Question about Samsung HCN529W 52" Rear Projection Television
Double image on letters for progran guide, 12" green line during perfect focus and on start up componet one need to be re-booted a few times to acquire video
I have extended warranty from circuit city and the tech has been to my house twice. The problems are as follows.
(1) a double image appears on the program guide for letters and numbers as they course across the screen. (the tech says this is how the tv is built and that is the way it came from factory). This is a recent problem becoming obvious during the last month.
(2)an intermittent error only occurring once, a large green vertical bar appeared during perfect focus operation. I took a photograph of the error. (the tech says it had to do with a light sensor) This sounded a bit dismissive as I took the photograph at night
(3)When the tv is turned on the audio comes on but the video does not. I have to switch back and forth between component one and component two and then the video image appears.
My fear is that when this extended warranty expires in March that the tv will just go on the fritz. I can pretty much fix anything around the house ans have built computers, but I am at a loss with this one. My tv is 4 years old.
thanks for your help
  • Samsung Master
  • 5,138 Answers
Best advice run as fast as you can to the nearest Repair Shop that does samsung warranty- /// quit calling circuit city it seems like they could care less if your set is fixed or not bad business,first of all those double images you are seeing means you have convergence going out repair cost with out warranty is 350.00 and up to as much as 560.00
Posted on Jan 19, 2008
6ya staff
SOURCE:
I have paid for an extended warranty on my double oven but cannot find the papers. Who would I call to get this information and speak about service? Thank you, Arden Teplow
wherever you purchased the extended warranty should keep records and the sale person at that store regardless if it was your salesman should be able to assist you with this... i work for home depot,lowes, circuit city,best buy and lg electronic extended warranties all the time... hopefully they registered you in the system and they can help.... if you have the receipt proving you purchased the extended warranty would make it alot easier go to the store and ask for help.... hope this helps you out please vote......
Jan 03, 2011 | Jenn-Air Ovens
Same problem as many others- GREEN TV bought from Circuit city and went green about same time as extended warranty ran out. no blue left in picture green cast over all pictures any options at this date.TV...
Sony has extended the warranty on the optical block regardless of purchase date until 6/30/10. I just had them cover the repair for me. They were very good about it. Call 1-239-768-7547 in US.
Mar 21, 2010 | Sony KDS-55A2020 55" Television
Screen goes blank intermittently on 60in Sony Bravia KDS-60A3000
I am having the same problem with my Sony. I bought it at Circuit City in November 2007 and the extended warranty, which I thought was for 4 years, has expired. Has anyone else had this problem, and how did you resolve it?
Mar 15, 2010 | Sony Televison & Video
I bought a new TV from Circuit City its broke model 3200
If you purchased an extended warranty for the TV then you will need to call 1-866-839-4481 That number is for Assurant Solutions who handle the warranties sold by Circuit City and other dealers. If its under manufactures warranty still, then call the manufacturer via the number provided in your owners manual and they will assist in locating an authorized servicer in your area. Please take a moment to rate my answer. Thanks..
Nov 23, 2009 | Televison & Video
Same problem as others. Sony KDF-E55A20-while watching TV, screen goes black and sound leaves too! Will come back on in a few seconds...but continues this cycle. The green light stays on.
You really need a tech to check the error codes recorded in the TV to be sure. You could have a bad lamp driver, but I would want to see if any error codes were recorded
Sep 25, 2008 | Sony KDF-E55A20 55 in. LCD Television
Picture convergence and double lettering
there is a bad dioded rca part # rca 259638 its in the convergence part of the tv it has to be replaced
Aug 03, 2008 | RCA R52WM24 52" HDTV Projection Television
Mitsubishi slim DLP, keep or sell? can't decide
That problem with the "AIRFLOW Blocked" is now covered by Mitsubishi (parts & labor) Contact a good repair shop and they should fix it free. I had that same problem the tech came out and fixed it in about 30min.
May 19, 2008 | Mitsubishi WD-57731 57" Projection HDTV
Esa television model PDP4294lv1 Has Red appearing in the screen. We're tring to find out how do we ge rid of the redness it actually takes over the picture and your not able to see anything. We also want...
the problem you are having can be fixed with an adjutment that has to be done on the power supply. you will need a thec to do this adjustment. as for the remote you can get them here.
http://www.newtvremotes.com/Mfrs/Samsung/SamsungTV/BN5900429F.htm
as for the extended warranty if it is still under manufacturers warranty you should be able to get it from the place you purchased it from( if they offer it) or the manufacturer.
Feb 12, 2008 | Televison & Video
PT44LCX65 Has spots and Haze
Panasonic has a fix for this problem. No need to replace the light engine. Just have a service tech do an "eprom upgrade" - Fixed mine.
Jan 24, 2008 | Panasonic PT-52LCX65 44" HDTV
Samsung HCN529W 52" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
Ekse
