Question about Acer Aspire SA20 PC Desktop
Getting no single to my moniter
When i turn on my computer i get a no single on my screen. could it just be the video card or some thing else. i have tried other cables and still nothing
  • Anonymous Aug 09, 2008
    When switch on the computer and the monitor say "NO SIGNAL"
  • 2,351 Answers
Good start. Suggest you borrow a working monitor & hook it up to your pc. Still no video? Your Pc system has a built in video card. It is part of the mainboard. The video is run by a intergrated controller. Either the controller is defective or just the video is defective. You do have an extra PCI (white in color) slot. You can add a PCI video card, however it may or may not function with the defective video controller.
This link below shows what your mainboard supports. This is only a referance. Some other sites show differant configurations not consistant with this link.
2nd link. This is differant.:
Posted on Jan 19, 2008
    Problem Solver:
  • 14 Answers
If your power light is on and no long beeps from your computer then is your intergrated video chip is bad. Your system board dosnt support agp or pci-e video cards. You will have to settle for a pci video card here is a good computer store to purchase one.
After a few minutes display disappar with a verticle flash line and when again power on its normal again for a few minutes ibm15" p50 crt moniter
  • Make Sure the cable or connected properly.
  • Restart the Computer
  • As soon as you restart Tap F2 key.
  • You will get BIOS screen.
  • Check whether you have same problem on the screen. If you have same problem on bios screen. it problem with the monitor.
  • If not with the computer Software.
Please rate my response!!
Jan 29, 2010 | IBM P 50 15" CRT Monitor
Lg Flatron 17" monitor turns on you see the green light then
it's prb.. your video card not the moniter if a moniter goes from green to yellow " standby" it's prb the computer not the moniter
Dec 27, 2009 | LG Flatron L1715S 17" LCD Monitor
When I hook up my moniter it does not work like other moniters.
ok sounds like you have a broken pin on your cable if you look in the end of the cable plug the part thet goes into the box but also check both ends if they are there
failing that take monitor to roof and heave ho away it goes
Jul 25, 2009 | Compaq P 1220 22" CRT Monitor
I have an eMachine that the moniter will not turn on. I run a virus scan. But cannot get the moniter the stay on. the power light is on, the screen is not working.
The first thing we need to do is figure out if the problem is the computer or the monitor.
Have you got another computer around, a laptop will work too.
Jun 17, 2009 | E-Machines eMachines Desktop PC
Moniter says no signal
You may need to replace the moniter cord or check the video card on the computer.
May 31, 2009 | Acer Aspire™ T180 PC Desktop
My Moniter Is Blank
First make sure that you have the P4 connector (the square one at the top of the board connected to your P4 power from the power supply.
From here I would disconnect the data cables from the hdd, optical drives, and remove all video/peripheral cards. You should have only the RAM, CPU, and power connected, then try to boot again.
If this works, then add 1 device at a time until it fails to start. This will isolate the component that is giving you problems.
With a single stick of RAM, try to get the computer to POST. (if possible, test the ram in another machine first to ensure that RAM is good)
Jan 01, 2009 | ASUS EN8400GS SILENT/HTP/256M PCI-E TV-OUT...
Moniter is black but has power
It's your video card! No Doubt! that happened to mine once and my friends and it was the same thing!
Dec 19, 2008 | HP Compaq FP5315 15" LCD Monitor
Computer Moniter screen turned purple
This is a problem with the video cards hardware or the driver itself depending on your card you should updaate your cards driver from the appropriate site,right click the desktop>properties>settings>advanced>ada... will then see the name and manufacturer of your graphic card
go to the appropriate website and download the latest driver,here are the three main graphic card manufacturers websites
1) nvidia.....
other things to check are
1.make sure your graphic card is securely fitted and if power is required to the card,then check the power connector is securly fitted and inserted
2.try changing your monitors lead from the v.g.a connector to the d.v.i connector at the back of the card,the v.g.a. is a blue connector and the d.v.i. is a white connector,and the d.v.i requires a d.v.i to v.g.a converter
3.where applicable install any monitor drivers however these are rarely required the direct x diagnostic utility,press start>run>type dxdiag >press enter,then go to the display tab and run the "test direct 3d" test
5.finally check all cables are securly fitted
if after these tests and tasks you still experience problems then change the graphics card and run the tests again,if you experience more problems then a new video/graphic card is required
any problems let me know
good luck .......
"Don't forget to rate the solution"
May 28, 2008 | Gateway FPD2275W LCD Monitor
Check the inverter board.
Sep 10, 2007 | BenQ T701 TFT 17" LCD Monitor
Acer Aspire SA20 PC Desktop Logo
185 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
