Question about Canon MV800i Mini DV Digital Camcorder
My cnon MV800i Mini DV Digital Camcorder
The canon camcorder will not load the tape and it will beep a few times and Eject it.
  • 6 more comments
  • zebair Mar 08, 2008
    ihave the same probleme my cam eject always the tape
  • Jakkin Mar 15, 2008
    I got exactly the same problem...
  • ceebee40 May 11, 2008
    Same problem here !
  • Anonymous May 23, 2008
    Same problem with ZR100
  • ibaldy May 26, 2008
    when tape is loaded is is ejected so cannot load.
  • lesd42 May 27, 2008
    Same problem with ZR400 model.
  • Anonymous Jul 11, 2008
    have the same problem. tape wont go in
  • catacons Jul 14, 2008
    when i try to load a tape it will not play, then it beeps a few times and ejects the tape.
I can not load a tape
Posted on Jan 26, 2008
Canon xl2 tape won't eject
This is a known problem.
Broken loading gear, Example: canon zr65 replace broken gear
Canon XL2 and ZR65 uses same tape drive system.
Feb 20, 2015 | Canon XL2 Mini DV Digital Camcorder
I have a canon MV 830.Please could you tell me when i put the cassette into the camcorder it keeps beeping then asks me to eject the cassette. Is this expensive to fix?
My MV830 would load without a cassette; but freeze, beep 3 times and eject if a cassette was inserted. I read the following thread with a great deal of scepticism and concern that I would damage my MV830 camcorder even more; but what did I have to lose? I loaded the compartment without a cassette, hit it firmly 3 times on the tape loading side and the issue was gone. It now works perfectly! Technology is fantastic...
http://www.fixya.com/support/t238707-will_not_load_tape
Dec 06, 2010 | Canon MV830 Mini DV Digital Camcorder
Canon NTSC ZR25 MC Digital video camcorder eating tape how can I fix it
Canon NTSC ZR25 MC Digital video camcorder is eating the tape. I've loaded a new tape and get an "eject tape" message each time. Does anyone know how to fix this issue?
Jun 24, 2009 | Canon ES75 Camcorder
Canon ZR-800 Mini DV Camcorder tape stuck
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined.
Feb 23, 2009 | JVC GR-DV800U Camcorder
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Cann't eject cassette from Canon ZR60
I had a similar problem last few days with my ZR60.
The problem I had was that the tape won't eject and on repeated attempts to eject it would eject as if it had a mind of its own.
I was messing with it a little bit and realized that the door was not opening fully. Being a delicate item I didn't realize that I was not fully opening the door may be because there was a little friction in the pivot pins or what ever.
Try to gently swing the door open fully and see if it helps.
Since I discovered this problem I tried 10-12 times, and every time it would eject the tape and load it.
I was almost going to give up this camcorder last night thank GOD, I am able to use it.
Good Luck to you.
Dec 27, 2008 | Canon ZR60 Mini DV Digital Camcorder
Won't Eject Tape
same problem, after you hit eject is pops out and never opens up, to the right of the "push" button is an arm with a spring, pushing it back will open that side, on the left side is a pin with an arm you can move the arm back the pin moves and the other side will open as well, wont fix the problem but will get you your tape back.  I have a very upset wife, we had a jvc mini DV went out one winter change in temp killed it instantly, now our canon has sat a few years and wont work either,  we bought a flip video, it works.
Oct 06, 2008 | Canon ZR60 Mini DV Digital Camcorder
Ejects tapes wont load
Hardware Problem, contact Service Center.
Jul 14, 2008 | Canon MV800i Mini DV Digital Camcorder
Will not accept any tape
i bought this camara from someone with the same problem for 5 bucks at a yard sale. an easy fix. 1. blow the dust out 2. charge the battery. 3. put the tape in and when it gos down into the case close the door and turn it on, run tape on ff then rr then turn camara to record. if it says to eject tape at any time, eject it and do it again. it worked for me.
Jan 11, 2007 | Canon ZR80 Mini DV Digital Camcorder
Canon MV800i Mini DV Digital Camcorder Logo
210 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
