILL PUT IN TO IT & THE MONEY .!!! YOUR BETTER OFF GETTING A NEW SET.!!!HOPE THIS HELP'S YOU.!!!"GOOD LUCK"
Jul 20, 2008 | RCA 20F511T TV
RCA Telivision
The beeping sound is caused by the power supply trying to turn the set on then off. Your failure is a bad high voltage transformer and subsequent failure of the horizontal output transistor. Probably not a cost effective repair.
Mar 01, 2008 | Televison & Video
Beeping
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Jan 19, 2008 | Philips 55PW9363 55" Rear Projection...
You have a bad flyback transformer and shorted horizontal output transistor. Your set would have to be taken to a shop to have these parts replaced. Stargazer
Aug 04, 2007 | RCA 32V550T 32" TV
Beeping sound when tv is pluged into wall. no picture or sound
is it beeping or cherping ,cherping it the power supply trying to run.power supply poss.faulty
Jul 29, 2007 | RCA P52926 52" Rear Projection Television
No picture or sound
sounds like the PTV Small Signal Board.
Jul 22, 2007 | Philips 60P8341 60" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
142 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
