Question about Averatec Sotec 3200 Series Fan with Heatsink, for AMD Athlon CPU D4008B05MZ CPU Heatsink & Fan
Averatec cpu fan
When starting up i get cpu fan error
  • 92 Answers
IF you check your BIOS and everything is fine, and also you run a stress test, and everything clears. They you have no problem, usually you see this error in custom builds.
rate pls
Posted on Feb 07, 2008
What kind of cpu cooling fan can I use in a Acer America ASE380-UD420A desktop computer?
Cooling fan to CPU are come along with the CPU. You can use any other fan, having speed regulator pin, ie, the connector wire to it will have three conductors. Keep a close look at the size and seating screws to its body to the heat-sink of the CPU.
Jul 22, 2014 | Averatec Sotec 3200 Series Fan with...
I have a fan error on startup and pc shutdown
This might have to do with how the fan is being connected for power...if it is not connected to the motherboard and you are using some sort of controller....then you have to go into the BIOS (Setup) settings and tell it to stop monitoring the fan in question. All this is assuming that the fan in question is working!
Jun 25, 2011 | Averatec Sotec 3200 Series Fan with...
Computer gets HOT and it gives me ERROR CODE CPU FAN ERROR?
Is the fan working? can you hear it? if the fan is working, check to see if dust is clogging the air vents on the side of the case, if there is, then there is probably alot of dust inside the laptop too. that may be whats causing the computer of overheat. , this is just one possible cause, the CPU fan may be broken, or your bios my be messed up.
Feb 03, 2011 | Averatec 3200 Notebook
Need to put a fan in my 3280 seires averatec is ther a parts list of the inside of the computer would like to fix myself
http://www.insidemylaptop.com/take-apart-averatec-3200-laptop/
This might help you with dismantling it
Jan 01, 2011 | Averatec 3200 Notebook
Fan does not run. computer says cpu fan failure.
First check the connector and that is good then fan has failed. You can get a new fan from places like Computer Geeks dot com or Tiger Direct. Make sure you get the right fan for your CPU.
Sep 05, 2010 | Averatec (E33-0700010-S69) Cooling Fan
My Averatec 3200 keeps shutting itself down. The
A common problem with all laptop is dust. Sounds like you have 5 years worth of dust stuck in there. You should get a can of compressed air and blow though every vent you can! You want to loosen the dust that's in there and possibly try to blow it out and/or get it closest to the vents.
After that you should take a vaacum cleaner and **** out all the dust you can!
Dust inhibits air flow, alot! Its the number 1 killer of old computers.
Apr 18, 2010 | Averatec Sotec 3200 Series Fan with...
Hi, My averatec is vibrating making weird noises, what causes this?
The only actual components with moving parts are the hard drive and fan(s). Take the side cover off the case and i am sure you will be able to tell which it is. A new cpu/fan heatsink is usually under $20 but a new hard drive could cost you a bit more.
Feb 28, 2010 | Averatec D1002UHCE-1 All-In-One Intel...
My Averatec 3200 turns of randomly...
Check the CPU and Fan/Heatsink assembly. I have a pretty good feeling that the CPU is heating up too much and is not being cooled properly. There may be lint or dust clogged in the fan. You can get access to this pretty easy by removing a few screws on the bottom panel that houses the CPU/fan.
Feb 20, 2009 | Averatec 3200 Notebook
Fan error
You mite not want to reset this. This could be telling you that your fan is faulty/Dieing. If so then if it doesn't turn off your comp, your CPU will fry from the heat. Try replaceing your CPU fan within your computer. "Cool Master" is a good brand. you can find them at any Fry's Electronics Store.
Oct 05, 2008 | Averatec Sotec 3200 Series Fan with...
CPU Fan Error - Averatec 3200
First, download PC Wizard 2008 so you can check the fan speeds and temp of your CPU (and every other component of your PC if need be) and see if it's operating properly. You can find it here:
http://pc-wizard-2008.en.softonic.com/
If it's malfunctioning, you'll need to replace it.
Nov 25, 2007 | Averatec Sotec 3200 Series Fan with...
Averatec Sotec 3200 Series Fan with Heatsink, for AMD Athlon CPU D4008B05MZ CPU Heatsink & Fan Logo
217 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
