AEG Lavamat W 80-W 914 001 220 00
Drum will not rotate to either wash or spin-dry. Drive belt is still firmly in place, drum and motor rotate freely when spun by hand from rear. Pump still removes water. When machine is switched to final spin-dry position the pump operates, whilst 230V appears (open circuit ref. to earth) at two of the five wires in the plug to the motor and 60V, (or 80V? I forget) at two of the others. That's about as far as I want to dig without advice. Can you help please?
  • ziade Apr 08, 2008
    I have the same problem and i find two resistor R8 R9 in the timer electrical circuit that burn. i dont know there value .if any one have manual it can help.
EngineerGR
  • 119 Answers
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Posted on Apr 09, 2008
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
  • 38 Answers
SOURCE: Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Posted on Aug 19, 2007
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
  • 351 Answers
SOURCE: Washing Machine Fuse Keeps Blowing Off !!
check for earth leakage and a water leak.is the heating element ok
Posted on Apr 03, 2008
Washing mahine stops after one minute
put it on the spin cycle and open the filter if it's the belt you will surely hear the motor spinning if not then it's not the belt
Feb 10, 2014 | AEG Lavamat 72640 Front Load Washer
Noisy machine AEG Lavamat 35600 Tumble Dryer
moter 1st i would say thx nick
Feb 10, 2008 | Dryers
Belt slipping off
did it sound loud on spin if it did
check your bearing as they may be worn and need replacing
or your pulley may be damaged
Jan 11, 2014 | AEG Lavamat 74640 Front Load Washer
THE DRUM ON MY MACHINE ISNT GOING AROUND AND IT'S NOT SPINNING
Is it old washing machine?
One problem could be belt. It could be dropped. If you hear motor spining noise, but drum isnt spining - this is it.
If you cant hear anything - motor carbong brushes..
If not - electronics problems (semistor or etc).
I need more info to help you better.
Apr 05, 2013 | AEG Lavamat 74640 Front Load Washer
On spin cycle drum going round but not spinning so clothes stay wet
Hi, if it doesn't spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jun 20, 2011 | AEG Lavamat 74640 Front Load Washer
Drum is making some really nasty banging then screaching sounds when entering high spin - any ideas??
sounds like main drum bearings not common but if the bearings are worn you get the banging noise and as it slackens the drive belt you get screeching noise as the belt slips.
Nov 21, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
Motor huming bowl not spinning
sounds like the drive belt has come off. may be something under the drum that caused it to come off.is there any error code.
Aug 06, 2010 | AEG Lavamat 88840 Front Load Washer
Drum does not agitate water goes in and it just humms, no agitation or spin
The drive belt is broken or the motor's rotor is stuck. Open the door and rotate the drum manually. The drive belt is worn or broken if you can freely rotate the drum. The rotor is most probably stuck if you cannot turn the drum.
Visual check can be done by removing the back panel. Remove the screws holding it to the cabinet and pull it off. Replace the belt if it is worn or broken. Simply wrap it around the drive motor pulley and on one side of the drum pulley. Rotate the drum pulley in such a way that the belt completely wraps around it.
Try to free the rotor if it's stuck by lubricating it and forcibly turning it back and forth until it turns freely. To remove the motor, disconnect the motor wiring harness and ground wire from the terminals and remove the mounting bolt. Pull the motor out of the mounting slots. To reinstall or replace, simply slide it back into the mounting slots and secure it with the mounting bolt.
In some cases, the drum will not spin due to a broken drum pulley. Post it back if that is the case.
Feb 07, 2010 | Kenmore 42822 Front Load Washer
AEG OKO-Lavamat 1271 VI Turbo (Washer Dryer) 7-8 years old intergrated front loaderSuddenly began clanking during the spin cycle. with no load works normally with a light load, sometimes works on some...
Sounds like the main drum bearings have failed.
At this age , I don't think this is an economical repair to undertake.
Better to replace with a new one.
Dec 13, 2008 | AEG Washing Machines
Washing Machines Logo
771 people viewed this question
Top Washing Machines Experts
