Question about Mitsubishi CS-35505 35" TV
My tv have picture 5 inch in the horizontal in the center....
My tv have picture 5 inch horizontal in the center , and a I have the schematic for this tv, also I have a oscilloscope 25MHz 400V max Is this can help me to fix this tv, cold you help me, Thank you!!!
Iggy Alencar
  • Iggy A Alencar
    Iggy A Alencar Jan 19, 2008
    Jaime867, can you tell me each IC is the vertical amplifier, and the high power resistors? Thank you!!!!
    Iggyalencar
  • 2,336 Answers
Check the electrolitic capacitors in the vertical section for leakage or dry condition. The vertical amplifier IC may also be defective and check for the solder joints around the high power resistors as well.
Posted on Jan 19, 2008
I have an rca model hd52w67 tv and there is a problem with the picture. the picture has a red and green picture that don't allign by about an inch. I think it is in the picture guns but i cant find a...
Do not align the guns! they are located facing up toward the mirror; they are picture tubes! covered with big glass lenses! heavy!
instead look for a red/green/blue adjustment knob on the set's front; the buttons should say: convergence or, crosshatch push the crosshatch button: once you have three vertical lines crossing three horizontal lines; just merge them using the other R/G/B knobs untill you have one white vertical line and, one horizontal line crossing in the center of the screen.
(you may have to find the controls on the remote using "setup")
Feb 11, 2010 | RCA Televison & Video
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
Pin cushion falt
Circuit diagrams are available online from 5-20 dollars. I doubt it will do you much good, as you will need to be an expert at tv repair in order to read the diagram, and trace the problem. It sounds to me like a bad capacitor near the horizontal deflection circuits, or a resistor near the pincushion adjustment could have blown. If you really want to learn how to fix your tv, you should visit some learning websites that explain the different areas of a tv circuit board and their functions.
Dec 06, 2008 | Philips Magnavox 27MS343S 27" TV
Polaroid ttm-2401
To me, sounds like a picture tube issue. horizontal / vertical controls don't fix it. then its dead.
Jun 22, 2008 | Polaroid TTM-2401 TV
Toshiba TV CX2789K Horizontal Line
Failure in the vertical deflection amplifier section. This is usualy from failed components, and sometimes cold solder connections. Most of the time, I found bad capacitors, and sometimes the output IC or transistors (depending on the model type) that have failed.
Take the set to a service center for an estimate. You may find it more feasible to buy a new set depending on the parts that failed and the time involved to do the work.
Jerry G.
Apr 14, 2008 | Televison & Video
Sony KP-46v25 rear projection: picture width contracted 4-5 inches on left and right.
Have you measured the b+ yet? I would like to see the schematic. It could be the b+ section or the horizontal drive circuit.
Sep 25, 2006 | Sony KP-48S75 48" Rear Projection...
Picture deterioration
Your whole problem my freind is dryed up capacitors. You should go, if you have the technical ability to replace these capacitors, to http://servicemanuals.net, download the schematic diagram, and start replacing the waveshaper capacitors in the vertical drive circuit.
Sep 23, 2006 | Sony KV-35V35 TV
MY TV SONY KV27FS12 PICTURE PROBLEME
Hey Rolly no problem man as if we can help ya your not taking up our time as we answer when we can. Ok theres is still a small cap somewhere by the drive ic or they call it the jungle ic. If you have a schematic scan the vert part and I will assist you the best i know how.
Apr 14, 2006 | Sony KV-27FS12 27" TV
Televison & Video Logo
82 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
