Question about Philips 46PP9302 46" Rear Projection Television
Cobwebbs between the screen and the screen protector
I have several cobwebs behind the screen protector on my 52 " rear projection tv .could someone tell me how to get acess to them.
thanks
    Problem Solver:
  • 15 Answers
Hi pykeman,
I have successfully used a feather duster taped to a vacuum cleaner extension tube with duct tape. Remove the back panel of your projection television, then remove the the rectangular panel near the top over the chassis where the cabinet exposes the inside screen area. You will see the red, green, and blue CRT lenses. Insert the feather duster through this rectangular opening and sweep your cob webs away from the screen. Works for me every time.
Regards,
MyTvGuy
Posted on Jan 19, 2008
Scratched plastic screen protector
I have a rear projection TV that I thought had a scratch as well. Upon closer examination and several attempts to clean, I discovered that there was a spider web behind the screan in front of the color projectors. I carefully removed the screen and gently cleaned the spider web from the screen. Presto no more scratches.
Hope this is a viable solution for you as well.
Jul 02, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Toshiba 52 inch Screen
the outer trim just pops loose behind that there are several screws the plexi is held in by those crews i believe so once you take the screws out you can clean between the two screens
Feb 04, 2009 | Toshiba TheaterWide 46HM94 46" Rear...
Cobwebs behind the screen of a 55" projection screen. How do I remove screen to clean the TV? I have a Mitisubishi WS-55809.
Hello morsec,
You will need to remove the screws on the back of the top half of the TV set. This will allow you to remove the top rear half of the TV and give you access to the screen. Make sure you do not break the mirror that is attached to the rear of the TV set. Clean the screen with a damp non-abrasive cloth dry with a dry non-abrasive cloth. When finish replace the back of the TV and tighten the screws to hand tightness.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Rca-r56wh76y851 tv front glass
Is a protector plastic?...If yes, Sure, you can replaced. I recommended open the front cover and use tape meter. Go to glass store and ask for plastic glass....You can use this plastic. If are you talking about lenticular screen, this is expense new (over $385) .Try to find a close TV shop and ask for used replacement.....That's work !!!
Aug 10, 2008 | RCA P52926 52" Rear Projection Television
Cleaning JVC rear projection screen (behind cover)
You will have to do some dissassembling of the cabinet to remove the screen and bezel assembly. If you are will to do this I can give you the directions.
Mar 22, 2008 | JVC AV-48WP30 48" Rear Projection...
How do i clean my screen
  CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
Oct 29, 2007 | RCA P52926 52" Rear Projection Television
Rca tv
my son cracked our screen protector and instead of paying two or three hundred dollars to replace it we had plexy glass cut at Lowes and put velcro striping around the edges and looked as good as the original and has held up great for five years now.
Oct 26, 2007 | RCA P52937 52" Rear Projection Television
Exploded view diagram
1) Remove rear cover. Slide out pressed-board light shield.
2) Remove any cobwebs behind screens-(soft cloth on pole)
3) wipe lens caps with soft cloth
4) re-assemble
Oct 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
130 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
