Question about EliteGroup ECS P6STMT SIS630ET Chipset Ultra ATA100 ATX Form Factor3xPCI / 2xDIMM with direct VGA, LAN&Audio (59814) Motherboard
P6stmt beep error
Hey guys. I have a elitegroup p6stmt starts up but after i start it it shows no video and several three second beeps and doesnt stop. I have switched ram, psu, and still no post. Nothing but beeps. I was just wondering if yall might be able to help.
    Genius:
  • 1,665 Answers
Make sure your RAM and Graphics Card are properly fitted and data cable of your monitor connected.
Also the links below may be useful to you
http://www.nodevice.com/driver/P6STMT/get36620.html
http://www.nodevice.com/user_manual/ecs_elitegroup/motherboard.html
Posted on Jan 19, 2008
Gw712 doesnt start just beeps
Lets see if an error code pulls up.
With the machine off, press and hold the Wash Temp Down button and then push the power button until the machine gives 2 short beeps and lights up. Now press the Spin Speed Up button three times so that the Hold and Slow LEDs are illuminated.
The eight wash progress LEDs will show the error code.
Apr 29, 2014 | Washing Machines
What are the elitegroup Computer system Beep error codes
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jul 05, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Dell power edge 2850 make 4 seconds beeps alarm without stopping and without show any error Msg on the screen.
I don't understand the beep code you describe, but the 2850 has many beep codes to help understand what is going on.
First ... Identify the beep. Does the beep start as soon as you power it on, or after several seconds? What is the pattern of the beep - is it a repeating set of beeps - 3 sets of beeps between 1 and 4 beeps ... like 1 beep-3 beeps-2 beeps, or 3 beeps, 3 beeps, 1 beep? Or is it a steady repeating beep - about once per second?
Second ... is the LCD panel on the server blue or orange? If orange, what is the error code(s) it is scrolling?
If it is a steady, once-per-second beep, it is probably your RAID controller. Does the system boot to Windows/OS ok? If so, use (or install) OpenManage Server Administrator (Managed Node from Dell's Support Site) to check the Hardware Logs and check the RAID array (under Storage/Virtual Disks). If it is not booting to the OS, then go into CTRL-M to see what the status of your array is.
Aug 16, 2010 | Dell 3.0 GHz Second Processor for...
At start the computer - 2x beep - what is that ?
Here is a good link I found on the web. You can click on link below.
Also I found Beep Code with descriptions. If you find this helpful, please rate me.
http://en.wikipedia.org/wiki/Power-on_self-test
I think a few OEM's have developed their own or use Phoenix or AMI beep codes, but for the most part motherboard manufacturers uses the IBM based ones because they are grandfathered in. Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps----------------------------CPU OVERHEATING
On the forum link below says Ram. Read on.
http://www.help2go.com/forum/computer-help/101730-post-cmos-error.html
The meaning of beeps at boot depends on the BIOS that is installed. This will give you an idea, but my guess is you have a RAM problem. Try checking that it's properly seated, otherwise you could run a program like Memtest to confirm the problem. Pls rate me. Thanks and Good Luck.
Jan 17, 2010 | EliteGroup ECS A780GM-M3 AM2+ AMD 780G...
Computer turns on and beeps
Have you recently changed any hardware or BIOS settings? Is it one beep for 8 seconds or 8 beeps? If it's 8 beeps then that indicates a bad video card. If you are not using the on board video then try re-seating the video board or try a different video board.
Mar 13, 2009 | Microsoft Windows XP Professional
Computer beeps when I try to start up
No Beeps
No Power, Loose Card, or Short.
1 Short Beep
Normal POST, computer is ok.
2 Short Beep
POST error, review screen for error code.
Continuous Beep
Repeating Short Beep
One Long and one Short Beep
Motherboard issue.
One Long and Two Short Beeps
Video (Mono/CGA Display Circuitry) issue.
One Long and Three Short Beeps.
Video (EGA) Display Circuitry.
Three Long Beeps
Keyboard / Keyboard card error.
One Beep, Blank or Incorrect Display
Video Display Circuitry.
Jan 05, 2009 | HP Computers & Internet
Starting computer
Your power and data system need inspection inside the MoBo. Hardware problems produce warning beeps, especially RAM and VIDEO. Check these first to make sure they are in slots.
Does it show anything on the screen while it's beeping??????
Please provide more information and come back
Feb 19, 2008 | MSI K8N Neo4-F Motherboard
Black screen and beeping.
try to use pci card to getto screen agp ect ok maby bios thinks its that output reset it pull out battery then back in
Feb 03, 2008 | EliteGroup ECS AMD690GM-M2 Socket AM2...
EliteGroup 741GX-M Motherboard
Your computer has memory problems. First check the video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad or they are mismatched .The CAS latency has to be the same and compatible with your M/B. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard.
Sep 25, 2006 | EliteGroup 741GX-M Motherboard
EliteGroup ECS P6STMT SIS630ET Chipset Ultra ATA100 ATX Form Factor3xPCI / 2xDIMM with direct VGA, LAN&Audio (59814) Motherboard Logo
94 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
