Question about VIA P4X266 PE11-L Motherboard
48-bit LBA compatible BIOS possible ??
Does this motherboard have a 48-bit LBA compatible BIOS that will support a 500 GB hard drive and allow the native limitation of 137 GB partition limit to be exceeded ?? If no, is it possible to update the BIOS to accomplish this ? Thanks.
  • emeryg Jan 20, 2008
    I needed to know whether my motherboard is capable of handling 48-bit LBA which you've answered.
    My system runs on Win 2000. After install Service Pack 4 and updating the BIOS I was finally able to install the 500 GB HD and gained access to greater than 137 GB (exceeding the limitation). Thanks.
    However, in the process something happened because now when I try to start up my computer I'm getting the message "NTLDR missing." As a result the computer doesn't even boot up.
    Can someone tell me how I could've lost this file ?? More importantly, how I can resolve the problem. Thanks for the help.
  • 2,351 Answers
The last Bios update for your board was 06/18/2002. With XP editions you should not have a problem seeing the whole drive.
Your bios is not a issue with win XP & drive size.
By going to your Hd's Mfg's site you can download either bootable disks or creat a bootable CD & set your drive up in dos like mode. Your able to pick your FAT type & cluster size, drive size & preform a quick format. If you want the NTFS file system with its 4kb cluster size skip the Mfg's drive utilities & just let windows do its thing.
The link below is your board.:
Please vote...
Posted on Jan 19, 2008
While trying to install PATA 250GB HD (XP Pro) only 130GB recognized. Upgraded BIOS to v1.4 (latest) and assured by Toshiba that this would enable computer to handle 250GB. No such luck. Accessed BIOS...
According to the detailed specs on that model, it came with a 60GB ATA-5 EIDI hard drive. therefore, you can use any ATA compatible (ATA-5, ATA-6 or ATA-100) EIDE/IDE drive that has jumpers enabling you to configure the drive as "Master". Western Digital Blue Scorpio and Seagate Momentus lines both have models that will fit the bill. You can find those drives at your neighborhood BestBuy or Staples pretty easily. I don't know if the A25 BIOS supports 48-bit logical block addressing (LBA), in spite of what toshiba says, If it only supports 24-bit LBA the maximum drive size is 137GB. If it supports 48-bit LBA then you can go as high as you can find drives available; usually 500GB. I suspect that it supports 48-bit LBA because various online vendors list up to 250GB drives for that model. The most important thing about the drive, though, is that it MUST be jumperable as 'master'. A cable select only drive won't work. Both the Western Digital and Seagate EIDE models have jumpers. hope this helps but if you need anything else just ask:)
Jul 31, 2011 | Toshiba Satellite A25-S279 Notebook
Western Digital 2500aajb hard drive not reconized by windows 2000. I can see it in the bios but not in windows. Thanks so much.
Make sure you have the latest service pack for Windows 2000 - this fix will NOT work on service pack 2 or earlier.
The reason you cannot see the drive right is that 2000 doesn't have big LBA enabled, and thus has a 137GB drive size limit.
To enable 48-bit LBA large-disk support in the registry:
1.Start Registry Editor (Regedt32.exe).
2.Locate and then click the following key in the registry:
3.In the Edit menu, click Add Value, and then add the following registry value:
Value name: EnableBigLba
Data type: REG_DWORD
Value data: 0x1
4. Quit Registry Editor.
You should now reboot, and then you should be able to use your drive.
Mar 27, 2011 | Western Digital WD2500AAJB 250 GB EIDE...
Describe your Seagate Barracuda 7200.12 500 GB SATA Hard Drive is not getting detected in BIOS
It requires special hard ware tools to solve this problem. they are available with me and it just takes 20 minutes to get your data back. this is called LBA ZERO REPAIR, AND TRANSLATOR REGENERATION.
Nov 22, 2010 | Seagate Barracuda 7200.10 320 GB SATA Hard...
I purchased a Western Digital EIDE 320GB hard to replace existing Toshiba 100GB hard drive. I cloned the old hard drive using Acronis software from Western Digital and when I placed the new hard drive in...
I have the same problem with my laptop. Here is my understanding of the problem.
Many laptops have a BIOS limit of 128GB hard drive capacity.
Try to find the latest BIOS available for the laptop, and see if it supports 48-bit LBA addressing of the hard drive.
If the BIOS only supports 24-bit LBA addressing, there are tools to restrict the size of the drive.
DISCLAIMER: I have read of Dynamic Drive Overlay (or Drive Dynamic Overlay) software, which is supposed to allow for the use of larger drives. I have not used one, so I do not know how well they work. I am sure they slow down access and, from what I have read, they do not work with Vista or Windows 7.
Dec 04, 2009 | Toshiba Satellite A75-S2762 Notebook
Bought a 500gb hard disk only registers as 128Gb when in computer. how do I recover and format this oem drive?
This would be a bios limitation. Formatting wont' fix the issue. Check your bios and see if it supports "lba" . Certain manufacturers offer "Drive overlay" which will allow you to use the space ..
Nov 14, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
Overcoming the 137GB barrier on a hard drive
*********** board have no support LBA 48bit adressing.
If you want to use so big HDD, you must to upgrade bios (for LBA 48 bit) or change motherboard for new one.
Mar 30, 2009 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
My Hard Drive is 250 GB but I only see 137GB
Windows xp has a max Hard drive limit of 137GB, so what you see is totally right.
Windows XP did not support 48-bit LBA for ATAPI disk drives, which is what larger drives needs.
The service packs do address the problem but you need to have a copy of windows xp which includes at least service pack 1 on the installation.
The problem is when you install from your original disk, it doesn't include the service packs, so by the time you have got the system up and running the hard disk space has already been allocated.
Bios update wont help
controller card won't help either
Possible solutions:
If you can get hold of a new version of XP which includes at least service pack 1, you can re-install with this disk and it should find all your hard disk space
You can do what is called 'slipstreaming', this is when you burn the original XP disk and the service packs together on one disk, but it does take a bit of working out.
here are a few links which may help you more:
hope this al least sheds a little light on the problem
Feb 02, 2009 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Windows does not see full size of new Hard drive
Is your disk correctly partitioned?
  1. Right-click My Computer.
  2. Click Manage.
  3. Click Disk Management.
Find your newly installed disk and see if there is any unpartitioned space on it. If there is, just create a new partition, or delete the previous one so you can create the partition which will consume full size of the disk.
Jan 15, 2009 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
N600c's bios can't support 48-bit lba?
It depends what you want to use the laptop for but Windows XP SP2 (Disk needs Service Pack integrated), Windows Fundamentals for Legacy PC's and Windows Vista and Windows 7 will correctly address a hard drive within a machine that has the 137gb 48bit LBA problem.
Nov 01, 2008 | Compaq Evo N600c Notebook
Trying to format a 500GB HDD at full capacity
check your bios if the disk is recognized as 500gb first. if it is not recognized, update your motherboard bios. most updates are available in their manufacturers site.
Oct 11, 2007 | Western Digital Caviar SE16 (WD5000AAKS)...
VIA P4X266 PE11-L Motherboard Logo
435 people viewed this question
Top VIA Computers & Internet Experts
KG John Justin
KG John Justin
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
