I bought a new battery installed it and plugged in the razor to charge but it just finds the network and after a while starts to beep because it says the battery is unable to charge.
when i plug the razor to charge it reads unable to charge when i plug the razor to charge it reads unable to charge
AnonymousApr 16, 2008
my phone says unable to charge when i plug it in and it is bothering me b.c i have had it on the charger for a while my phone says unable to charge when i plug it in and it is bothering me b.c i have had it on the charger for a while
AnonymousAug 22, 2008
unable to charge
unable to charge
AnonymousJan 26, 2009
Unable to Charge when AC charger is plugged into the Razr V3.Unable to Charge when AC charger is plugged into the Razr V3.
You can't post conmments that contain an email address.
It sounds like the battery pack needs replaced. You will find the correct battery type at shaveroutlet.com. See link below. You will need to order 2 batteries
To replace, you will need to remove the back cocer by removing the two screws. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
in the settings menu,there is a place that has a charge time adjust.Turn it off so the charger will start charging the battery.This is a feature so you can set the phone to charge in minutes,if the bat is too dead,then it would need hrs charging.Thats why it cannot start.
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone. Razr V3 external battery charger
Are the batteries really gettin a full charge or is your charger faulty. If you can borrow a voltage meter you can see what your battery is putting out and check the charger (plugged in) to test how much voltage it is putting out. If the Razor is 12 volt you can hook up a car/motorcycle charger to pump up those batteries. I don't think your batts are not holding a charge, i think they're not gettin a charge....good luck to you...Tim
Hi, I had the same problem with my Old Razor, I bought a new battery and that fixed the problem. New Batteries for Razors are around £6 - £7 online. google it.
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
unable to charge
