Question about Palm Tungsten E2 Handheld
Is this a battery problem?
E2 goes dead, tried the resets, nothing. Tried opening the back disconnecting the battery and then it works, and recharging, but although shows as charged it goes dead again.
  • 94 Answers
If it's not the E2 going to sleep mode ;-), have it checked by a Palm service center .It might just need a new battery. Worst case scenario the charging system is faulty. Have it checked.
Hope that helps. Let me know how you make out.
Posted on Jan 19, 2008
My 2005 Dodge Dakota's alarm won't disengage. I have tried disconnecting the battery and everytime I connect it it goes off again. The truck will not turn over. The battery is not dead and the lights flash...
I just encountered this exact problem tonight. The engine will start, but the alarm continues until I disconnect the battery. Nothing else works. Have you found any solutions, zenythe?
Jan 10, 2011 | 2005 Dodge Dakota
My Palm Tungsten E2 does not turn on.
Have you tried doing a soft reset? To do a soft reset, use the tip of the stylus to gently press the reset button inside the hole on the back panel of your handheld.
Jan 09, 2008 | Palm Tungsten E2 Handheld
My palm tungsten e2 does not power on at all? what is the solution. i tried soft reset. it did not work out.
It could be the battery. may be the charger is stuck ,did you Connect the E2 to the charger then soft reset ?this should reset the charging circuit on the Palm.after that Let it connected to the power adapter for a good 2 hours. After that, disconnect the Palm and see if it will turn on. If not, then you need to get a replacement battery for your Palm.hpe this helps.pls do let me know thanks
Jan 12, 2010 | Palm Tungsten E2 Handheld
Back door on shogun 2.8 td 1996, dead locked itself and now cant open it, i cant get the alarm to work either,however it sounds when i turn the ignition key so have to disconnect the alarm under the...
have you tried disconnecting the battery, that sometimes resets the alarm, regarding the back door......have you tried opening it from the inside
Aug 02, 2009 | 1996 Mitsubishi 3000GT
Zen V Plus locked up, will not shut off
After 3 1/2 hours, the battery went dead. I waited a couple of minutes, then plugged it into my computer to see if the battery would charge. It started charging. A few hours later I went back to check on it, and it showed a full battery. I disconnected it from my computer, and turned it on. It came on, but the screen just said "Low Battery". I then plugged it back into my computer, and the screen said "Rebuilding Library". I left it for about a 1/2 hour, and it was done. I unplugged it from my computer, turned it on, and it works now!! Hope this helps out everyone else who has the same problem.
Feb 12, 2009 | Creative Labs ZEN V Plus MP3 Player
Tungsten E2 wont power on
Turn it on pressing the reset at the same time or take out battery and unplug/plug the battery. Your battery may have died. If this is helpful, post as such. If it is a fixya, post as such. I had an E2, can tell you alot about it. TY
Jan 23, 2009 | Palm Tungsten E2 Handheld
Tungsten E2 will not power on
The Tungsten is an excellent PDA
You do have to be careful with how you handle it if you've dropped it too many times or set it down too hard or whatever something inside will get cracked or disconnected.
So you may want to open it up (personally I use a really small screwdriver but there is a kit for 9.95 on that comes with a Shim like tool that is really useful for splitting the Tungsten open because its not easy getting it open and closed)any way open the back up and make sure everything is connected and clean especially the connectors to the screen, battery and USB/charging plugs. You may also need to try charging it overnight. If you haven't run the PDA in a while its going to read a full charge regardless of how much of a charge its actually holding. Also, there are alot of other places to get A PDA repaired do a little research and find a place near you that will repair a PDA. An official Palm repair is almost always going to cost you more than anywhere else.
Jun 06, 2008 | Palm Tungsten E2 Handheld
My e2 frozen on the palm powered logo
Okay here it goes, your going to want to leave it on for however many hours it takes to completely drain the battery then you're going to want to recharge it back to normal charge, and try restarting it again. This will delete completely anything that is keeping it from restarting properly. If you did open up the machine without following "antistatic procedure" you may have fried a component on the board and then your in trouble
you'll need to salvage a board from another tungsten and put it back in your PDA and hope you put it back together right
May 28, 2008 | Palm Tungsten E2 Handheld
Garmin ique 3600 won't turn on after battery goes dead
You have to charge the unit before it will start from a dead battery (usually about 10 minutes) before even trying to start the unit.
Jan 10, 2008 | Garmin iQue 3600 GPS Receiver
I can't get my Tungsten e2 to turn on.
Open up casing to reveal battery. disconnect then reconnect battery connection to mother board.
Nov 14, 2007 | Palm Tungsten E2 Handheld
Palm Tungsten E2 Handheld Logo
394 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
