Question about Maytag MFC2061HES Stainless Steel French Door Refrigerator
Freezer works but the frig doesn't
Maytag model MFD2561HES freezer is fine but the temp in the frig is at 72 degrees. No amount of adjustment of the temp controls affect the problem. What gives?
  • Ron Marek
    Ron Marek May 11, 2010
    bas, you either have a defrost failure or the evap fan in the freezer section is not running. Open the freezer door and see if you can hear the fan running. Then check to see if the back panel in the freezer is full of frost. Start there and post back. Catriver.
  • 30 Answers
There are repair instructions available at:
http://www.anyonecanfixit.com
specifically at:
http://www.anyonecanfixit.com/household.htm#warm_frig
Posted on Sep 17, 2009
My Maytag Refrigerator is not Cooling enough. My Freezer works fine and we have unplugged and let everything defrost and plugged back in but still not working properly. Model # is MFD2561HES
Its possible the evaporator fan is bad. Air is drawn from freezer to cool the refrigerator side and ultimately controlled by the fridge side thermostat. Or... Low freon.
Oct 28, 2013 | Maytag Refrigerators
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
Freezer works, frig doesn't
there is a fan on many newer units that blows cold air from the freezer side to the frig. If that fan is not working, the frig will be cool, but not 34° like you want it.
Nov 25, 2009 | Frigidaire Refrigerators
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
Everything in my frig is frozen
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .. I don't know what he was doing with the putty unless he was stopping up the vent which won't work because you have to have the air circulation for the fridge section to work. The fridge temp control may be the problem.
Aug 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
GE GSS25LSMFBS IS FINE IN THE FREEZER SIDE BUT FREEZES IN THE REFRIGERATOR SIDE.
Sounds like you need to adjust your airflow into the frig compartment. There are two adjustments for air flow on a side/side one at top next to thermostat and one at bottom next to crisper. If your freezer is working properly like you say then you just simply need to balance the airflow to get the proper temp of just above freezing to 40 degrees
Jul 27, 2009 | GE Profile Arctica Stainless Steel Top...
Freezer is freezing but fridge is not cold as it was
Sounds like defrost timer is not putting the refrigerator in defrost every 8 hours. You freezer should be below -5 degrees. Also the condenser beneath the refrigerator possibly needs cleaning. First slowly turn the defrost timer clockwise until freezer goes in defrost. You should hear the sound of crackling noise in freezer after about one minute into defrost. If timer does not come out of defrost or does not turn itself then replace it. Let me know what you find, Thanks Sea Breeze
Feb 07, 2009 | Frigidaire FRT15G4B Top Freezer...
Refrigerator stops cooling, but if I adjust the temp it restarts
temp control wire dodgy turn off take plug out of socket trace wire repair it switch back on i had one temp mate it was wire
Dec 17, 2008 | Frigidaire FRS23KF7AB Side by Side...
FREEZER NORM TEMP. FRIG. 60 DEGREES.
DEFROSTED COIL WITH HAIR DRYER BEHIND FREEZER WALL BELOW FAN,
REPLACED FRIG. THERMOSTAT.
Aug 11, 2008 | Maytag 21.6 Cabinet Depth Side by Side...
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Maytag MFC2061HES Stainless Steel French Door Refrigerator Logo
274 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
