Question about Tascam CD-RW750 CD Recorder
Errors out on blank cd only
Will read a non blank cd but when i put in a blank cd it reads toc starts to load then it errors out im thinking it is a problem with the laser sticking instead of sliding in to read disk
  • 1,067 Answers
Use disk cleaner lens cleaner cd ok and only use hi end memreox in it or better not cheap shit i own this one i love mine -12 dbu for live band -8 craniks out clean live recordings from mon out on mixer use a cleaner cd with brushes on it fiber ones clean lens for u ok run few times 20 bucks at store get one use clean cd s onlow clean it off nice blow it out nice blower ok
Posted on Jan 19, 2008
Troubleshooting cd player
Your Optical Pickup is worn out. When you put the disc in the drawer, it must load to read the TOC(table of contents). If it can't read the TOC, it will stop or eject.
Aug 17, 2014 | Technics SL-MC3 61-Disc CD Changer
Wurlitzer jukebox error code 8
TOC Error - Table of Contents. The 8 flashes in this way to prolong the "Read" so bad CD can be take out.
More likely your player is beginning to fail to read the CD. Try cleaning the player lens with a Qtip and a bit of saliva. If that doesn't help, and it;s not the CD's then you may need to start thinking about sending that player out to be refurbished.
Jun 25, 2014 | Wurlitzer Jukebox 1015 One More Time...
After reading toc of my Marant zcd5003 the display is "error" seeking help to find out the cause
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
follow the steps and fix it.
God bless you
May 27, 2013 | Marantz CD5003 CD Player
Toc error 14
On questions like this it would help if we knew the manual was or was not consulted.
And if it was NOT, why.
C14 / TOC Error The unit did not read the TOC information. Insert other discs.
"If you write data to a disc and leave the session open, the TOC -- which tells the CD player or CD-ROM drive where the tracks are -- is written into a separate area called the Program Memory Area, or PMA. CD recorders are the only devices that know to look at the PMA, which is why you can't see data in an open session on a standard playback device. CD players won't find any audio tracks, and CD-ROM drives won't see a data track. When the session is finalized, the TOC is written in the lead-in area, enabling other devices to recognize the disc.
(Something to try: write an audio track to a blank CD, and leave the session open. Put the disc in a CD player. Some players will deny the existence of the disc, some will spin the disc up to an incredible speed and won't even brake the spindle when you eject the disc, others will perform equally random acts. The TOC is important!)"
Mar 02, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Kenwood MD plays ok but recordings fail to play; U TOC error?
Without a decent Table Of Contents, your MiniDisc will NOT work, as you've found out. Does it matter what brand of MD you use? I would record it at "1X" and NOT 4x speed too. Try erasing a blank minidisc first and then shut off the unit and then turn it back on and see if the TOC works. Try adding a title, then turn it off and back on. Then try the CD to MD.
Jan 16, 2010 | Audio Players & Recorders
Error - 8403 on cdj 200 not reed the cd
Can't find Error 8403 in the service manual. Please advise the correct error code and I'll see what I can find out for you.
E-7201 TOC READ ERROR 26: TOC data could not be read.
62: The program cannot be written in the DSP.
(Startup error)
12: The desired address could not be searched.
15: Address data could not be read.
22: The Focus Servo could not be closed.
91: The pickup could not be returned to the inner track.
(Abnormality in playback)
(Abnormality in writing to the buffer)
99: Abnormality in writing in the buffer
(Abnormality in decoding)
Abnormality in decoding ∗∗
(Inappropriate data format)
A data format other than MP3 was used. ∗∗
E-9101 MECHANICAL TIME OUT 90: Abnormality in the disc-loading mechanism (TIMEOUT)
Feb 24, 2009 | Pioneer CDJ-1000 CD Player
Emerson 3 disk CD player - CD spins - message
im not sure what toc read means, my cd player says that im guessing it means its loading, any ways take the d player apart an clean the lens wit a cuetip that should work, or the cds may be to scartched to read
Oct 15, 2008 | Audio Players & Recorders
Kenwood KDC-MP528 CD TOC ERR
Every one of those Kenwoods that I have fixed with that error needed the laser pick up replaced. so there is no easy fix for it.
If you have tried several disc's and they all have a TOC err, and you know the disc's are in decent condition, then you will need the pick up replaced.
First try cleaning the disc you are using. I use windex and a soft cloth like a bath towel, it works great at getting fingerprints and other stuff off the disc without scratching the disc. A bad fingerprint or a bad scratch right at the innermost part of the disc (where the TOC is located) will cause any CD player to not read the TOC, producing a TOC ERROR. you never know, you might get lucky.
Jun 17, 2008 | Kenwood KDC-MP528 CD Player
Toc error
toc error means "table of contents" error... means the player is unable to read the disc at all. May have a dirty focal lense to laser. clean gently with some windex on a cotton wool bud. It may be a faulty spindle motor that spins the disc. the bearings get worn or uneven and do not allow for disc reading to be successful. a check for this is a drop of oil to the bearing. It may then start to read discs, but will still require the motor to be replaced. . Check for the above... but if there is more required, take it to a Kenwood 'Agent... it may need a laser change
Dec 04, 2007 | Kenwood KDC-MP228 CD Player
Tascam CD-RW750 CD Recorder Logo
398 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
