Hello i am having a problem when running a video, movies, clips. the problem is that the picture slows down for a few moments, and then speed up until it comes to the right time,and catches the sound.than it goes for some time really well until this happens again.
i have installed k-lite mega pack, latest shockwave player, latet flash player and activX for now i solved the problem when watching something on youtube, by installing activX.
i got a laptop aspire 5100 1.6ghz turion x2,1 gb ram, 100gb hdd, and ati xpress1100 running vista ultimate p.s. the sistem runs great when i have these issues
Computer needs a cleaning or it is your internet connection or provider. Go and check your internet speed by typing Internet speed test in your browser and test to see how fast or slow your internet is running. If the internet is slow it will most likely run movies slow online and we call this buffering witch we all hate but it is do to slow computer or an upgrade needs to be done threw your internet provider.. Good luck hope this helped....
not sure how that relates to a remote control---but it sounds like your download speed is slow,you dont say if you are using wifi or a home hub,if its wifi then you need an amplifier also make sure your graphic driver is up to date and any other programs related to video like flash player,finally only run minimal programs at a time not 10 in the background it makes your computer slow,look in the taskbar to see how many are running and shut them down,try msconfig
Check your camera settings in movie mode for the correct settings for time lapse, normal, slow motion and fast motion. A slow recording memory card will not produce your problem but will take longer to save the file. If you shot the movie in PAL and played it on an NTSC TV, the picture would be in black and white with no sound and vice versa. ALWAYS format the memory card in the camera, never on a PC
Usually, huge files of movies, mp3, or even viruses can slow up your mobile unit. I suggest you install an application for antivirus that compatible to your mobile phone.
Try to remove some of the files such as mp3, or video clips, or even movies. Or you may expand your external memory card to a higher capacity.
if you have windows, then you can use windows movie maker. add your video to the folder, then click the effects link on the sidebar, scroll down, and you should find 'slow'. drag it to your clip. hope this helps
To correct this, you will need to either upgrade the RAM memory in your computer system or close everything off but the Windowes Movie Maker program. I made a few videos during the christmas season and it did the same thing to me. After i closed off all the applications and programs running in the back round, the audio and video stayed in sync. Press the "Ctrl, alt, and delete" buttons on your keyboard all at one time to bring up the "Windows Task Manager" Now, click on "processes' and end the ones you are not using, these programs running in the backround are slowing your computer down causing that lag in your movie maker.
This procedure is from the windows media player help file.I hope it's useful: ------------------------- *To play content at variable speeds*
You can change the speed at which content plays in the Player. For example, you can slow down the playback speed if you are taking notes while watching a training video, or you can speed up the slow sections of a presentation.
•Begin playing a file.
•Click the arrow below the Now Playing tab, point to Enhancements, and then click Play Speed Settings.
•Move the Play Speed slider to the speed at which you want to play the content, or click the Slow, Normal, or Fast link.
•To select speeds between the labeled play speeds, in the Enhancements pane, clear the Snap slider to common speeds check box.
•To hide the settings, click the Close button in the Enhancements pane. -------------------------
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
if your downloading movies from the intenet you will need to download divx codec this can be found on divx.com
if this does not help the your video card might not be good enough to play the movies or could be your computer is not fast enough to run them
close out al other programs and try it any programs running in the back ground can slow down movies to
