Question about True GDM-12 Refrigerator Commercial
Gdm-12 oil is leaking from underneath is this repairable
GDM-12 refrig not cooling
Posted on Nov 21, 2008
How do i chage the temperature on a true cooler gdm 49 florial cooler
True GDM-12 Refrigerator... Repair Questions - Fixya
Recent True GDM-12 Refrigerator Commercial questions, problems & answers. ...Where is the temp control on the older (14 yrs or so) on GMD-12? True ..
Aug 16, 2014 | True GDM-12 Refrigerator Commercial
Noisy compressor?
My Gdm 12 was doing the very same thing. Remove the from grill plate by taking out the 4 screws below the door. This will expose the compressor mounting plate . While the compressor is running, and is at its loudest, loosen or tighten the two front hold down bolts until the noise goes away. Most likely, when you cooler was moved or transported off the shipping pallet, it was bent slightly allowing contact between the bottom of the compressor, and the mounting plate. Hope this helps.
Feb 03, 2014 | True GDM-12 Refrigerator Commercial
Adjust temp gdm 12
Jun 26, 2012 | True GDM-12 Refrigerator Commercial
I have mazda 6 2004....earlier i have radiater leak...then i repaired...then again it started heavy fuel consumtion...and chek engine indicator appears on dash board...i have engine oil leakege also..
FOR oil leak issue and other problems you mentioned check the following help links:---
Radiator leaking?
consuming more fuel? How to maximize fuel economy on your vehicle?
Check Engine Light On car?
Common Causes of Car Oil Leaks?
Troubleshoot Car Oil leak?
Car oil leak?
Car oil leaks from valve cover gasket?
Rear oil seal leaking?
leaking oil from oil pan?
leaking oil from timing cover?
How to Check Differential Oil Leaks and Replace Oil
Oil leaks from air filter on ford?
---------This will help. Thanks.
Jan 27, 2012 | 2004 Mazda 6
This whole idea is something you should have a qualified refrigeration technician doing. There's a point in the piping from the compressor to the radiator fins, which can be located behind, underneath or inside behind a plastic panel, where the freon is both installed and removed. It requires special equipment to do both and if you get moisture in the system you can pretty much kiss it good bye. Let a pro do this.
Jan 22, 2011 | True GDM-12 Refrigerator Commercial
True GDM-12 - Unit runs, but won't cool below 60 degrees,
Is it very hot out side the unit.recharging may not hurt is it cleaned the lint could be trapping the radiator were the coolan goes through to cool down try cleanning underneath before recharging
Jul 26, 2010 | True GDM-12 Refrigerator Commercial
Fan works, just stopped cooling TRUE GDM 26
there is a leak of gas in the system,must see where the leak is, repair it then fill the gas,
Aug 21, 2009 | True GDM-26 Refrigerator
True GDM-12 Refrigerator Commercial Logo
139 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
