IP fails in n/w diognosis
Hello people i am having lan issues it seems that my computer's ip [failed] in network diognosis, when i try and 'repair' the connection it says "the following repair operation failed: flushing arp cache" and "renewing ip failed" when searching for my computer from the other one it shows up but not from mine to the other, both pcs are running identical versions of win xp.
most games we play still work n/w just cant get file sharing going..
also i have to manually enter ip, and gateway for adsl connection
any help would be greatly appreciated.
cheers
  • sirenigma Jan 23, 2008
    Have tryed that, even tryed a different network card, same problem, it wont auto config, or manual
  • 20 Answers
You should reinstall you network adaptor driver
then you may get solve this problem.
Posted on Jan 21, 2008
I am trying to connect a panasonic blue ray recorder model number dmr bw 780 to the network i have followed the instrutions on connecting a lan cable to the unit and connecting the other end to a router...
This could be a few things. 1) Did you ever set p your router to only put out so many IP addresses? Meaning normally it is set for 50 IPs but a lot of people go in and set the IPs up for only how many computers are on it. This causes problems when people come over your house and connect their phones and such. 2) Some time when you put on new devices you have to reset your router. It has conflicts sometimes and all that is needed is a good reboot. 3) I don't know your unit but make sure you have everything setup to be auto on your device. Meaning auto ip, DNS and, Gateway on your player is set that way. 4) It maybe that your cable is bad. Just to make sure it isn't the cable try it on a laptop. Making sure you turn off your wireless on the laptop when you try this. Is the cable is bad the wireless will still pick up an IP faking you out thinking it works.
Hope this helps.
Jun 23, 2011 | Computers & Internet
Hello i have d'link airplus g dwl g630 e2 5.0 network card in my other laptop.. it has drivers installed and it connects to network, but i cant get in internet.. it says " the connection has limited...
This happens when the wireless network card fails to get an IP address from the wireless router.
To get the router to issue your wireless network card with a new IP address, right click on the wireless card icon on the task bar and click Repair.
Mar 16, 2011 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
I am trying to install my bizhub c250 through network cross cable with my computer. I adopted almost all the instuctions available for the configuration of the same but could not get a print through...
What you have done should have worked.
You may need to enter the IP address into the printer using the printer console not via the computer printer properties.
If it still does not work check the IP address range of your network card, the printer's Ip address needs to be in the same range, ie the first group of numbers must be the same, only the last group of numbers are different.
You may need to use a LAN hub with normal LAN cables and not a crossover cable.
Jul 23, 2010 | Office Equipment & Supplies
Network connects without router. Install router
is your router powered? make sure your router is powered properly.
are you connecting your computer to the LAN ports? (the ones with a number not the one that say WAN? connect your computer to one of the LAN numbered ports and check to see if you get a green light on the front pannel. if you don't have green light, try a different port until, if you run out of ports and still no green light try a different cable.
have you by any chance disable your lan ports? I don't know if it is possible on your router to disable some ports, if that's the case is better to start fresh and simply reset your router by pressing a reset button for a minute while your router is getting powered and retest to see if you a green light on the lan port where you are connecting your computer.
if all this fails, it's very likely that your router has died. replaced accordingly.
Apr 04, 2010 | D-Link DGL-4100 Router (DGL4100)
CF19 LAN connection problem
Hello there, have you check your LAN IP?Make sure that your LAN IP is uniqe from other pc on your LAN otherwise your connection will be limited.
Mar 28, 2010 | Panasonic Toughbook 19 Laptop Convertible...
Trying to connect two computers to the internet through a router (not wireless) having problems after connecting both computers to the router, only one computer has internet connection. My internet...
Initially check whether the ip address is assigned in the computer in which internet is not browsing using the command ipconfig/all for windows and ifconfig for linux.If ip is present try to ping the default gateway ip address,if ping is success there is no issue in the cable you used and also with ip address.If ip is not assigned assign ip by manually or by using dhcp of router.Enable and disable the lan card in the router so that sometimes the problem get resolved.After ip is assigned and ping with router is ok .Ensure dns servers are correct else give google public dns server 8.8.8.8.Then try to ping www.google.com in command prompt if ping is success then you can browse.
Mar 01, 2010 | HP Pavilion a1610n PC Desktop
Ip address fails test connection
you need to set your 360's network to automatically detect your settings if you have other devices hooked up to the airport and they work it is not the Airport.
When it says IP address failed it has nothing to do with comcast it is your LAN having issues not your WAN
Mar 30, 2009 | Microsoft Xbox 360 Wireless Controller
Can't access my computer onthe internet
  1. Make sure that your ISP is not blocking port 80. You can check that here. (Otherwise switch to another port like 8080 or 805)
  2. Have you setup your DDNS service on your router or ensured by other means that no-ip has your up-to-date external IP? (Make sure that your external IP matches the entry at no-ip.com!)
  3. Set your LAN server to a static IP address
  4. Make sure that port forwarding is enabled and pointing to your server.
    - That means: if you run a webserver on port 80, you have to set the external port to 80 and leave the internal blank, unless your internal server listens on a different port.
If this does not help, what exactly do your mean by "Fail to connect"? Is it a 404 error? Please provide details.
I think this might be interesting for some other people too. So please come back and leave a comment!
Feb 14, 2008 | Belkin (F5D6230-3) Wireless Router
Networking issues
Hi gymny,
The best connectivity in hosting application is using virtual ip network. Normally DHCP always changing IP in everytime your computer reboot or shutdown.
Hope this will be helpful to your problem.
Best regards,
Philip
Oct 17, 2007 | Cisco (WS-X3011) Router
Computers & Internet Logo
David Payne
David Payne
